LX7006 环境下有个区域存在网络故障 各位大佬帮忙分析下日志
2023-10-19提问
  • 0收藏,298浏览
%Oct 13 14:54:49:677 2023 SCJY-HeXin-Core LLDP/6/LLDP_DELETE_NEIGHBOR: -Slot=7; Nearest bridge agent neighbor deleted on port GigabitEthernet7/0/4 (IfIndex 676), neighbor's chassis ID is e0d5-5e9f-2efa, port ID is e0d5-5e9f-2efa. %Oct 13 14:54:49:687 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=7; Nearest bridge agent neighbor created on port GigabitEthernet7/0/4 (IfIndex 676), neighbor's chassis ID is e0d5-5e9f-2efa, port ID is e0d5-5e9f-2efa. %Oct 13 16:38:39:615 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/45 was notified a topology change. %Oct 13 16:38:42:665 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/45 was notified a topology change. %Oct 13 18:27:12:398 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 13 18:48:08:661 2023 SCJY-HeXin-Core LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -Slot=7; Nearest bridge agent neighbor aged out on port GigabitEthernet7/0/4 (IfIndex 676), neighbor's chassis ID is e0d5-5e9f-2efa, port ID is e0d5-5e9f-2efa. %Oct 13 19:21:12:583 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=7; Nearest bridge agent neighbor created on port GigabitEthernet7/0/4 (IfIndex 676), neighbor's chassis ID is e0d5-5e9f-2efa, port ID is e0d5-5e9f-2efa. %Oct 13 19:29:40:357 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 13 23:16:47:923 2023 SCJY-HeXin-Core SSHS/6/SSHS_DISCONNECT: SSH user admin (IP: 172.22.229.165) disconnected from the server. %Oct 13 23:16:47:934 2023 SCJY-HeXin-Core SHELL/5/SHELL_LOGOUT: admin logged out from 172.22.229.165. %Oct 14 00:03:55:418 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 14 00:03:57:427 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 14 00:04:09:850 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 14 00:04:13:847 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 14 06:54:03:333 2023 SCJY-HeXin-Core LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -Slot=6; Nearest bridge agent neighbor aged out on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 14 08:03:23:858 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=6; Nearest bridge agent neighbor created on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 14 09:00:34:639 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 14 09:35:13:818 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 14 14:08:58:352 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 14 14:12:08:395 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to down. %Oct 14 14:12:08:398 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to down. %Oct 14 14:12:09:967 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to up. %Oct 14 14:12:09:977 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to up. %Oct 14 14:12:21:467 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to down. %Oct 14 14:12:21:472 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to down. %Oct 14 14:12:23:976 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to up. %Oct 14 14:12:23:986 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to up. %Oct 14 14:25:21:415 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/44 was notified a topology change. %Oct 14 14:25:24:415 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/44 was notified a topology change. %Oct 14 14:25:34:424 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/44 was notified a topology change. %Oct 14 14:42:30:520 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/44 was notified a topology change. %Oct 14 14:42:32:819 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/44 was notified a topology change. %Oct 14 14:42:37:387 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/44 was notified a topology change. %Oct 14 16:58:29:208 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 14 17:47:43:242 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/45 was notified a topology change. %Oct 14 17:47:58:249 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/45 was notified a topology change. %Oct 14 18:14:38:333 2023 SCJY-HeXin-Core LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -Slot=6; Nearest bridge agent neighbor aged out on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 14 19:04:53:128 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 14 19:46:55:730 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=6; Nearest bridge agent neighbor created on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 15 00:00:39:260 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 15 00:00:42:133 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 15 00:01:20:135 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 15 06:45:25:333 2023 SCJY-HeXin-Core LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -Slot=6; Nearest bridge agent neighbor aged out on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 15 08:01:06:488 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=6; Nearest bridge agent neighbor created on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 15 11:50:17:272 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 15 12:40:33:226 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 15 13:47:02:359 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/45 was notified a topology change. %Oct 15 13:47:04:369 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/45 was notified a topology change. %Oct 15 13:47:11:262 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/45 was notified a topology change. %Oct 15 14:12:14:577 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to down. %Oct 15 14:12:14:581 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to down. %Oct 15 