MSR830-6BHI IPV6问题
2023-10-13提问
  • 0收藏,346浏览
kevin 零段
在淘宝上花钱请人设置了 以后可以PING通IPV6 的DNS了也可以访问IPV6资源了 现在是很多原来使用IPV4拨号上网可以打开的网站 都打不开了  必须挂代理软件才可以打的开了
比如百度可以打开 但他们的下级功能比如 百度翻译就打不开
  1. #
  2. version 7.1.064, Release 6728P26
  3. #
  4. sysname Router
  5. #
  6. clock timezone Beijing add 08:00:00
  7. clock protocol ntp
  8. #
  9. wlan global-configuration
  10. #
  11. undo resource-monitor output syslog snmp-notification netconf-event
  12. #
  13. security-zone intra-zone default permit
  14. #
  15. dialer-group 1 rule ip permit
  16. #
  17. ip load-sharing mode per-flow src-ip global
  18. #
  19. dhcp enable
  20. dhcp server always-broadcast
  21. #
  22. dns proxy enable
  23. #
  24. lldp global enable
  25. #
  26. system-working-mode standard
  27. password-recovery enable
  28. #
  29. vlan 1
  30. #
  31. dhcp server ip-pool lan1
  32. gateway-list 192.168.0.1
  33. network 192.168.0.0 mask 255.255.254.0
  34. address range 192.168.1.2 192.168.1.254
  35. dns-list 114.114.114.114 202.96.128.166
  36. #
  37. wlan service-template h3c
  38. ssid H3C
  39. #
  40. wlan service-template h3c_5g
  41. ssid H3C_5G
  42. #
  43. controller Cellular0/0
  44. #
  45. interface Aux0
  46. #
  47. interface Dialer0
  48. ppp chap password cipher $c$3$tMuS1DKeKV9jxSZ9PoHFDVnnmJsRiB/K38Dy
  49. ppp chap user 07551215870801@163.gd
  50. ppp ipcp dns admit-any
  51. ppp ipcp dns request
  52. ppp pap local-user 07551215870801@163.gd password cipher $c$3$XMjo8y3JJ5xCh798YKyH3yrpI3udopusLCqp
  53. dialer bundle enable
  54. dialer-group 1
  55. dialer timer idle 0
  56. dialer timer autodial 5
  57. ip address ppp-negotiate
  58. nat outbound
  59. ipv6 address auto
  60. ipv6 address auto link-local
  61. ipv6 dhcp client pd 1 rapid-commit option-group 1
  62. ipv6 dhcp client stateless enable
  63. #
  64. interface NULL0
  65. #
  66. interface Vlan-interface1
  67. description LAN-interface
  68. ip address 192.168.0.1 255.255.254.0
  69. tcp mss 1280
  70. ipv6 dhcp select server
  71. ipv6 address 1 ::1/64
  72. ipv6 nd autoconfig managed-address-flag
  73. ipv6 nd autoconfig other-flag
  74. undo ipv6 nd ra halt
  75. ipv6 nd ra interval 60 10
  76. ipv6 nd ra dns server 240E:1F:1::1 sequence 0
  77. #
  78. interface GigabitEthernet0/0
  79. port link-mode route
  80. description Single_Line1
  81. combo enable copper
  82. pppoe-client dial-bundle-number 0
  83. #
  84. interface GigabitEthernet0/1
  85. port link-mode route
  86. #
  87. interface GigabitEthernet0/2
  88. port link-mode bridge
  89. #
  90. interface GigabitEthernet0/3
  91. port link-mode bridge
  92. #
  93. interface GigabitEthernet0/4
  94. port link-mode bridge
  95. #
  96. interface GigabitEthernet0/5
  97. port link-mode bridge
  98. #
  99. scheduler logfile size 16
  100. #
  101. line class aux
  102. user-role network-operator
  103. #
  104. line class console
  105. user-role network-admin
  106. #
  107. line class tty
  108. user-role network-operator
  109. #
  110. line class vty
  111. user-role network-operator
  112. #
  113. line aux 0
  114. authentication-mode none
  115. user-role network-admin
  116. #
  117. line con 0
  118. user-role network-admin
  119. #
  120. line vty 0 63
  121. authentication-mode scheme
  122. user-role network-operator
  123. #
  124. ip route-static 0.0.0.0 0 Dialer0
  125. ipv6 route-static :: 0 Dialer0
  126. #
  127. info-center loghost 127.0.0.1 port 3301
  128. info-center source CFGLOG loghost level informational
  129. #
  130. performance-management
  131. #
  132. ntp-service enable
  133. ntp-service unicast-server ***.***
  134. ntp-service unicast-server ***.***
  135. ntp-service unicast-server ***.***
  136. ntp-service unicast-server ***.***
  137. ntp-service unicast-server ***.***
  138. ntp-service unicast-server ***.***
  139. ntp-service unicast-server ***.***
