F100-C-G 配置PPPoE拨号后外网无法访问防火墙外网口
2017-09-04提问
  • 1收藏,3125浏览
SecPath  F100-C-G 配置PPPoE拨号后外网无法访问防火墙外网口的80端口也无法Telnet 23端口
外部用户也无法使用拨号获取的公网IP地址通过L2TP VPN连接公司网络
设备配置如下:
[H3C]di cu
 version 5.20, Release 5142P02
 sysname H3C
 l2tp enable
 undo voice vlan mac-address 00e0-bb00-0000
 interzone policy default by-priority
 domain default enable system
 dns resolve
 dns proxy enable
 dns server 114.114.114.114
 telnet server enable
 port-security enable
 web idle-timeout 60
 undo alg dns
 undo alg rtsp
 undo alg h323
 undo alg sip
 undo alg sqlnet
 undo alg pptp
 undo alg ils
 undo alg nbt
 undo alg msn
 undo alg qq
 undo alg tftp
 undo alg sccp
 undo alg gtp
session synchronization enable
 password-recovery enable
acl number 2000
 rule 1 permit source 172.16.10.0 0.0.0.255
 rule 2 permit source 172.16.20.0 0.0.0.255
acl number 3333
 rule 0 permit ip
vlan 1
domain system
 authentication ppp local
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
 accounting optional
 ip pool 1 192.168.168.100 192.168.168.200
pki domain default
  crl check disable
dhcp server ip-pool dmz
 network 172.16.100.0 mask 255.255.255.0
 gateway-list 172.16.100.254
 dns-list 172.16.100.254
dhcp server ip-pool office10
 network 172.16.10.0 mask 255.255.255.0
 gateway-list 172.16.10.254
 dns-list 172.16.10.254
dhcp server ip-pool office20
 network 172.16.20.0 mask 255.255.255.0
 gateway-list 172.16.20.254
 dns-list 172.16.20.254
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$GtNONlXPUfSrjr3svymRPtgIMxbhviG33lgPG6o=
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
interface Dialer1
 link-protocol ppp
 ppp chap user xxxxxxxx
 ppp chap password cipher $c$3$ewrAddwK+wHJHvpThfRtajhHublT1ohwpg==
 ppp pap local-user xxxxxxxx password cipher $c$3$nFPtgWe4QfBooso0FU6rI13qb05BotuLCg==
 ppp ipcp dns request
 ip address ppp-negotiate
 dialer user pppoeclient
 dialer-group 1
 dialer bundle 1
interface Virtual-Template1
 ppp authentication-mode chap domain system
 remote address pool 1
 ip address 192.168.168.254 255.255.255.0
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/1
 ip address 172.16.100.254 255.255.255.0
interface GigabitEthernet0/2
 ip address 172.16.10.254 255.255.255.0
interface GigabitEthernet0/3
 ip address 172.16.20.254 255.255.255.0
interface GigabitEthernet0/4
 nat outbound 2000
 pppoe-client dial-bundle-number 1
vd Root id 1
zone name Management id 0
 priority 100
 import interface GigabitEthernet0/0
zone name Local id 1
 priority 100
zone name Trust id 2
 priority 85
 import interface GigabitEthernet0/2
 import interface GigabitEthernet0/3
zone name DMZ id 3
 priority 50
 import interface GigabitEthernet0/1
zone name Untrust id 4
 priority 5
 import interface Dialer1
 import interface GigabitEthernet0/4
switchto vd Root
 object network range 11
  range 172.16.10.1 172.16.10.253
 object network range 21
  range 172.16.100.1 172.16.100.253
 object network host www
  host address 172.16.10.1
 ip virtual-reassembly
 zone name DMZ id 3
 interzone source Trust destination DMZ
  rule 1 permit
   source-ip 11
   destination-ip any_address
   service any_service
   rule enable
 interzone source Trust destination Untrust
  rule 1 permit
   source-ip 11
   service any_service
   rule enable
 interzone source DMZ destination Trust
  rule 1 permit
   source-ip 21
   service any_service
   rule enable
 interzone source DMZ destination Untrust
  rule 1 permit
   source-ip 21
   service any_service
   rule enable
 interzone source Untrust destination Local
  rule 0 permit
   source-ip any_address
   service any_service
   rule enable
 interzone source Untrust destination Trust
  rule 1 permit
   destination-ip www
   service any_service
   rule enable
 ip route-static 0.0.0.0 0.0.0.0 Dialer1
 dhcp server forbidden-ip 172.16.10.254
 dhcp server forbidden-ip 172.16.20.254
 dhcp server forbidden-ip 172.16.100.254
 dhcp enable
 dialer-rule 1 ip permit
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface vty 0 4
 user privilege level 3
 set authentication password cipher $c$3$b0+qpvTZQWp8Am3gGZ13pOtgFCL992NwhnpOnCI=
 idle-timeout 60 0
return
[H3C]
请指点一下,谢谢!
防火墙Gi 0/4连接通过拨号连接公网,Gi 0/2和0/3分别连接内网不通的二层交换机。
粉丝:18人 关注:11人
策略放开了吗?  直接配个IP  直连单机测试能登录吗?
如果这样能  配置没问题  再看是不是运营商封掉了端口
粉丝:4人 关注:0人
在防火墙上开debug ip packet acl(acl匹配你的源电脑的公网ip,目的匹配拨号口地址,协议端口号也可以配置一下),看看有没有报文上来。
创建ACL 3001,ACL源为公网地址,目的地址为拨号口公网地址,执行debugging ip packet acl 无报文
zhiliao_58186 发表时间:2017-09-04
zhiliao_58186 知了小白
之前Gi 0/4连接路由器的LAN口设置固定IP测试,使用Gi 0/4相同网段的IP访问Gi 0/4的80能打开,Telnet也能连上,现在Gi0/4配置了PPPoE直接连外网,在公网测试就不能访问防火墙的外网口了。