14:12:16:148 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to up. %Oct 15 14:12:16:151 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to up. %Oct 15 14:12:27:753 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to down. %Oct 15 14:12:27:758 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to down. %Oct 15 14:12:30:267 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to up. %Oct 15 14:12:30:279 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to up. %Oct 15 18:03:22:950 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 15 18:28:06:333 2023 SCJY-HeXin-Core LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -Slot=6; Nearest bridge agent neighbor aged out on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 15 19:43:02:874 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=6; Nearest bridge agent neighbor created on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 15 22:25:44:119 2023 SCJY-HeXin-Core SSHS/6/SSHS_AUTH_SUCCESS: SSH user admin from 172.22.229.165 port 58653 passed password authentication. %Oct 15 22:25:45:161 2023 SCJY-HeXin-Core SSHS/6/SSHS_CONNECT: SSH user admin (IP: 172.22.229.165) connected to the server successfully. %Oct 15 22:25:45:323 2023 SCJY-HeXin-Core SHELL/5/SHELL_LOGIN: admin logged in from 172.22.229.165. %Oct 15 22:25:47:403 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is sy %Oct 15 22:25:58:557 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 5 %Oct 15 22:26:19:363 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 4 %Oct 15 22:26:23:453 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 3 %Oct 15 22:26:26:937 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 6 %Oct 15 22:26:31:519 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 7 %Oct 15 22:26:36:727 2023 SCJY-HeXin-Core SHELL/4/SHELL_CMD_MATCHFAIL: -User=admin-IPAddr=172.22.229.165; Command dis stp his s 8 in view system failed to be matched. %Oct 15 22:26:40:713 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 1 %Oct 15 22:26:49:932 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 2 %Oct 15 22:26:57:137 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 3 %Oct 15 22:27:00:290 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 4 %Oct 15 22:27:02:995 2023 SCJY-HeXin-Core SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.22.229.165-User=admin; Command is dis stp his s 5 %Oct 15 22:27:09:260 2023 SCJY-HeXin-Core SSHS/6/SSHS_LOG: User admin logged out from 172.22.229.165 port 58653. %Oct 15 22:27:09:260 2023 SCJY-HeXin-Core SSHS/6/SSHS_DISCONNECT: SSH user admin (IP: 172.22.229.165) disconnected from the server. %Oct 15 22:27:09:278 2023 SCJY-HeXin-Core SHELL/5/SHELL_LOGOUT: admin logged out from 172.22.229.165. %Oct 15 23:59:26:436 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 15 23:59:29:439 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 16 00:00:23:436 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 16 06:41:32:333 2023 SCJY-HeXin-Core LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -Slot=6; Nearest bridge agent neighbor aged out on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 16 08:02:32:806 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=6; Nearest bridge agent neighbor created on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 16 08:47:15:183 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 08:51:38:179 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 08:51:48:179 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 08:52:37:185 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 08:55:47:182 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 09:04:59:151 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 09:32:50:120 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 09:50:11:109 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 09:54:30:097 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 09:58:33:098 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 10:00:56:091 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 12:43:53:955 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 13:24:18:924 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 13:24:59:912 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 13:27:23:909 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 13:33:18:911 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 13:35:43:909 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 14:12:14:004 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to down. %Oct 16 14:12:14:007 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to down. %Oct 16 14:12:15:578 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to up. %Oct 16 14:12:15:584 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to up. %Oct 16 14:12:27:183 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to down. %Oct 16 14:12:27:187 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to down. %Oct 16 14:12:29:391 2023 SCJY-HeXin-Core IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/0/47 changed to up. %Oct 16 14:12:29:395 2023 SCJY-HeXin-Core IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/0/47 changed to up. %Oct 16 14:38:25:020 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=5; Nearest bridge agent neighbor created on port GigabitEthernet5/0/48 (IfIndex 528), neighbor's chassis ID is 1c69-7ab8-1415, port ID is 1c69-7ab8-1415. %Oct 16 15:02:01:469 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 15:02:01:736 10/16/2023 to 15:02:01:407 10/16/2023, the NTP server's IP address is 172.22.229.253. %Oct 16 15:30:10:903 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 15:30:10:476 10/16/2023 to 15:30:10:852 10/16/2023, the NTP