ipsec+nat穿越
2023-06-15提问
  • 0收藏,544浏览
有没有IPSEC VPN 一个总部对接多个分部的案例啊?
粉丝:6人 关注:0人
参考如下:
https://zhiliao.h3c.com/Theme/details/116250
我也看看去
zhiliao_pcE0u 发表时间:2023-06-16
粉丝:35人 关注:7人
以下是配置举例,请参考:
2、需求
建立ipsec vpn实现各分支和总部之间互通,并且各分支之间也能通过总部访问。总部是固定ip地址,分支IP地址不固定,并且分支AB处无人值守且分支无主动自动访问总部的业务运行,所以为了防止分支设备断电重启后无法主动建立隧道,需要通过NQA来实现设备断电重启后自动触发隧道建立。
配置步骤
3、关键配置
总部:
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 1.1.1.2 255.255.255.252
 nat outbound 3002
 ipsec apply policy test
 ip route-static 0.0.0.0 0 1.1.1.1
acl advanced 3000
 description toBranchA
 rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
 rule 5 permit ip source 192.168.3.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
acl advanced 3001
 description toBranchB
 rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.3.0 0.0.0.255
 rule 5 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.3.0 0.0.0.255
acl advanced 3002
 description outboundNATDenyFlow
 rule 0 deny ip source 192.168.1.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
 rule 5 deny ip source 192.168.3.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
 rule 10 deny ip source 192.168.1.0 0.0.0.255 destination 192.168.3.0 0.0.0.255
 rule 15 deny ip source 192.168.2.0 0.0.0.255 destination 192.168.3.0 0.0.0.255
 rule 100 permit ip
ipsec transform-set 1
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm md5
ipsec policy-template branchA 1
 transform-set 1
 security acl 3000
 ike-profile branchA
ipsec policy-template branchB 1
 transform-set 1
 security acl 3001
 ike-profile branchB
ipsec policy test 1 isakmp template branchA
ipsec policy test 2 isakmp template branchB
ike dpd interval 10 on-deman
ike profile branchA
 keychain branchA
 exchange-mode aggressive
 local-identity fqdn headquarters
 match remote identity fqdn branchA
ike profile branchB
 keychain branchB
 match remote identity fqdn branchB
ike proposal 1
ike keychain branchA
 match local address 1.1.1.2
 pre-shared-key hostname branchA key cipher $c$3$nng95cm/zlG3ghvIRim5saZ3bMEhoJD+Ow==
ike keychain branchB
 pre-shared-key hostname branchB key cipher $c$3$Rl2okdkTYNBEYWd32X25LOWYkYo5YCcrgw==
分支A
nqa entry admin test
 type icmp-echo
  destination ip 192.168.1.1
  frequency 5000
  history-record enable
  history-record number 10
  probe count 10
  probe timeout 500
  source ip 192.168.2.1
nqa entry admin test1
 type icmp-echo
  destination ip 192.168.3.1
  frequency 5000
  probe count 10
  probe timeout 500
 nqa schedule admin test start-time now lifetime forever
 nqa schedule admin test1 start-time now lifetime forever
 combo enable copper
 ip address 2.2.2.2 255.255.255.252
 nat outbound 3001
 ipsec apply policy 1
 ip route-static 0.0.0.0 0 2.2.2.1
acl advanced 3000
 rule 0 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
acl advanced 3001
 rule 0 deny ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
 rule 5 deny ip source 192.168.2.0 0.0.0.255 destination 192.168.3.0 0.0.0.255
 rule 100 permit ip
ipsec policy 1 1 isakmp
 transform-set 1
 security acl 3000
 remote-address 1.1.1.2
 ike-profile 1
ike dpd interval 10 on-demand
ike profile 1
 keychain 1
 local-identity fqdn branchA
 match remote identity fqdn headquarters
ike proposal 1
ike keychain 1
 pre-shared-key address 1.1.1.2 255.255.255.0 key cipher $c$3$5QlYyBFEZTju/oTPut9zgP5JNpmVleBIbA==
分支B
 type icmp-echo
  frequency 5000
  probe count 10
  probe timeout 500
  source ip 192.168.3.1
 type icmp-echo
  destination ip 192.168.2.1
  frequency 5000
  probe count 10
  probe timeout 500
 combo enable copper
 ip address 3.3.3.2 255.255.255.252
 nat outbound 3001
 ip route-static 0.0.0.0 0 3.3.3.1
acl advanced 3000
 rule 0 permit ip source 192.168.3.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
acl advanced 3001
 rule 0 deny ip source 192.168.3.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
 rule 100 permit ip
 transform-set 1
 security acl 3000
 ike-profile 1
ike profile 1
 keychain 1
 local-identity fqdn branchB
ike proposal 1
ike keychain 1
4、测试
分支A侧可以ping通总部和分支B
 分支B侧可以ping通总部和分支A
在总部侧查看ike sa ipsec sa
<Headquarters>dis ike sa
    Connection-ID   Remote                Flag         DOI
