R4900 G3磁盘大量爆出missing问题如何解决
2023-08-21提问
  • 0收藏,681浏览
报错信息如下:
3899         Informational        NA   NA   NA   From BMC       2023-08-05 04:08:48      ENGINEER         PDIndex(Front:13)----Unexpected sense: PD 1f(e8/s13) Path 5000c500bd4135a1, CDB: 2f 00 43 78 fd 99 00 10 00 00, Sense: 3/00/07
3900         Warning         NA   NA   NA   From BMC       2023-08-05 04:08:48      ENGINEER         Uncorrectable medium error logged for VD 0e/d at 4378fd99 (on (null) at b0d14cb0)---CtrlIndex(2)
Device ID                               : 31
Slot                                    : Front 13
BIOS Number                             : 13
Status                                  : Online
Transfer Speed                          : 12 Gbps
Type                                    : SAS HDD
Vendor & ProductID                      : SEAGATE ST1800MM0129
Firmware Version                        : C003
Serial Number                           : WBN1HQ23
Capacity                                : 1.64TiB
Temperature                             : 28
//更换前部丝印为13的硬盘
3921         Warning         Drive Slot (Bay)       HDD_F19_Status     Assertion event       From BMC         2023-08-07 22:52:57      CUSTOMER     The disk is missing
3922         Warning         Drive Slot (Bay)       HDD_F19_Status     Assertion event       From BMC         2023-08-07 22:52:57      CUSTOMER     Drive fault
3923         Warning         Drive Slot (Bay)       HDD_F20_Status     Assertion event       From BMC         2023-08-07 22:52:58      CUSTOMER     The disk is missing
3924         Warning         Drive Slot (Bay)       HDD_F20_Status     Assertion event       From BMC         2023-08-07 22:52:58      CUSTOMER     Drive fault
3925         Warning         Drive Slot (Bay)       HDD_F00_Status     Assertion event       From BMC         2023-08-07 22:53:00      CUSTOMER     The disk is missing
3926         Warning         Drive Slot (Bay)       HDD_F00_Status     Assertion event       From BMC         2023-08-07 22:53:00      CUSTOMER     Drive fault
3927         Warning         Drive Slot (Bay)       HDD_F01_Status     Assertion event       From BMC         2023-08-07 22:53:00      CUSTOMER     The disk is missing
3928         Warning         Drive Slot (Bay)       HDD_F01_Status     Assertion event       From BMC         2023-08-07 22:53:01      CUSTOMER     Drive fault
3929         Warning         Drive Slot (Bay)       HDD_F02_Status     Assertion event       From BMC         2023-08-07 22:53:01      CUSTOMER     The disk is missing
3930         Warning         Drive Slot (Bay)       HDD_F02_Status     Assertion event       From BMC         2023-08-07 22:53:02      CUSTOMER     Drive fault
3931         Warning         Drive Slot (Bay)       HDD_F03_Status     Assertion event       From BMC         2023-08-07 22:53:02      CUSTOMER     The disk is missing
3932         Warning         Drive Slot (Bay)       HDD_F03_Status     Assertion event       From BMC         2023-08-07 22:53:03      CUSTOMER     Drive fault
3933         Warning         Drive Slot (Bay)       HDD_F04_Status     Assertion event       From BMC         2023-08-07 22:53:03      CUSTOMER     The disk is missing
3934         Warning         Drive Slot (Bay)       HDD_F04_Status     Assertion event       From BMC         2023-08-07 22:53:03      CUSTOMER     Drive fault
3935         Warning         Drive Slot (Bay)       HDD_F05_Status     Assertion event       From BMC         2023-08-07 22:53:04      CUSTOMER     The disk is missing
3936         Warning         Drive Slot (Bay)       HDD_F05_Status     Assertion event       From BMC         2023-08-07 22:53:05      CUSTOMER     Drive fault
3937         Warning         Drive Slot (Bay)       HDD_F06_Status     Assertion event       From BMC         2023-08-07 22:53:05      CUSTOMER     The disk is missing
3938         Warning         Drive Slot (Bay)       HDD_F06_Status     Assertion event       From BMC         2023-08-07 22:53:06      CUSTOMER     Drive fault
3939         Warning         Drive Slot (Bay)       HDD_F07_Status     Assertion event       From BMC         2023-08-07 22:53:06      CUSTOMER     The disk is missing
