S7506X-S中的业务广播设备无法正常上线
2023-08-11提问
  • 0收藏,712浏览
①同网段两台广播设备的ttl值不一样
②业务时通时不通
③软件版本已经升级,问题还是存在
④备机有一个口存在root端口,检查线路也没有问题
组网配置如下
核心1:
igmp-snooping
 global-enable
vlan 150
 igmp-snooping enable
 igmp-snooping querier
vlan 3134
 description --ZNHSB--
stp region-configuration
 region-name h3c
 instance 1 vlan 150 3134
 active region-configuration
 stp instance 1 root primary
 stp global enable
interface Bridge-Aggregation1
 description toHX2
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
 stp instance 1 cost 2000
interface Vlan-interface102
 ip address 192.168.102.1 255.255.255.0
 pim sm
 igmp enable
interface Vlan-interface150
 description --guangbo--
 ip address 192.168.150.2 255.255.255.0
 pim sm
 igmp enable
 vrrp vrid 150 virtual-ip 192.168.150.1
 vrrp vrid 150 priority 110
 vrrp vrid 150 preempt-mode delay 500
interface Vlan-interface3134
 description --ZNHZW--
 ip address 172.30.134.2 255.255.254.0
 pim sm
 igmp enable
 vrrp vrid 10 virtual-ip 172.30.134.1
 vrrp vrid 10 priority 110
 vrrp vrid 10 preempt-mode delay 500
核心2:
igmp-snooping
 global-enable
vlan 102
 description --SBGL--
vlan 150
vlan 3134
 region-name h3c
 stp instance 1 root secondary
 stp global enable
 description toHX1
 ip address 192.168.102.2 255.255.255.0
 pim sm
 igmp enable
 ip address 192.168.150.3 255.255.255.0
 pim sm
 igmp enable
 ip address 172.30.134.3 255.255.254.0
 pim sm
 igmp enable
接入配置:
 region-name h3c
stp global enable
stp bpdu-protection
粉丝:3人 关注:1人
有问题的时候看起来ping都不通了,看看是不是组播源出问题了?
也可以看看mac表、igmp表项啥的是否都在吧
时而在备上面
zhiliao_4MMuPO 发表时间:2023-08-11
