h3c交换机作irf集群
2023-08-30提问
  • 0收藏,598浏览
怎么配置irf?
2台数据中心交换机作irf
heam 四段
粉丝:1人 关注:10人
配置IRF2
3.1.1  配置设备编号
# Device A保留缺省编号为1,不需要进行配置。同时,在Device B上将设备的成员编号修改为2
<DeviceB> system-view   //进入系统视图
[DeviceB] irf member 1 renumber 2   //将设备的成员编号修改为2
Warning: Renumbering the switch number may result in configuration change or loss. Continue? [Y/N]:y
[DeviceB]
3.1.2  配置堆叠口
#将两台设备断电后,按组网图所示连接IRF链路,然后将两台设备上电。在Device A上创建设备的IRF端口2,与物理端口Ten-GigabitEthernet1/0/25 Ten-GigabitEthernet1/0/26绑定,并保存配置。
<DeviceA> system-view   //进入系统视图
[DeviceA] interface ten-gigabitethernet 1/0/25   //进入xg1/0/25接口
[DeviceA-Ten-GigabitEthernet1/0/25] shutdown   //关闭接口
[DeviceA-Ten-GigabitEthernet1/0/25] quit   //退出当前视图
[DeviceA] interface ten-gigabitethernet 1/0/26   //进入xg1/0/26接口
[DeviceA-Ten-GigabitEthernet1/0/26] shutdown   //关闭接口
[DeviceA-Ten-GigabitEthernet1/0/26] quit   //退出当前视图
[DeviceA] irf-port 1/2   //进入irf端口1/2
[DeviceA-irf-port1/2] port group interface ten-gigabitethernet1/0/25   //将成员设备1IRF物理端口Ten-GigabitEthernet1/0/25IRF端口IRF-port2绑定
[DeviceA-irf-port1/2] port group interface ten-gigabitethernet1/0/26   //将成员设备1IRF物理端口Ten-GigabitEthernet1/0/26IRF端口IRF-port2绑定
[DeviceA-irf-port1/2] quit   //退出当前视图
[DeviceA-Ten-GigabitEthernet1/0/25] undo shutdown   //开启接口
[DeviceA-Ten-GigabitEthernet1/0/26] undo shutdown   //开启接口
[DeviceA] save force   //保存配置
# Device B上创建设备的IRF端口1,与物理端口Ten-GigabitEthernet2/0/25Ten-GigabitEthernet2/0/26绑定,并保存配置。
[DeviceB] interface ten-gigabitethernet 2/0/25   //进入xg2/0/25接口
[DeviceB-Ten-GigabitEthernet2/0/25] shutdown   //关闭接口
[DeviceB-Ten-GigabitEthernet2/0/25] quit   //退出当前视图
[DeviceB] interface ten-gigabitethernet 2/0/26   //进入xg2/0/26接口
[DeviceB-Ten-GigabitEthernet2/0/26] shutdown   //关闭接口
[DeviceB-Ten-GigabitEthernet2/0/26] quit   //退出当前视图
[DeviceB] irf-port 2/1   //进入irf端口2/1
[DeviceB-irf-port2/1] port group interface ten-gigabitethernet2/0/25   //将成员设备2IRF物理端口Ten-GigabitEthernet2/0/25IRF端口IRF-port1绑定
[DeviceB-irf-port2/1] port group interface ten-gigabitethernet2/0/26   //将成员设备2IRF物理端口Ten-GigabitEthernet2/0/26IRF端口IRF-port1绑定
[DeviceB-irf-port2/1] quit   //退出当前视图
[DeviceB-Ten-GigabitEthernet2/0/25] undo shutdown   //开启接口
[DeviceB-Ten-GigabitEthernet2/0/26] undo shutdown   //开启接口