3940         Warning         Drive Slot (Bay)       HDD_F07_Status     Assertion event       From BMC         2023-08-07 22:53:07      CUSTOMER     Drive fault
3941         Warning         Drive Slot (Bay)       HDD_F08_Status     Assertion event       From BMC         2023-08-07 22:53:07      CUSTOMER     The disk is missing
3942         Warning         Drive Slot (Bay)       HDD_F08_Status     Assertion event       From BMC         2023-08-07 22:53:07      CUSTOMER     Drive fault
3943         Warning         Drive Slot (Bay)       HDD_F09_Status     Assertion event       From BMC         2023-08-07 22:53:08      CUSTOMER     The disk is missing
3944         Warning         Drive Slot (Bay)       HDD_F09_Status     Assertion event       From BMC         2023-08-07 22:53:08      CUSTOMER     Drive fault
3945         Warning         Drive Slot (Bay)       HDD_F10_Status     Assertion event       From BMC         2023-08-07 22:53:09      CUSTOMER     The disk is missing
3946         Warning         Drive Slot (Bay)       HDD_F10_Status     Assertion event       From BMC         2023-08-07 22:53:09      CUSTOMER     Drive fault
3947         Warning         Drive Slot (Bay)       HDD_F11_Status     Assertion event       From BMC         2023-08-07 22:53:10      CUSTOMER     The disk is missing
3948         Warning         Drive Slot (Bay)       HDD_F11_Status     Assertion event       From BMC         2023-08-07 22:53:10      CUSTOMER     Drive fault
3949         Warning         Drive Slot (Bay)       HDD_F12_Status     Assertion event       From BMC         2023-08-07 22:53:11      CUSTOMER     The disk is missing
3950         Warning         Drive Slot (Bay)       HDD_F12_Status     Assertion event       From BMC         2023-08-07 22:53:11      CUSTOMER     Drive fault
3951         Warning         Drive Slot (Bay)       HDD_F13_Status     Assertion event       From BMC         2023-08-07 22:53:11      CUSTOMER     The disk is missing
3952         Warning         Drive Slot (Bay)       HDD_F13_Status     Assertion event       From BMC         2023-08-07 22:53:12      CUSTOMER     Drive fault
3953         Warning         Drive Slot (Bay)       HDD_F14_Status     Assertion event       From BMC         2023-08-07 22:53:12      CUSTOMER     The disk is missing
3954         Warning         Drive Slot (Bay)       HDD_F14_Status     Assertion event       From BMC         2023-08-07 22:53:13      CUSTOMER     Drive fault
3955         Warning         Drive Slot (Bay)       HDD_F15_Status     Assertion event       From BMC         2023-08-07 22:53:13      CUSTOMER     The disk is missing
3956         Warning         Drive Slot (Bay)       HDD_F15_Status     Assertion event       From BMC         2023-08-07 22:53:13      CUSTOMER     Drive fault
3957         Warning         Drive Slot (Bay)       HDD_F16_Status     Assertion event       From BMC         2023-08-07 22:53:14      CUSTOMER     The disk is missing
3958         Warning         Drive Slot (Bay)       HDD_F16_Status     Assertion event       From BMC         2023-08-07 22:53:14      CUSTOMER     Drive fault
3959         Warning         Drive Slot (Bay)       HDD_F17_Status     Assertion event       From BMC         2023-08-07 22:53:15      CUSTOMER     The disk is missing
3960         Warning         Drive Slot (Bay)       HDD_F17_Status     Assertion event       From BMC         2023-08-07 22:53:15      CUSTOMER     Drive fault
3961         Warning         Drive Slot (Bay)       HDD_F18_Status     Assertion event       From BMC         2023-08-07 22:53:16      CUSTOMER     The disk is missing
3962         Warning         Drive Slot (Bay)       HDD_F18_Status     Assertion event       From BMC         2023-08-07 22:53:16      CUSTOMER     Drive fault
阵列卡固件为: 4.680.00-8249
EXP固件为:2.00.04
阵列卡为:lsi-9381-8!
求一份修复说明
7 个回答
z6Kl9 九段
粉丝:67人 关注:2人
抓取日志,反馈400
粉丝:4人 关注:2人
机器过保了吗?怎么不给二线,让二线分析呢。你在管理口下是什么报错啊
粉丝:16人 关注:9人
建议收集SDS日志联系400报修,看日志情况应该是HDM老版本的已知问题,可以报修确认下,或直接升级至官网最新版本后重置HDM观察。
Deft 四段
建议您把硬盘固件从C003升级到C0E4版本
1、建议收集日志,并根据最近几天日志进行详细分析
2、分析不明白的话拨打400
粉丝:6人 关注:7人
您好,这边建议您将硬盘固件版本升级为C0E4,在不影响业务的情况下重启即可
粉丝:1人 关注:1人
首先看型号:是希捷的。有公告显示:
解决方案:
如果发生时间比较长,也可以进行更换硬盘。固件升级到CE04以上。
