H3C F100-C-G5二层透传后导致VPN业务不正常
2023-08-18提问
  • 0收藏,642浏览
现场原架构是网关、出口、VPN、DHCP等三层配置都跑在路由器上的,原环境一切正常,需在路由器下面增加一台防火墙做二层透传,以及增加一台交换机,但增加防火墙后,客户端上网正常,但是与分支的VPN业务不正常,出现了 分支可访问总部,总部访问不到分支的情况。
组网:路由器配置一直在使用的 一切正常,更改切换后网关 VPN等配置都跑在路由器上,不变,只增加一台二层透明模式防火墙,以及一台交换机,交换机配置为一个管理地址,以及默认路由,上行24口为trunk。
(附带我的防火墙配置)
粉丝:12人 关注:4人
理论上纯二层防火墙+放行策略不会对业务进行拦截,试试跳过防火墙,路由器直连交换机试试
好的好的 我尝试下
zhiliao_jJqqOE 发表时间:2023-08-18
zhiliao_jJqqOE 知了小白
此配置为我的防火墙配置:
[F100-C-G5]display current-configuration
version 7.1.064, Release 9560P33
sysname F100-C-G5
clock protocol none
context Admin id 1
ip vpn-instance MGT
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
dns server 8.8.8.8
dns server 114.114.114.114
lldp global enable
password-recovery enable
vlan 1
vlan 2 to 3
controller Cellular1/0/0
controller Cellular1/0/1
interface NULL0
interface Vlan-interface1
interface GigabitEthernet1/0/0
port link-mode route
combo enable fiber
combo enable fiber
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/11
description for MGT
ip binding vpn-instance MGT
ip address 192.0.0.250 255.255.255.0
port link-mode bridge
port link-type trunk
port trunk permit vlan all
interface GigabitEthernet1/0/4
description to sanfor
interface GigabitEthernet1/0/5
description to ER
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
description to ER
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
security-zone name Local
security-zone name Trust
import interface GigabitEthernet1/0/4 vlan 1 to 4094
import interface GigabitEthernet1/0/6 vlan 1 to 4094
import interface GigabitEthernet1/0/10 vlan 1 to 4094
import vlan 1 to 3
security-zone name DMZ
security-zone name Untrust
import interface GigabitEthernet1/0/5 vlan 1 to 4094
import interface GigabitEthernet1/0/7 vlan 1 to 4094
security-zone name Management
import interface GigabitEthernet1/0/11
zone-pair security source Any destination Any
packet-filter 3200
scheduler logfile size 16
line class aux
user-role network-operator
line class console
authentication-mode scheme
user-role network-admin
line class vty
line aux 0
line con 0
line vty 0 63
ip route-static vpn-instance MGT 0.0.0.0 0 192.0.0.1
undo info-center enable
performance-management
ssh server enable
arp static 192.0.0.3 0011-327b-b4c4
arp static 192.0.0.50 1418-7758-a694
arp static 192.0.0.51 c85b-7692-d741
arp static 192.0.0.52 eca8-6b82-0c1f
arp static 192.0.0.53 309c-232e-f4f9
arp static 192.0.0.54 4437-e64a-3629
arp static 192.0.0.55 d8cb-8abd-1175
arp static 192.0.0.57 d8cb-8abd-1fd4
arp static 192.0.0.58 90fb-a67b-1801
arp static 192.0.0.59 1cc1-de56-9405
arp static 192.0.0.60 14da-e9ca-4ef0
arp static 192.0.0.61 28d2-4433-19d1
arp static 192.0.0.86 7844-fde1-0100
arp static 192.0.0.93 b870-f42a-676a
arp static 192.0.0.94 507b-9d3d-6b31
arp static 192.0.0.95 6c4b-9028-0c4d
arp static 192.0.0.97 309c-232f-ac6a
arp static 192.0.0.98 4ccc-6a1c-ba6c
arp static 192.0.0.99 00e0-4c36-05e2
arp static 192.0.0.113 0017-c890-8a6b
arp static 192.0.0.115 0017-c890-8a5e
arp static 192.0.0.116 0047-5029-b11a
arp static 192.0.0.118 0007-4d9f-5b06
arp static 192.0.0.167 0007-4d92-c8b9
arp static 192.0.0.175 c025-a57f-aa08
arp static 192.0.0.245 8cec-4ba7-07c1
arp static 192.168.0.2 b82a-72dc-02ef
arp static 192.168.0.3 0011-327b-b4c4
arp static 192.168.0.48 1418-7758-a693
arp static 192.168.21.26 0007-4d9f-5b06
arp static 192.168.21.27 0017-c890-8a6b
arp static 192.168.21.28 489e-bdef-45bf
acl advanced 3200
rule 100 permit ip
undo password-control blacklist all-line
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash $h$6$c4P9kF64FqeScnym$usL23+3rOd7w67vXH8VBhTfrv+KgmSSLecix3/zBarCvB3YZxr82yPqoATrdV2kIuubhokKhVNpIgBZKjusPnQ==
service-type ssh telnet terminal http https
authorization-attribute user-role level-15
ssl renegotiation disable
ssl version ssl3.0 disable
ssl version tls1.0 disable
ipsec logging negotiation enable
ike identity fqdn test
ike logging negotiation enable
ip http enable
ip https enable
loadbalance isp file flash:/lbispinfo_v1.5.tp
security-policy ip
rule 0 name any
action pass
rule 10 name pass
action pass
source-zone Trust
source-zone Local
source-zone Untrust
source-zone Management
destination-zone Local
destination-zone Trust
destination-zone Untrust
rule 20 name 30
action pass
cloud-management server domain opstunnel-seccloud.h3c.com
return
[F100-C-G5]
粉丝:14人 关注:0人
没有大的问题,再看看路由器和交换机配置呢
