S7506E-拆堆叠升级
2023-06-07提问
  • 0收藏,668浏览
S7506E怎么拆堆叠升级,哪位大佬解答下?
粉丝:20人 关注:2人
参考防火墙步骤:
配置步骤
1 收集与备份:
<F1070>dir
<F1070>display version
 <F1070>display irf
 <F1070>display mad verbose
 <F1070>save   //ftp备份starup.cfg
2 查看剩余空间,上传升级版本,复制升级版本(主备),指定为下次启动文件:
<F1070>dir
<F1070>dir slot1#flash:/
<F1070>dir slot2#flash:/
<F1070>delete //删除多余文件
<F1070>reset recycle-bin //清空回收站
ftp上传版本文件
<F1070>copy flash:/ xxx.ipe slot1#flash:/
<F1070>copy flash:/ xxx.ipe slot2#flash:/
<F1070>boot-load file flash:/xxx.ipe slot 1 main  //指定重启加载版本文件
<F1070>boot-load file flash:/xxx.ipe slot 2 main
<F1070>display boot-loader
3 关闭MAD检测口,shutdown主框的业务口,确认业务切换到备框, 业务测试正常后,保存配置(之后割接过程中不再保存配置):
[F1070]interface Route-Aggregation 3
[F1070-Route-Aggregation3]undo mad bfd enable
[F1070]int range g 1/0/6 to g 1/0/7
[F1070-if-range]shutdown
[F1070]save
[F1070]display redundancy group aaa
[F1070]display reth int reth 2
[F1070]dis reth int reth 2
4 断开堆叠线路,建议通过拔线方式,使堆叠分裂;
<F1070>display irf
<F1070>display irf link
<F1070>display irf configuration
5 确认业务正常后,重启主框:
<F1070>reboot slot 1  (主框)
6 通过display system stable state确认主框板卡正常后,通过 security-policy switch-from object-policy startup.cfg xx.cfg实 现对象策略转换为安全策略,再次重启设备;
<F1070>display device
<F1070>display sys stable state
 [F1070]security-policy switch-from object-policy startup.cfg security-startup.cfg
7 通过display system stable state确认主框板卡正常后, shutdown 备框业务口,同时undo shutdown主框业务口,测试业务;
<F1070>display security-policy ip
[F1070]interface range g 2/0/6 to g 2/0/7  (备框)
[F1070-if-range]shutdown                 (备框)
[F1070]interface range g 1/0/6 to g 1/0/7  (主框)
[F1070-if-range]undo shutdown        (主框)
[F1070]display reth int reth 1
[sw1]ping 2.2.2.1
8 业务正常后,重启备框。重启过程中,恢复堆叠链路,备框重启完成后,自动加入堆叠;
<F1070>reboot slot 2
注意:不要保存配置
<F1070>display irf
9 测试业务正常后,恢复MAD线路,保存查看配置
[F1070-Route-Aggregation3]mad bfd enable
[F1070-Route-Aggregation3]mad ip add 192.168.2.1 24 member 1
[F1070-Route-Aggregation3]mad ip add 192.168.2.2 24 member 2
[F1070-Route-Aggregation3]quit
[F1070]display mad verbose
[F1070]save
实验数据与结果
查看剩余空间
<F1070>dir
1048576 KB total (745584 KB free)
1048576 KB total (735772 KB free)
查看版本文件
<F1070>dis boot-loader
Software images on slot 1:
Current software images:
  flash:/f1000fw-cmw710-boot-R9345P14.bin
  flash:/f1000fw-cmw710-system-R9345P14.bin
Main startup software images:
  flash:/f1000fw-cmw710-boot-R9333P35.bin
  flash:/f1000fw-cmw710-system-R9333P35.bin
Backup startup software images:
  None
Software images on slot 2:
  None
关闭主框业务,确认切换业务到备框
[F1070-if-range]dis redundancy group aaa
Redundancy group aaa (ID 2):
  Node ID      Slot          Priority   Status        Track weight
  1            Slot1         100        Secondary     -255
  2            Slot2         50         Primary       255
