H3C 交换机与Cisco交换机采用链路聚合对接(静态和动态)
2023-09-26提问
  • 0收藏,831浏览
粉丝:0人 关注:12人
请教各位大神帮忙写一下H3C 交换机与Cisco交换机采用链路聚合对接(静态和动态)万分感谢!
粉丝:119人 关注:1人
必须配置lacp动态聚合
有具体对接配置吗?
枫飘雪2019 发表时间:2023-09-26
回复枫飘雪2019:
正常配置即可,参考各自的文档,不要用思科的pagp
叫我靓仔 发表时间:2023-09-26
粉丝:23人 关注:0人
参考LACP对接指导:
3.1  与思科设备对接操作指导
3.1.1  互通性分析
表7 互通性分析
H3C
Cisco
互通结论
Static(缺省)
On(缺省)
可以互通
Dynamic
Active
可以互通
3.1.2  采用静态聚合模式对接案例
1. 组网需求
10所示,H3C设备与Cisco设备通过各自的二层以太网接口相互连接。现要求在H3C设备和Cisco设备上分别配置静态链路聚合,实现增加链路带宽、提高链路可靠性的目的。
图10 采用静态聚合模式对接配置组网图
2. 配置步骤
·     配置H3C设备
创建三层聚合接口1,并为该接口配置IP地址和子网掩码。
<H3C> system-view
[H3C] interface Route-aggregation 1
[H3C-Route-Aggregation1] ip address 16.1.105.33 24
[H3C-Route-Aggregation1] quit
将三层以太网接口GigabitEthernet1/0/1加入三层聚合组1中。
[H3C] interface gigabitethernet 1/0/1
[H3C-GigabitEthernet1/0/1] port link-aggregation group 1
[H3C-GigabitEthernet1/0/1] quit
将三层以太网接口GigabitEthernet1/0/2加入三层聚合组1中。
[H3C] interface GigabitEthernet 1/0/2
[H3C-GigabitEthernet1/0/2] port link-aggregation group 1
[H3C-GigabitEthernet1/0/2] quit
·     配置Cisco设备
如下配置以Cisco Nexus9000 C9236C为例进行介绍,设备具体信息如下:
Cisco# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2017, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source.  This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0  or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
***.***/licenses/gpl-2.0.php and
***.***/licenses/gpl-3.0.html and
***.***/licenses/lgpl-2.1.php and
***.***/licenses/old-licenses/library.txt.
Software
 BIOS: version 07.56
 NXOS: version 7.0(3)I4(6)
 BIOS compile time:  06/08/2016
 NXOS image file is: bootflash:///nxos.7.0.3.I4.6.bin
 NXOS compile time:  3/9/2017 22:00:00 [03/10/2017 07:05:18]
Hardware
 cisco Nexus9000 C9236C chassis
Intel(R) Xeon(R) CPU  @ 1.80GHz with 16400984 kB of memory.
