packet-capture特性包
2023-08-17提问
  • 0收藏,708浏览
packet-capture交换机报文捕获特性包怎么安装?用什么命令?
粉丝:111人 关注:1人
 安装Packet Capture特性软件包,以便用户可以配置特性包报文捕获功能
# 查看设备的版本信息,准备和设备当前运行的Boot包、System包兼容的Packet Capture特性软件包。
<Device> display version
H3C Comware Software, Version 7.1.070, Demo 01
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.
H3C XXX uptime is 0 weeks, 0 days, 5 hours, 33 minutes
Last reboot reason : Cold reboot
Boot image: flash:/boot-01.bin
Boot image version: 7.1.070, Demo 01
  Compiled Oct 20 2019 16:00:00
System image: flash:/system-01.bin
System image version: 7.1.070, Demo 01
其它显示信息略……。
# 从IP地址为192.168.1.1的TFTP服务器上下载Packet Capture特性软件包packet-capture-01.bin。
<Device> tftp 192.168.1.1 get packet-capture-01.bin
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 11.3M    0 11.3M    0     0   155k      0 --:--:--  0:01:14 --:--:--  194k
Writing file...Done.
# 给IRF中的所有成员设备(此处以slot 1和slot 2为例)都安装Packet Capture特性软件包,并让该软件包在设备重启后能够继续生效。
<Device> install activate feature flash:/packet-capture-01.bin slot 1
Verifying the file flash:/packet-capture-01.bin on slot 1....Done.
Identifying the upgrade methods....Done.
  Running Version             New Version
  None                        Demo 01
  Slot                        Upgrade Way
  1                           Service Upgrade
This operation might take several minutes, please wait....................Done.
<Device> install activate feature flash:/packet-capture-01.bin slot 2
Verifying the file flash:/packet-capture-01.bin on slot 2....Done.
  None                        Demo 01
  Slot                        Upgrade Way
  2                           Service Upgrade
<Device> install commit
This operation will take several minutes, please wait.......................Done.
# 重新登录设备,以便用户能够执行packet-capture interface和packet-capture read命令行。
(2)     在接口Ten-GigabitEthernet1/0/1的入方向上应用QoS策略,用来限制只捕获192.168.1.10到192.168.1.1、192.168.1.11到192.168.1.1的硬件转发报文。
# 创建IPv4高级ACL 3000,用来匹配192.168.1.10到192.168.1.1、192.168.1.11到192.168.1.1的报文。
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule permit ip source 192.168.1.10 0 destination 192.168.1.1 0
[Device-acl-ipv4-adv-3000] rule permit ip source 192.168.1.11 0 destination 192.168.1.1 0
# 定义流行为behavior1,配置流量镜向到CPU。
[Device] traffic behavior behavior1
[Device-behavior-behavior1] mirror-to cpu
[Device-behavior-behavior1] quit
# 定义类classifier1,匹配ACL3000。
[Device] traffic classifier classifier1
[Device-classifier-class1] if-match acl 3000
[Device-classifier-class1] quit
# 定义一个名为user1的策略,并在策略user1中为类classifier1指定采用流行为behavior1。
[Device] qos policy user1
[Device-qospolicy-user1] classifier classifier1 behavior behavior1
[Device-qospolicy-user1] quit
# 将策略user1应用到接口Ten-GigabitEthernet1/0/1的入方向上。
[Device-Ten-GigabitEthernet1/0/1] qos apply policy user1 inbound
[Device] quit
(3)     开启报文捕获功能
# 开启Ten-GigabitEthernet1/0/1接口上的报文捕获功能,指定捕获报文个数上限为10,指定捕获的报文存入文件a.pcap。在192.168.1.10上使用Telnet方式登录192.168.1.1,创造报文捕获条件。
<Device> packet-capture interface ten-gigabitethernet 1/0/1 capture-filter "vlan 3 and src 192.168.1.10 or 192.168.1.11 and dst 192.168.1.1" limit-captured-frames 10 write flash:/a.pcap
Capturing on 'Ten-GigabitEthernet1/0/1'
粉丝:144人 关注:0人
您好,使用install active 安装
