f1070防火墙ipsec sa问题
2023-06-12提问
  • 0收藏,562浏览
dislpay ipsec sa ,display ikev2 sa没有信息,请问是啥问题导致以下是debug信息
*Jun 12 15:43:09:537 2023 f1/2-gdgz-yd IPSEC/7/EVENT: -COntext=1; Got SA time-based soft lifetime settings when filling Sp data. Configured soft lifetime buffer : 0 seconds. Configured global soft lifetime buffer : 0 seconds. *Jun 12 15:43:09:547 2023 f1/2-gdgz-yd IPSEC/7/EVENT: -COntext=1; Sent delete SA message to all nodes, message type is 0x16. *Jun 12 15:43:09:053 2023 f1/2-gdgz-yd IPSEC/7/EVENT: -COntext=1-Slot=1; Deleted tunnel of synchronization successfully. *Jun 12 15:43:09:053 2023 f1/2-gdgz-yd IPSEC/7/EVENT: -COntext=1-Slot=1; The SA doesn't exist in kernel. *Jun 12 15:43:09:547 2023 f1/2-gdgz-yd IPSEC/7/EVENT: -COntext=1; The SA doesn't exist in kernel. *Jun 12 15:43:11:738 2023 f1/2-gdgz-yd IPSEC/7/EVENT: -COntext=1; Can't find block-flow node. *Jun 12 15:43:11:738 2023 f1/2-gdgz-yd IPSEC/7/PACKET: -COntext=1; Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65536. *Jun 12 15:43:11:738 2023 f1/2-gdgz-yd IPSEC/7/ERROR: -COntext=1; The reason of dropping packet is no available IPsec tunnel. *Jun 12 15:43:11:738 2023 f1/2-gdgz-yd IPSEC/7/EVENT: -COntext=1; Sent SA-Acquire message : SP ID = 0 *Jun 12 15:43:11:738 2023 f1/2-gdgz-yd IPSEC/7/EVENT: -COntext=1; Received negotiatiate SA message from IPsec kernel. %Jun 12 15:43:11:738 2023 f1/2-gdgz-yd IPSEC/6/IPSEC_SA_INITIATION: -COntext=1; Began to establish IPsec SA. SA information: Local address: 27.46.171.2 Remote address: 123.60.230.113 Sour addr: 22.3.24.2/255.255.255.255 Port: 0 Protocol: IP Dest addr: 22.3.24.1/255.255.255.255 Port: 0 Protocol: IP Inside VPN instance: Outside VPN instance: ACL name: songshanhu
粉丝:144人 关注:0人
您好,参考以下排查
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
粉丝:137人 关注:8人
参考
https://www.h3c.com/cn/d_202205/1616066_30005_0.htm#_Toc104397394
debug ike 发现ike-v2的proposal不生效请问是什么原因
