msr26-00 配置无法上网,请指导
2023-07-24提问
  • 0收藏,436浏览
 version 5.20, Release 2516P28
 sysname H3C
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control password update interval 0
 password-control login idle-time 0
 password-control complexity user-name check
 domain default enable system
 dar p2p signature-file flash:/p2p_default.mtd
 port-security enable
 password-recovery enable
vlan 1
 vlan 8
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan1 extended
 network ip range 192.168.2.100 192.168.2.199
 network mask 255.255.254.0
 gateway-list 192.168.2.1
 dns-list 192.168.2.1
dhcp server ip-pool vlan8 extended
 network ip range 192.168.0.100 192.168.0.200
 gateway-list 192.168.0.1
 dns-list 192.168.0.1
user-group system group-attribute allow-guest
 local-user admin
 authorization-attribute level 3
 service-type web
cwmp
 undo cwmp enable
interface Aux0
 async mode flow
 link-protocol ppp
 interface Cellular0/0
 async mode protocol
 link-protocol ppp
 interface NULL0
interface Vlan-interface1
 ip address 192.168.2.1 255.255.254.0
 dhcp server apply ip-pool vlan1
 interface Vlan-interface8
 ip address 192.168.0.1 255.255.254.0
 dhcp server apply ip-pool vlan8
 interface GigabitEthernet0/0
 port link-mode route
 ip address dhcp-alloc
 interface GigabitEthernet0/1
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
 port access vlan 8
interface GigabitEthernet0/4
 port access vlan 8
interface GigabitEthernet0/5
 port access vlan 8
interface GigabitEthernet0/6
 port access vlan 8
interface GigabitEthernet0/7
 port access vlan 8
 interface GigabitEthernet0/8
 port access vlan 8
interface GigabitEthernet0/9
 port access vlan 8
 dhcp enable
 load xml-configuration
load tr069-configuration
 user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
粉丝:46人 关注:1人
看了你的配置,1、你没有配置路由,2、你没有配置外网口的NAT outbound
谢谢回复,辛苦了,我刚把回车打完,没想到10分钟前就回答了,我在g0/0写了NEToutbound, 现在不能访问网址,这有默认路由,具体是哪个没写,请赐教
白小小白 发表时间:2023-07-24
回复白小小白:
g0/0 是外网口对么,dis ip int br 看一下获取到IP地址了么?
zhiliao_h907dg 发表时间:2023-07-24
回复白小小白:
int g0/0 nat outb 把这个命令位置上
回复白小小白:
没看到你的的路由配置啊,正常有个ip route 0.0.0.0 0.0.0.0 指向网关地址
默认路由获取上就有了,我dhcp写的dns是网关,是不是还得点儿什么让dns去找上级路由分配的dns,谢谢
白小小白 知了小白
