Primera Nvme 硬盘显示被降级,旧固件升级失败
2023-06-09提问
  • 0收藏,635浏览
3D-primera01 cli% showversion
Release version 4.5.11
Release Type: Extended Support Release
Component Name Version
CLI Server 4.5.11
CLI Client 4.5.11
System Manager 4.5.11
Kernel 4.5.0
IO Stack 4.5.11
Drive Firmware 4.5.11
Enclosure Firmware 4.5.7
Upgrade Tool 55 (230329)
3D-primera01 cli% showpd -i
Id CagePos State ----Node_WWN---- --MFR-- -----Model------ ----Serial---- -FW_Rev- Protocol MediaType -----AdmissionTime-----
24 0:16:0 degraded 002538F60100248C SAMSUNG AEPC3840P5xnNTLC S520NA0N600047 3P01 NVMe MLC 2023-06-03 19:55:55 MSK
25 0:17:0 degraded 002538F601002470 SAMSUNG AEPC3840P5xnNTLC S520NA0N600019 3P01 NVMe MLC 2023-06-03 19:55:55 MSK
26 0:18:0 degraded 002538F60100248D SAMSUNG AEPC3840P5xnNTLC S520NA0N600048 3P01 NVMe MLC 2023-06-03 19:55:55 MSK
3D-primera01 cli% upgradepd -a
Are you sure you want to upgrade PD firmware?
select q=quit y=yes n=no: y
PD with WWN 5002538B402503F1 has current firmware
PD with WWN 5002538B40250341
Failed -- Opcode = SCCMD_DOCDB Node = 253 Tpd error code = TE_INVALID -- Invalid input parameter Tpd error info = Could not activate firmware on PD 002538F60100248C
Upgrading PD 25
Failed -- Opcode = SCCMD_DOCDB Node = 253 Tpd error code = TE_INVALID -- Invalid input parameter Tpd error info = Could not activate firmware on PD 002538F601002470
Upgrading PD 26
Failed -- Opcode = SCCMD_DOCDB Node = 253 Tpd error code = TE_INVALID -- Invalid input parameter Tpd error info = Could not activate firmware on PD 002538F60100248D
Upgrading PD 27
Failed -- Opcode = SCCMD_DOCDB Node = 253 Tpd error code = TE_INVALID -- Invalid input parameter Tpd error info = Could not activate firmware on PD 002538F601002471
Upgrading PD 28
Failed -- Opcode = SCCMD_DOCDB Node = 253 Tpd error code = TE_INVALID -- Invalid input parameter Tpd error info = Could not activate firmware on PD 002538F601002476
Upgrading PD 29
Failed -- Opcode = SCCMD_DOCDB Node = 253 Tpd error code = TE_INVALID -- Invalid input parameter Tpd error info = Could not activate firmware on PD 002538F60100248B
Upgrading PD 30
Failed -- Opcode = SCCMD_DOCDB Node = 253 Tpd error code = TE_INVALID -- Invalid input parameter Tpd error info = Could not activate firmware on PD 002538F601002491
Upgrading PD 31
Failed -- Opcode = SCCMD_DOCDB Node = 253 Tpd error code = TE_INVALID -- Invalid input parameter Tpd error info = Could not activate firmware on PD 002538F601002479
3D-primera01 cli%
粉丝:13人 关注:11人
在使用 upgradepd 命令升级硬盘固件时,出现了多个失败的提示,提示信息为“Invalid input parameter Tpd error info = Could not activate firmware on PD”。这可能是由于硬盘固件升级过程中出现了错误,导致升级失败。
为了解决这个问题,您可以尝试以下步骤:
  1. 检查硬盘连接是否正常。请确保硬盘已正确连接到服务器,并且没有松动或损坏的连接线。
  2. 检查硬盘是否支持固件升级。请查看硬盘的规格说明书,确认硬盘是否支持固件升级。如果硬盘不支持固件升级,则无法解决这个问题。
  3. 尝试使用其他升级工具。如果您使用的是 Primera 提供的升级工具,可以尝试使用其他升级工具,例如硬盘厂商提供的升级工具。这可能会解决升级失败的问题。
  4. 联系 Primera 技术支持。如果以上步骤都无法解决问题,建议您联系 Primera 技术支持,获取更进一步的帮助。他们可以提供更详细的指导,帮助您解决这个问题。
粉丝:24人 关注:0人
硬盘状态degraded,应该用showpd -s看原因,而不是升固件
有的,showpd -s 后就是显示old firmware. 32 total 3D-primera01 cli% showpd -s Id CagePos Type -State-- -Detailed_State- --SedState-- 0 0:0:0 SSD normal normal not_capable 1 0:1:0 SSD normal normal not_capable 2 0:2:0 SSD normal normal not_capable 3 0:3:0 SSD normal normal not_capable 4 0:5:0 SSD normal normal not_capable 5 0:7:0 SSD normal normal not_capable 6 0:4:0 SSD normal normal not_capable 7 1:1:0 SSD normal normal fips_capable 8 0:6:0 SSD normal normal not_capable 9 1:3:0 SSD normal normal fips_capable 10 0:9:0 SSD normal normal not_capable 11 1:5:0 SSD normal normal fips_capable 12 1:6:0 SSD normal normal fips_capable 13 1:0:0 SSD normal normal fips_capable 14 1:2:0 SSD normal normal fips_capable 15 1:7:0 SSD normal normal fips_capable 16 1:8:0 SSD normal normal fips_capable 17 1:9:0 SSD normal normal fips_capable 18 0:11:0 SSD normal normal not_capable 19 1:10:0 SSD normal normal fips_capable 20 1:4:0 SSD normal normal fips_capable 21 0:8:0 SSD normal normal not_capable 22 1:11:0 SSD normal normal fips_capable 23 0:10:0 SSD normal normal fips_capable 24 0:16:0 SSD degraded old_firmware capable 25 0:17:0 SSD degraded old_firmware capable 26 0:18:0 SSD degraded old_firmware capable 27 0:19:0 SSD degraded old_firmware capable 28 0:20:0 SSD degraded old_firmware capable 29 0:21:0 SSD degraded old_firmware capable 30 0:22:0 SSD degraded old_firmware capable 31 0:23:0 SSD degraded old_firmware capable ------------------------------------------------------
zhiliao_bfpGc9 发表时间:2023-06-09
某些型号的硬盘固件有问题,会升级失败,到400报修吧
zhiliao_rwNFd 发表时间:2023-06-09
