恢复出厂设置
2023-09-08提问
  • 0收藏,448浏览
s5130恢复出厂设置
恢复出厂设置
粉丝:121人 关注:8人
命令行恢复出厂设置
reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //确定删除保存的配置文件
reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N  //不保存配置
This command will reboot the device. Continue? [Y/N]:Y   //继续重启
粉丝:24人 关注:0人
<H3C>rest  sa
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //输入Y
之后断电重启即可
console线进系统,reset sa ,Y-----N-----Y,人后reboot
粉丝:119人 关注:1人
删除dir目录下的cfg文件和mdb文件,然后不报错配置重启即可
