4320胖ap当路由器
2023-07-01提问
  • 0收藏,396浏览
配置后直接ping无线ap有延迟大和丢包
光猫—poe网关交换机(无配置)—下挂2个4320胖ap
粉丝:13人 关注:9人
下挂一个是否丢包,考虑是否AP有信道干扰?
****************************************************************************** * Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.* * Without the owner's prior written consent, * * no decompiling or reverse-engineering shall be allowed. * ****************************************************************************** Login authentication Username:admin Password: dis cu # version 5.20, Release 1509P01 # sysname WA4320-ACN-SI # domain default enable system # telnet server enable # undo wlan-client-isolation enable # port-security enable # password-recovery enable # undo attack-defense tcp fragment enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # dhcp server ip-pool 1 network 192.168.1.0 mask 255.255.255.0 expired unlimited # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$65bNVTVNFktCJgHBGpqOwblc7PlrhDDhj2lB07Q= authorization-attribute level 3 service-type telnet service-type web # wlan rrm dot11a mandatory-rate 6 12 24 dot11a supported-rate 9 18 36 48 54 dot11b mandatory-rate 1 2 dot11b supported-rate 5.5 11 dot11g mandatory-rate 1 2 5.5 11 dot11g supported-rate 6 9 12 18 24 36 48 54 # wlan service-template 1 clear ssid H3C # wlan service-template 2 crypto ssid WFKQ cipher-suite tkip cipher-suite ccmp security-ie rsn security-ie wpa service-template enable # cwmp undo cwmp enable # interface NULL0 # interface Vlan-interface1 ip address 192.168.1.200 255.255.255.0 # interface GigabitEthernet1/0/1 port link-type hybrid port hybrid vlan 1 untagged # interface WLAN-BSS32 port link-type hybrid port hybrid vlan 1 untagged # interface WLAN-BSS33 port link-type hybrid port hybrid vlan 1 untagged # interface WLAN-BSS34 port link-type hybrid port hybrid vlan 1 untagged port-security port-mode psk
小白一串 发表时间:2023-07-01
一个也有丢包
回复小白一串:
直接接终端是否丢包?不接AP
太平洋宽带安装 发表时间:2023-07-01
粉丝:31人 关注:4人
胖ap 使用nat 模式 影响ap 性能
建议使用bridge 模式
由上行设备负责分配地址,和路由转发;ap只负责无线接入;
如果使用nat 路由模式;
终端到网关丢包严重;
首先确认是连接的2.4G 还是5G,
建议更换一下信道在测试,适担当调整一下ap发射功率;
建议2.4G 频宽 20MHZ  5G 频宽建议设置为40MHZ
加密方式选择  AES  wpa2  ,不要选择tkip ,tkip只能协商到54M;
