路由器 如何实现电脑内网同时访问外网及总部内网服务器。
  • 1收藏,3118浏览
H3C 同一台路由如何实现同时上内外网(两个内网专线地址段为10.17.123.0 网关10.17 .123.254与10.17.124.0  网关10.17.124.254)另外一台连接外网的路由地址为192.1.1.254
目前两个内网地址不能互通 ,外网的路由只能访问本地的10.17.123.0段的地址,请问如何能实现配置的10.17.124.0段地址的电脑可以同时访问内外网。
电脑配置为192段外网地址只能ping本地10.17.123.0网段,无法访问总部的各个项目的服务器。
两台路由配置如下:
                                请大神帮忙修改一下配置。
内网路由
 version 5.20, Release 2511P02
 sysname JS-DX
 undo password-control aging enable
 firewall enable
 domain default enable system
 router id 10.17.112.86  上级公司专线分配地址
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 port-security enable
 password-recovery enable
acl number 3000
 rule 0 permit ip destination 192.168.100.0 0.0.0.255
 rule 5 permit ip destination 192.168.118.0 0.0.0.255
 rule 10 permit ip destination 192.168.122.0 0.0.0.255
 rule 15 permit ip
acl number 3001
 rule 0 deny ip destination 192.168.100.0 0.0.0.255
 rule 5 deny ip destination 192.168.118.0 0.0.0.255
 rule 10 deny ip destination 192.168.122.0 0.0.0.255
 rule 15 permit ip
acl number 3602
 rule 0 permit ip source 10.104.249.65 0
 rule 5 permit ip source 10.104.254.101 0
 rule 10 permit ip source 10.104.249.143 0
 rule 15 permit ip destination 10.104.249.65 0
 rule 20 permit ip destination 10.104.254.101 0
 rule 25 permit ip destination 10.104.249.143 0
 rule 30 permit ip source 10.104.254.11 0
 rule 35 permit ip destination 10.104.254.11 0
acl number 3608
 rule 0 deny ip source 10.104.249.65 0
 rule 5 deny ip source 10.104.254.101 0
 rule 10 deny ip source 10.104.249.143 0
 rule 15 deny ip destination 10.104.249.65 0
 rule 20 deny ip destination 10.104.254.101 0
 rule 25 deny ip destination 10.104.249.143 0
 rule 30 deny ip source 10.104.254.11 0
 rule 35 deny ip destination 10.104.254.11 0
acl number 4999
 rule 1 permit
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
traffic classifier others operator and
 if-match acl 3001
traffic classifier pos&sap operator and
 if-match acl 3000
traffic classifier acl3980deny operator or
 if-match acl 3980
traffic behavior others
 queue af bandwidth 6000
traffic behavior pos&sap
 queue af bandwidth 4000
traffic behavior acldeny
 filter deny
qos policy pos&sap
 classifier pos&sap behavior pos&sap
 classifier others behavior others
qos policy PolicyLimit
user-group system
 group-attribute allow-guest
local-user JS-DX
local-user LYGXXB
 password cipher ************
 authorization-attribute level 3
 service-type ssh telnet
 service-type web
local-user admin
 password cipher ***************
 service-type web
 password-control length 4
 password-control composition type-number 1
local-user user
cwmp
 undo cwmp enable
controller E1 0/0
 using e1
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 qos apply policy PolicyLimit outbound
 firewall packet-filter 4999 outbound
interface Ethernet0/0
 port link-mode route
 ip address 10.17.123.253 255.255.255.0
 ip address 10.17.124.253 255.255.255.128 sub
 ospf cost 1000
 vrrp vrid 1 virtual-ip 10.17.123.254
 vrrp vrid 1 priority 120
 vrrp vrid 1 preempt-mode timer delay 2
 vrrp vrid 2 virtual-ip 10.17.124.254
 vrrp vrid 2 priority 120
 vrrp vrid 2 preempt-mode timer delay 2
interface Ethernet0/1
 ip address 10.17.112.86 255.255.255.252    上级公司专线分配地址
