如果要映射几千各端口出去,该怎么写呀
比如第一段 4000-5000号端口
第二段 12000-13757号端口
出口是一台 F1000-ak
(0)
外网地址单一,外网端口连续。
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
(0)
单一我知道,批量怎么弄
您好,参考命令
nat server protocol tcp global 1.1.1.1 15000 17000 inside 2.2.2.2 15000 17000
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