 Processor Board ID FDO20511FC7
Device name: switch
 bootflash:   53298520 kB
Kernel uptime is 17 day(s), 20 hour(s), 9 minute(s), 30 second(s)
Last reset
Reason: Unknown
 System version: 7.0(3)I4(6)
 Service:
plugin
 Core Plugin, Ethernet Plugin
Active Package(s):
配置聚合口的IP地址。
Cisco# configure terminal
Cisco(config)# interface channel-group 1
Cisco(config-if)# ip address 16.1.105.34 255.255.255.0
Cisco(config-if)# exit
设置接口Ethernet1/3的聚合模式为手动方式。
Cisco(config)# interface Ethernet 1/3
Cisco(config-if)# channel-group 1 mode on
设置接口Ethernet1/5的聚合模式为手动方式。
Cisco(config-if)# interface Ethernet 1/5
Cisco(config-if)# end
3. 验证配置
H3C设备上验证聚合组的详细信息。
[H3C] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Mode: Static
Management VLANs: None
  Port             Status  Priority Oper-Key
  GE1/0/1(R)       S       32768    1
  GE1/0/2          S       32768    1
H3C设备上能Ping通对端设备。
[H3C ] ping 16.1.105.34
Ping 16.1.105.34 (16.1.105.34): 56 data bytes, press CTRL_C to break
56 bytes from 16.1.105.34: icmp_seq=0 ttl=255 time=2.537 ms
56 bytes from 16.1.105.34: icmp_seq=1 ttl=255 time=2.000 ms
56 bytes from 16.1.105.34: icmp_seq=2 ttl=255 time=1.935 ms
56 bytes from 16.1.105.34: icmp_seq=3 ttl=255 time=2.044 ms
56 bytes from 16.1.105.34: icmp_seq=4 ttl=255 time=2.143 ms
--- Ping statistics for 16.1.105.34 ---
round-trip min/avg/max/std-dev = 1.935/2.132/2.537/0.214 ms
3.1.3  采用动态聚合模式对接案例
1. 组网需求
11所示,H3C设备与Cisco设备通过各自的二层以太网接口相互连接。现要求在H3C设备和Cisco设备上分别配置动态链路聚合,实现增加链路带宽、提高链路可靠性的目的。
图11 采用动态聚合模式对接配置组网图
2. 配置步骤
·     配置H3C设备
<H3C> system-view
配置三层聚合接口1对应的聚合组工作在动态聚合模式下。
[H3C-Route-Aggregation1] link-aggregation mode dynamic
[H3C] interface gigabitethernet 1/0/2
·     配置Cisco设备
Cisco# show version
Software
 BIOS: version 07.56
Hardware
Device name: switch
Last reset
Reason: Unknown
 Service:
plugin
Active Package(s):
启动LACP
Cisco(config)# feature lacp
设置聚合接口的IP地址。
Ethernet1/3接口设置为LACPactive模式。
Cisco(config-if)# channel-group 1 mode active
Ethernet1/5接口设置为LACPactive模式。
3. 验证配置
H3C设备上验证聚合组的详细信息。
Aggregation Mode: Dynamic
System ID: 0x8000, 1cab-3496-09f6
Local:
  Port               Status   Priority Index    Oper-Key               Flag
  GE1/0/1(R)          S        32768    1        1                    {ACDEF}
  GE1/0/2             S        32768    2        1                    {ACDEF}
Remote:
  Actor            Priority  Index    Oper-Key    SystemID               Flag
   GE1/0/1         32768    265      32768    0x8000, 2c33-113a-eaef {ACDEF}
   GE1/0/2         32768    273      32768    0x8000, 2c33-113a-eaef {ACDEF}
H3C设备上能Ping通对端设备。
[H3C] ping 16.1.105.34
Request time out
56 bytes from 16.1.105.34: icmp_seq=1 ttl=255 time=2.331 ms
56 bytes from 16.1.105.34: icmp_seq=2 ttl=255 time=2.063 ms
56 bytes from 16.1.105.34: icmp_seq=3 ttl=255 time=2.202 ms
56 bytes from 16.1.105.34: icmp_seq=4 ttl=255 time=2.219 ms
5 packet(s) transmitted, 4 packet(s) received, 20.0% packet loss
round-trip min/avg/max/std-dev = 2.063/2.204/2.331/0.095 ms
谢谢大神,有二层对接配置吗?
回复枫飘雪2019:
上面两种都是二层对接呀,
悲剧塔 发表时间:2023-09-26
回复悲剧塔:
大神,楼上都是三层聚合,二层聚合的静态+动态配置您有吗?
回复枫飘雪2019:
sorry,看错了,不过按照上面的配置也是可以可的, route-aggre链路组改为bridge-aggr就行,其他lacp照抄,cisco那端,同理。我暂时没找到二层对接的官方手册,不过以上是足够参考的
悲剧塔 发表时间:2023-09-26
回复悲剧塔:
谢谢大神!
粉丝:7人 关注:0人
华三的配置动态,cisco配置lacp