    1               2.2.2.2               RD           IPsec
    2               3.3.3.2               RD           IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
<Headquarters>dis ipsec sa
Interface: GigabitEthernet0/0
  IPsec policy: test
  Sequence number: 1
  Mode: Template
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Path MTU: 1444
    Tunnel:
        local  address: 1.1.1.2
        remote address: 2.2.2.2
    Flow:
        sour addr: 192.168.1.0/255.255.255.0  port: 0  protocol: ip
        dest addr: 192.168.2.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 2857585848 (0xaa534cb8)
      Connection ID: 4294967296
      Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-MD5
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843148/3404
      Max received sequence-number: 390
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 1462782990 (0x57304c0e)
      Connection ID: 4294967298
      Max sent sequence-number: 390
      Status: Active
  IPsec policy: test
  Sequence number: 1
  Mode: Template
    Tunnel id: 1
    Inside VPN:
    Path MTU: 1444
    Tunnel:
    Flow:
        sour addr: 192.168.3.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 1741076224 (0x67c6b700)
      Connection ID: 4294967297
      SA remaining duration (kilobytes/sec): 1843095/3404
      Max received sequence-number: 790
      Status: Active
    [Outbound ESP SAs]
      SPI: 1031673059 (0x3d7e14e3)
      Connection ID: 4294967299
      Max sent sequence-number: 790
      Status: Active
  IPsec policy: test
  Sequence number: 2
  Mode: Template
    Tunnel id: 2
    Inside VPN:
    Path MTU: 1444
    Tunnel:
        remote address: 3.3.3.2
    Flow:
        dest addr: 192.168.3.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 3005711568 (0xb32784d0)
      Connection ID: 4294967300
      Status: Active
    [Outbound ESP SAs]
      SPI: 2370986263 (0x8d526117)
      Connection ID: 4294967302
      Status: Active
  IPsec policy: test
  Sequence number: 2
  Mode: Template
    Tunnel id: 3
    Inside VPN:
    Path MTU: 1444
    Tunnel:
    Flow:
        sour addr: 192.168.2.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 957577755 (0x39137a1b)
      Connection ID: 4294967301
      Status: Active
    [Outbound ESP SAs]
      SPI: 2955794011 (0xb02dd65b)
      Connection ID: 4294967303
      Status: Active
在分支A侧查看ike sa ipsec sa以及NQA相关信息
<branchA>dis ike sa
    1               1.1.1.2               RD           IPsec
Flags:
<branchA>dis ipsec sa
  IPsec policy: 1
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 1
    Inside VPN:
    Path MTU: 1444
    Tunnel:
        local  address: 2.2.2.2
        remote address: 1.1.1.2
    Flow:
    [Inbound ESP SAs]
      SA remaining duration (kilobytes/sec): 1843082/3379
      Max received sequence-number: 890
      Status: Active
    [Outbound ESP SAs]
      Max sent sequence-number: 890
      Status: Active
  IPsec policy: 1
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1444
    Tunnel:
    Flow:
        dest addr: 192.168.1.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SA remaining duration (kilobytes/sec): 1843141/3379
      Max received sequence-number: 440
      Status: Active
    [Outbound ESP SAs]
      Max sent sequence-number: 440
      Status: Active
<branchA>dis nqa result
NQA entry (admin admin, tag test) test results:
    Send operation times: 10             Receive response times: 10
    Min/Max/Average round trip time: 1/2/1
    Square-Sum of round trip time: 16
    Last succeeded probe time: 2020-01-01 20:59:48.9
  Extended results:
    Packet loss ratio: 0%
    Failures due to timeout: 0
    Failures due to internal error: 0
    Failures due to other errors: 0
NQA entry (admin admin, tag test1) test results:
    Min/Max/Average round trip time: 2/7/2
    Square-Sum of round trip time: 85
  Extended results:
<branchA>dis nqa statistics
NQA entry (admin admin, tag test) test statistics:
  NO. : 1
    Start time: 2020-01-01 20:55:03.8
    Life time: 313 seconds
    Send operation times: 630            Receive response times: 590
    Min/Max/Average round trip time: 1/3/1
    Square-Sum of round trip time: 867
  Extended results:
    Packet loss ratio: 6%
    Failures due to internal error: 10
    Failures due to other errors: 30
NQA entry (admin admin, tag test1) test statistics:
  NO. : 1
    Min/Max/Average round trip time: 1/7/1
    Square-Sum of round trip time: 2477
  Extended results:
<branchA>dis nqa history
NQA entry (admin admin, tag test) history records:
Index      Response     Status           Time
650        1            Succeeded        2020-01-01 21:00:23.9
649        2            Succeeded        2020-01-01 21:00:23.9
648        1            Succeeded        2020-01-01 21:00:23.9
647        1            Succeeded        2020-01-01 21:00:23.9
646        1            Succeeded        2020-01-01 21:00:23.8
645        1            Succeeded        2020-01-01 21:00:23.8
644        1            Succeeded        2020-01-01 21:00:23.8
643        1            Succeeded        2020-01-01 21:00:23.8
642        1            Succeeded        2020-01-01 21:00:23.8
641        1            Succeeded        2020-01-01 21:00:23.8
NQA entry (admin admin, tag test1) history records:
650        2            Succeeded        2020-01-01 21:00:23.9
648        2            Succeeded        2020-01-01 21:00:23.9
647        2            Succeeded        2020-01-01 21:00:23.9
646        2            Succeeded        2020-01-01 21:00:23.9
645        2            Succeeded        2020-01-01 21:00:23.9
644        2            Succeeded        2020-01-01 21:00:23.9
643        3            Succeeded        2020-01-01 21:00:23.8
641        2            Succeeded        2020-01-01 21:00:23.8
在分支B侧查看ike sa ipsec sa以及NQA相关信息
<branchB>dis ike sa
    1               1.1.1.2               RD           IPsec
Flags:
<branchB>dis ipsec sa
  IPsec policy: 1
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 1
    Inside VPN:
    Path MTU: 1444
    Tunnel:
        local  address: 3.3.3.2
    Flow:
    [Inbound ESP SAs]
      SA remaining duration (kilobytes/sec): 1843068/3353
      Max received sequence-number: 990
      Status: Active
    [Outbound ESP SAs]
      Max sent sequence-number: 990
      Status: Active
  IPsec policy: 1
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1444
    Tunnel:
    Flow:
    [Inbound ESP SAs]
      SA remaining duration (kilobytes/sec): 1843134/3353
      Max received sequence-number: 490
      Status: Active
    [Outbound ESP SAs]
      Max sent sequence-number: 490
      Status: Active
<branchB>dis nqa result
    Square-Sum of round trip time: 13
    Last succeeded probe time: 2020-01-01 21:00:34.3
  Extended results:
    Square-Sum of round trip time: 37
  Extended results:
<branchB>dis nqa statistics
  NO. : 1
    Start time: 2020-01-01 20:55:09.3
    Life time: 334 seconds
    Send operation times: 670            Receive response times: 640
    Square-Sum of round trip time: 917
  Extended results:
    Packet loss ratio: 4%
    Failures due to other errors: 20
  NO. : 1
    Min/Max/Average round trip time: 1/4/1
    Square-Sum of round trip time: 2551
  Extended results:
<branchB>dis nqa history
690        1            Succeeded        2020-01-01 21:00:49.3
689        2            Succeeded        2020-01-01 21:00:49.3
688        1            Succeeded        2020-01-01 21:00:49.3
687        1            Succeeded        2020-01-01 21:00:49.3
686        1            Succeeded        2020-01-01 21:00:49.3
685        1            Succeeded        2020-01-01 21:00:49.3
684        1            Succeeded        2020-01-01 21:00:49.3
683        1            Succeeded        2020-01-01 21:00:49.3
682        1            Succeeded        2020-01-01 21:00:49.3
681        2            Succeeded        2020-01-01 21:00:49.3
690        2            Succeeded        2020-01-01 21:00:49.3
688        2            Succeeded        2020-01-01 21:00:49.3
687        2            Succeeded        2020-01-01 21:00:49.3
686        2            Succeeded        2020-01-01 21:00:49.3
685        3            Succeeded        2020-01-01 21:00:49.3
684        2            Succeeded        2020-01-01 21:00:49.3
682        2            Succeeded        2020-01-01 21:00:49.3