 ospf network-type broadcast
 ip netstream inbound
 ip netstream outbound
 undo ip fast-forwarding
 ip flow-ordering internal
interface Ethernet0/2
 qos max-bandwidth 5120
 ospf network-type p2p
 qos flow-interval 1
interface Serial0/0:0
 link-protocol ppp
 qos flow-interval 1
interface NULL0
interface Vlan-interface1
interface Ethernet0/3
 port link-mode bridge
interface Ethernet0/4
ospf 100
 peer 10.17.112.85     上级公司专线分配地址
 area 0.0.2.5
  network 10.17.112.84 0.0.0.3
  network 10.17.123.0 0.0.0.255
  network 10.17.124.0 0.0.0.255
  nssa
voice-setup
 sip
 sip-server
  call-rule-set
  call-route
 dial-program
 aaa-client
 gk-client
 snmp-agent
 snmp-agent local-engineid 800063A20370F96D1A8D7E
 snmp-agent community read yunshang1
 snmp-agent sys-info version v2c
 ip netstream export host 192.168.132.142 2055
 ip netstream export source interface Ethernet0/1
 ntp-service unicast-server 192.168.132.201
 ssh server enable
 ssh server authentication-timeout 30
 ssh user admin service-type stelnet authentication-type password
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
 authentication-mode password
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
 idle-timeout 100 0
return
外网路由配置信息如下:
 version 5.20, Release 2311
 sysname H3C
 dns proxy enable
 bridge enable
acl number 3000
 rule 0 permit ip
vlan 1
vlan 6
 description tp NeiWang 10.17.123.254
domain system
 state active
 idle-cut disable
dhcp server ip-pool vlan1 extended
user-group system
local-user admin
 password cipher $c$3$MDxVKXl9Q2F9eQLHJWWtAuZrDugOuI3CErkebQ==
 service-type telnet
local-user xuyisuning
 password cipher $c$3$4GbNByYqHDH+y/2F+oyn8pGsOY2rXGtzNb8gEQ==
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
attack-defense policy 1
 signature-detect action drop-packet
 signature-detect fraggle enable
 signature-detect land enable
 signature-detect winnuke enable
 signature-detect tcp-flag enable
 signature-detect icmp-unreachable enable
 signature-detect icmp-redirect enable
 signature-detect tracert enable
 signature-detect smurf enable
 signature-detect source-route enable
 signature-detect route-record enable
 signature-detect large-icmp enable
 defense scan enable
  defense scan add-to-blacklist
 defense syn-flood enable
  defense syn-flood action drop-packet
 defense udp-flood enable
  defense udp-flood action drop-packet
 defense icmp-flood enable
  defense icmp-flood action drop-packet
controller E1 0/0
interface Aux0
 async mode flow
 link-protocol ppp
 async mode protocol
 link-protocol ppp
 nat outbound static
 attack-defense apply policy 1
 nat outbound static
 nat outbound 3000
 ip address 117.1.27.9 255.255.255.0
 dns server 117.4.0.55
 nat outbound static
 nat outbound 3000
 ip address 10.17.123.223 255.255.255.0
interface NULL0
 ip address 192.1.1.254 255.255.255.0
 undo dhcp select server global-pool
 dhcp server apply ip-pool vlan1
interface Vlan-interface6
 nat outbound
 ip route-static 0.0.0.0 0.0.0.0 Ethernet0/0 117.1.27.1
 dhcp server forbidden-ip 192.1.1.10 192.1.1.254
 dhcp enable
 nms primary monitor-interface Ethernet0/0
return
内网不同网段互通,可以添加具体内网网段的静态路由实现
内外网互访需要NAT
能给写个具体的配置吗?
℡劉立軍 发表时间:2017-09-04