[DeviceB] save force   //保存配置
# 激活DeviceAIRF端口配置。
[DeviceA] irf-port-configuration active   //激活DeviceAIRF端口配置
# 激活DeviceBIRF端口配置。
[DeviceB] irf-port-configuration active   //激活DeviceBIRF端口配置
#两台设备间将会进行Master竞选,竞选失败的一方将自动重启,重启完成后,IRF形成,系统名称统一为DeviceA
3.2  BFD分裂检测(选配)
IRF设备一旦分裂,会变成两台配置完全相同的设备,导致业务转发有问题。为了避免此类问题出现,可以配置分裂检测。设备一旦检测到IRF2分裂,则自动关闭备设备的所有非保留端口。在此介绍BFD MAD分裂检测配置方法。使用网线Device A上的端口GigabitEthernet1/0/1Device B上的端口GigabitEthernet2/0/1连接起来。
# 创建VLAN 3,并将Device A上的端口GigabitEthernet1/0/1Device B上的端口GigabitEthernet2/0/1加入VLAN中。
[DeviceA] vlan 3   //创建vlan3
[DeviceA-vlan3] port gigabitethernet 1/0/1 gigabitethernet 2/0/1   //g1/0/1g2/0/1加入vlan3
[DeviceA-vlan3] quit   //退出当前视图
# 创建VLAN接口3,并配置MAD IP地址。
[DeviceA] interface vlan-interface 3   //进入vlan3虚接口
[DeviceA-Vlan-interface3] mad bfd enable   //开启bfd mad检测
[DeviceA-Vlan-interface3] mad ip address 192.168.2.1 24 member 1   //配置vlan3接口在成员设备1上的MAD IP地址为192.168.2.1
[DeviceA-Vlan-interface3] mad ip address 192.168.2.2 24 member 2   //配置vlan3接口在成员设备2上的MAD IP地址为192.168.2.2
[DeviceA-Vlan-interface3] quit   //退出当前视图
# 按组网图所示连接BFD MAD链路。
# 因为BFD MAD和生成树功能互斥,所以在GigabitEthernet1/0/1GigabitEthernet2/0/1上关闭生成树协议。
[DeviceA] interface gigabitethernet 1/0/1   //进入g1/0/1接口
[DeviceA-Gigabitethernet1/0/1] undo stp enable   //关闭生成树
[DeviceA-Gigabitethernet1/0/1] quit   //退出当前视图
[DeviceA] interface gigabitethernet 2/0/1   //进入g2/0/1接口
[DeviceA-Gigabitethernet2/0/1] undo stp enable   //关闭生成树
3.3  配置要点
1IRF-port端口编号说明,irf-port 1/2中,第一个数字代表的是设备成员编号,第二个数字是接口编号。堆叠要求使用逻辑端口1对接逻辑端口2。即,如若第一台配置irf-port1/2,则第二台需要是用irf-port2/1对接。如若第一台使用irf-port1/1,则第二台需要配置irf-port2/2
2)设备配置好IRF2配置后,要先保存再激活配置。
你这个没有切换模式,没切的话有些交换机打不上irf-port-configuration active命令。 a先配irf端口,保存,切模式,重启,重启完成。配置b的irf端口,保存。。。连线。。。切换式,重启,重启完成后irf组好。chassis convert mode irf //将设备的运行模式切换到IRF模式。
大白_ 发表时间:2023-08-30
粉丝:119人 关注:1人
  • 01-H3C_IRF典型配置举例-新华三集团-H3C:这是一个详细介绍了IRF的相关概念和配置步骤的文档,包括IRF的体系结构、认证报文的交互机制、支持VLAN和VSI下发、支持ACL和User Profile下发、支持EAD快速部署等功能。
  • 01-IRF配置-新华三集团-H3C:这是另一个关于IRF配置的文档,涵盖了IRF的接入控制方式、重认证、URL重定向、CAR属性下发等功能,以及IRF的典型配置举例和常见故障处理方法。
  • F1000-AK系列防火墙虚拟化(IRF2)配置举例(命令行 …:这是一个针对F1000-AK系列防火墙的虚拟化(IRF2)配置举例,说明了如何通过命令行方式将两台防火墙组成堆叠,并进行MAD检测和业务配置。
希望这些信息能够对您有所帮助。如果您还有其他问题,欢迎继续与我交流。😊