  140. #
  141. password-control enable
  142. undo password-control aging enable
  143. undo password-control history enable
  144. password-control length 6
  145. password-control login-attempt 3 exceed lock-time 10
  146. password-control update-interval 0
  147. password-control login idle-time 0
  148. #
  149. domain system
  150. #
  151. domain default enable system
  152. #
  153. role name level-0
  154. description Predefined level-0 role
  155. #
  156. role name level-1
  157. description Predefined level-1 role
  158. #
  159. role name level-2
  160. description Predefined level-2 role
  161. #
  162. role name level-3
  163. description Predefined level-3 role
  164. #
  165. role name level-4
  166. description Predefined level-4 role
  167. #
  168. role name level-5
  169. description Predefined level-5 role
  170. #
  171. role name level-6
  172. description Predefined level-6 role
  173. #
  174. role name level-7
  175. description Predefined level-7 role
  176. #
  177. role name level-8
  178. description Predefined level-8 role
  179. #
  180. role name level-9
  181. description Predefined level-9 role
  182. #
  183. role name level-10
  184. description Predefined level-10 role
  185. #
  186. role name level-11
  187. description Predefined level-11 role
  188. #
  189. role name level-12
  190. description Predefined level-12 role
  191. #
  192. role name level-13
  193. description Predefined level-13 role
  194. #
  195. role name level-14
  196. description Predefined level-14 role
  197. #
  198. user-group system
  199. #
  200. local-user admin class manage
  201. service-type telnet http https
  202. authorization-attribute user-role network-admin
  203. #
  204. security-enhanced level 1
  205. #
  206. session statistics enable
  207. #
  208. netconf soap http enable
  209. #
  210. ip http enable
  211. ip https enable
  212. web new-style
  213. #
  214. wlan auto-ap enable
  215. #
  216. wlan ap-group default-group
  217. vlan 1
  218. ap-model WA2620-WiNet
  219.   radio 1
  220.   radio enable
  221.   service-template h3c_5g
  222.   radio 2
  223.   radio enable
  224.   service-template h3c
  225.   gigabitethernet 1
  226. ap-model WA2620E-WiNet
  227.   radio 1
  228.   radio enable
  229.   service-template h3c_5g
  230.   radio 2
  231.   radio enable
  232.   service-template h3c
  233.   gigabitethernet 1
  234. ap-model WA5320-WiNet
  235.   radio 1
  236.   radio enable
  237.   service-template h3c_5g
  238.   radio 2
  239.   radio enable
  240.   service-template h3c
  241.   gigabitethernet 1
  242. ap-model WA5320E-WiNet
  243.   radio 1
  244.   radio enable
  245.   service-template h3c_5g
  246.   radio 2
  247.   radio enable
  248.   service-template h3c
  249.   gigabitethernet 1
  250.   gigabitethernet 2
  251. ap-model WA5320H-WiNet
  252.   radio 1
  253.   radio enable
  254.   service-template h3c_5g
  255.   radio 2
  256.   radio enable
  257.   service-template h3c
  258.   gigabitethernet 1
  259.   gigabitethernet 2
  260.   gigabitethernet 3
  261.   gigabitethernet 4
  262.   gigabitethernet 5
  263. #
  264. traffic-policy
  265. rule 1 name web_AppTraffRank
  266.   application app http
  267. #
  268. dac log-collect service dpi traffic enable
  269. dac traffic-statistic application enable
  270. #
  271. dac storage service dpi traffic limit hold-time 1
  272. dac storage service traffic limit hold-time 1
  273. #
  274. cloud-management server domain cloudnet.h3c.com
  275. #
  276. return
前后配置有哪些变动?
打不开的时候,终端ping域名能通吗?看看是否能解析地址?ping解析出的地址是否能通?
粉丝:17人 关注:9人
域名无法打开,以下是排查要点,请参考:
1、检查设置的DNS是否正确。
2、检查路由是否可达。
3、检查是否有安全策略拦截了。
kevin 知了小白
前后配置有哪些变动?
打不开的 时候 可以ping通 可以解析地址 ping解析也可以ping通
域名无法打开,以下是排查要点,请参考:
1、检查设置的DNS是否正确。默认的DNS 也更换了 阿里 百度的IPV6 DNS
2、检查路由是否可达。可以访问的 现在是 比如TAOBAO可以打开主页 但 打不开淘宝的所有链接
3、检查是否有安全策略拦截了。没有设置安全策略 家庭网络
