WT1024-X-Q S6520X-54QC-EI AP上线失败,接口UP DOWN跳
  • 0收藏,729浏览
AC WX5540-X 旁挂核心,下联对接汇聚交换机S6520X-54QC-EI,汇聚交换机连接13台WT1024-X-Q设备,汇聚交换机对接WT设备接口UP DOWN跳,如果在AC上手动上线 只有一部分(7个)可以上线成功,剩下的上线失败,并且上线失败的WT对接汇聚交换机切口全部为down,并且指示灯灭。这种AP要如何上线,请求大神指点
报错日志
eb 14 02:56:01:717 2021 3#huiju IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/29 changed to down. %Feb 14 02:56:01:718 2021 3#huiju IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/29 changed to down. %Feb 14 02:56:05:293 2021 3#huiju IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/31 changed to down. %Feb 14 02:56:05:295 2021 3#huiju IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/31 changed to down. %Feb 14 02:56:05:302 2021 3#huiju LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on port Ten-GigabitEthernet1/0/31 (IfIndex 31), neighbor's chassis ID is 7c7a-3c1a-f82a, port ID is Ten-GigabitEthernet1/0/1. %Feb 14 02:56:08:245 2021 3#huiju IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/28 changed to up. %Feb 14 02:56:08:251 2021 3#huiju IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/28 changed to up. %Feb 14 02:56:08:257 2021 3#huiju LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on Ten-GigabitEthernet1/0/28 (PVID 43), with 3-11F-WT-02 Ten-GigabitEthernet1/0/1 (PVID 1). %Feb 14 02:56:08:257 2021 3#huiju LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/28 (IfIndex 28), neighbor's chassis ID is 7c7a-3c1a-f5f2, port ID is Ten-GigabitEthernet1/0/1. %Feb 14 02:56:13:182 2021 3#huiju IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/33 changed to up. %Feb 14 02:56:13:188 2021 3#huiju IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/33 changed to up. %Feb 14 02:56:15:994 2021 3#huiju LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on Ten-GigabitEthernet1/0/33 (PVID 43), with 3#-15F-WT-01 Ten-GigabitEthernet1/0/1 (PVID 1). %Feb 14 02:56:15:994 2021 3#huiju LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/33 (IfIndex 33), neighbor's chassis ID is 7c7a-3c1a-f792, port ID is Ten-GigabitEthernet1/0/1. %Feb 14 02:56:19:659 2021 3#huiju LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on port Ten-GigabitEthernet1/0/30 (IfIndex 30), neighbor's chassis ID is 7c7a-3c1a-f51e, port ID is Ten-GigabitEthernet1/0/1. %Feb 14 02:56:19:663 2021 3#huiju IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/30 changed to down. %Feb 14 02:56:19:664 2021 3#huiju IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/30 changed to down. %Feb 14 02:56:21:507 2021 3#huiju IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/37 changed to down. %Feb 14 02:56:21:508 2021 3#huiju IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/37 changed to down. %Feb 14 02:56:21:509 2021 3#huiju LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on port Ten-GigabitEthernet1/0/37 (IfIndex 37), neighbor's chassis ID is 7c7a-3c1a-f8ae, port ID is Ten-GigabitEthernet1/0/1.
winter 九段
粉丝:50人 关注:18人
需要通过替换测试看故障是跟着交换机走还是跟着AP走,判断是哪里的故障
粉丝:1人 关注:2人
你这是汇聚交换机的光端口UP DOWN
先看下汇聚交换机到本体的光链路有没有问题,看下光衰有多大,以及接口的错包
用汇聚交换机加原地址ping本体的地址,看有没有丢包