Preempt delay time remained     : 0    sec
Preempt delay timer setting     : 60   sec
Remaining hold-down time        : 0    sec
Hold-down timer setting         : 1    sec
Manual switchover request       : No
Member interfaces:
    Reth1                 Reth2
Node 1:
  Track info:
    Track    Status           Reduced weight     Interface
    1        Negative         255                GE1/0/7
    2        Negative(Faulty) 255                GE1/0/6
Node 2:
  Track info:
    3        Positive         255                GE2/0/7
    4        Positive         255                GE2/0/6
[F1070-if-range]dis reth int reth 1
Reth1 :
  Redundancy group  : aaa
  Member           Physical status         Forwarding status   Presence status
  GE1/0/7          DOWN(redundancy down)   Inactive            Normal
  GE2/0/7          UP                      Active              Normal
[F1070-if-range]dis reth int reth 2
Reth2 :
  GE1/0/6          DOWN                    Inactive            Normal
  GE2/0/6          UP                      Active              Normal
<F1070>dis sys stable state
System state     : Stable
Redundancy state : No redundance
  Slot    CPU    Role       State
  1       0      Active     Stable
[F1070]dis redundancy group aaa
Redundancy group aaa (ID 1):
  1            Slot1         100        Primary       255
  2            Slot2         50         Secondary     255
Member interfaces:
    Reth1                 Reth2
Node 1:
  Track info:
    1        Positive         255                GE1/0/7
    2        Positive         255                GE1/0/6
Node 2:
  Track info:
[F1070]dis reth int reth 1
Reth1 :
  GE1/0/7          UP                      Active              Normal
  GE2/0/7          UP                      Inactive            Normal
Reth2 :
  GE1/0/6          UP                      Active              Normal
  GE2/0/6          UP                      Inactive            Normal
配置关键点
升级前准备:
1.备份配置并收集设备运行信息、查看flash空间是否充足同时上传和复制版本文件到设备。
升级过程中:
1.boot-load file指定版本文件;
2.关闭MAD检测和主框业务口并保存配置;
3.重启主框并在主框启动完成前拔掉堆叠线;
4.先关闭备框业务口再打开主框业务口(间隔越短业务中断时间越短);
5.确认业务正常运行后重启备框并在重启完成之前插回堆叠线(注意重启时会提示是否保存当前配置,此时一定不能保存配置)(假如备框重启完毕未能加入主框的堆叠,则可能导致转发不通等异常。)。
升级完成后:
1.确认业务恢复情况并恢复MAD功能。
细节补充:
1、为什么拆堆叠升级前要关掉mad检测
BFD来检测网络中是否存在多个IRF,IRF分裂后,通过分裂检测机制IRF会检测到网络中存在其它处于正常工作状态的IRF。对于LACP MAD和BFD MAD检测,冲突处理会先比较两个IRF中成员设备的数量,数量多的IRF继续工作,数量少的迁移到Recovery状态(即禁用状态)。如果成员数量相等,则主设备成员编号小的IRF继续工作,其它IRF迁移到Recovery状态。这样会使得备框迁移到Recovery状态,主备框都无业务口运行,造成业务中断
2、为什么备框重启前不要保存配置
更正:是堆叠分裂状态下所有单框重启时都不要保存配置:单框下重启保存时都会丢失堆叠状态下单独配置在其他框的配置,再堆叠同步时就会丢失。堆叠断裂前,保存配置,主备框配置都会保存在starup文件中,接着堆叠分裂状态下单框重启时一定不要保存配置,那样最后堆叠重新启动调用starup的时候就是正常的配置。
3、Reth 口mac地址是否相同,为什么要相同
相同,在上、下行设备看来,与其连接的是以太网冗余接口,学习到的是以太网冗余接口的MAC地址。成员接口的激活状态发生变化,不会影响上、下行设备
粉丝:112人 关注:8人
IRF建议找窗口期升级设备.
升级参考:
