H3C M9006防火墙NSQM1FWDFGD1板卡升级版本问题
2023-06-16提问
  • 0收藏,681浏览
H3C M9006防火墙NSQM1FWDFGD1板卡TF卡损坏,更换TF卡上传软件镜像提示:Something wrong with the file 请问是什么原因?谢谢!
粉丝:13人 关注:0人
文件错误,看下是版本问题还是命名问题
大概率是文件下错了
https://www.h3c.com/cn/d_202208/1672737_30005_40.htm
官网下个最新的
溜溜溜 发表时间:2023-06-16
您好!用读卡器拷贝上去后提示如下:BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Loading the main image files... The image does not exist! Loading the backup image files... The image does not exist! Loading images fails. Loading the main boot and system image files... The system image does not exist! Loading the backup boot and system image files... The image does not exist! Loading images fails. Loading the main boot image... Loading file sda0:/BLADE4FWM9000-CMW710-BOOT-R9131P33.bin.....Done. Image file sda0:/BLADE4FWM9000-CMW710-BOOT-R9131P33.bin is self-decompressing.....Done. System image is starting... [4294677.400000] Please check your application, maybe need rebuilding! [4294677.475000] Now switch to default ... /bin/sh: can't access tty; job control turned off #
zhiliao_dUz2yG 发表时间:2023-06-16
您能提供这个版本的下载链接吗?BLADE4FWM9000-CMW710-BOOT-R9131P33.bin
这个版本官网已经没了,得联系当地办事处要一下
溜溜溜 发表时间:2023-06-16
感谢您的支持,已经修复
您好!H3C M9006防火墙IRF成员能命令进行主备切换吗?命令是?
没这个命令,如果切换的话,只能改优先级,然后主设备重启
溜溜溜 发表时间:2023-06-16
好的,谢谢您!
zhiliao_dUz2yG 知了小白
文件是从另外一台好的相同设备上拷贝的
