我要恢复出厂设置
  • 0收藏,673浏览
恢复出厂设置
粉丝:112人 关注:8人
什么设备?
命令行恢复出厂设置
reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //确定删除保存的配置文件
reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N  //不保存配置
This command will reboot the device. Continue? [Y/N]:Y   //继续重启
zhiliao_OFRoNw 知了小白
H3c s5120-28p-sl
粉丝:119人 关注:1人
最简单的,直接删除dir目录下以cfg和mdb结尾的文件,然后直接重启即可