server's IP address is 172.22.229.253. %Oct 16 16:01:25:477 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 16:06:10:456 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 16:19:18:303 2023 SCJY-HeXin-Core LLDP/6/LLDP_DELETE_NEIGHBOR: -Slot=5; Nearest bridge agent neighbor deleted on port GigabitEthernet5/0/48 (IfIndex 528), neighbor's chassis ID is 1c69-7ab8-1415, port ID is 1c69-7ab8-1415. %Oct 16 16:24:01:442 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 17:01:08:747 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=5; Nearest bridge agent neighbor created on port GigabitEthernet5/0/48 (IfIndex 528), neighbor's chassis ID is 1c69-7ab8-1415, port ID is 1c69-7ab8-1415. %Oct 16 17:54:01:356 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 18:01:53:817 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 18:01:53:908 10/16/2023 to 18:01:53:766 10/16/2023, the NTP server's IP address is 172.22.229.253. %Oct 16 18:19:26:234 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/45 was notified a topology change. %Oct 16 18:19:33:243 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/45 was notified a topology change. %Oct 16 18:29:32:925 2023 SCJY-HeXin-Core LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -Slot=6; Nearest bridge agent neighbor aged out on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 16 19:01:24:309 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 19:51:50:316 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=0; Instance 0's port GigabitEthernet0/0/21 was notified a topology change. %Oct 16 20:00:13:198 2023 SCJY-HeXin-Core LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=6; Nearest bridge agent neighbor created on port GigabitEthernet6/0/40 (IfIndex 616), neighbor's chassis ID is 2c56-dc3c-3d01, port ID is 2c56-dc3c-3d01. %Oct 17 00:02:56:867 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 17 00:03:05:317 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 17 00:03:45:304 2023 SCJY-HeXin-Core STP/6/STP_NOTIFIED_TC: -Slot=5; Instance 0's port GigabitEthernet5/0/46 was notified a topology change. %Oct 17 00:35:45:997 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 00:35:46:824 10/17/2023 to 00:35:45:946 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 00:45:54:590 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 00:45:54:002 10/17/2023 to 00:45:54:539 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 00:56:50:325 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 00:56:50:595 10/17/2023 to 00:56:50:275 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 01:07:37:138 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 01:07:36:330 10/17/2023 to 01:07:37:085 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 01:18:20:375 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 01:18:20:145 10/17/2023 to 01:18:20:322 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 01:43:48:154 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 01:43:48:379 10/17/2023 to 01:43:48:103 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 01:54:00:446 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 01:53:59:159 10/17/2023 to 01:54:00:393 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 02:04:51:334 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 02:04:51:451 10/17/2023 to 02:04:51:282 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 02:15:39:538 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 02:15:39:338 10/17/2023 to 02:15:39:488 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 02:26:27:233 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 02:26:26:543 10/17/2023 to 02:26:27:181 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 02:48:27:283 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 02:48:28:239 10/17/2023 to 02:48:27:233 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 03:05:47:008 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 03:05:47:288 10/17/2023 to 03:05:46:957 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 03:28:53:414 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 03:28:54:014 10/17/2023 to 03:28:53:361 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 03:39:17:194 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 03:39:17:419 10/17/2023 to 03:39:17:141 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 03:50:08:043 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 03:50:08:198 10/17/2023 to 03:50:07:989 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 04:29:09:247 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 04:29:11:052 10/17/2023 to 04:29:09:195 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 04:39:14:750 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 04:39:13:255 10/17/2023 to 04:39:14:698 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 04:50:01:732 2023 SCJY-HeXin-Core NTP/5/NTP_CLOCK_CHANGE: System clock changed from 04:50:02:755 10/17/2023 to 04:50:01:681 10/17/2023, the NTP server's IP address is 172.22.229.253. %Oct 17 05:15:49:498 2023 SCJY-HeXin-Core WEB/5/LOGIN_FAILED: admin failed to log in from 172.22.243.189. %Oct 17 05:15:53:233 2023 SCJY-HeXin-Core WEB/5/LOGIN_FAILED: admin failed to log in from 172.22.243.189.
blili 八段
粉丝:3人 关注:0人
接口物理up/down建议替换测试看故障跟谁走
还有大量的tc报文,建议排除下tc
tc排查方法:
执行命令 display stp 查看收到 TC 报文的数量,同时查看最近一次拓扑变化时间,如果 TC 报文的数量一直递增且最近一次拓扑变化时间在 10 秒以内,那么端口肯定频繁收到 TC 报文。接下来就是追溯 TC 源头,执行命令 diplay stp tc 查看频繁收到 TC 报文的端口,如果某端口收到的 TC 报文一直递增,查看该端口的对端设备的 TC 接收端口,一级一级往上直到找到 TC 源。
感谢 我试试看
zhiliao_PKP6qO 发表时间:2023-10-19
粉丝:112人 关注:8人
哪个区域,那个接口上来的,什么时间说明一下
最近三四天 每天凌晨左右 不定时会有问题 接口时5/0/45 麻烦了 多谢
5/0/45就是stp的日志
zhiliao_sEUyB 发表时间:2023-10-19
拓扑变化的日志
能看出有什么问题不 大佬看一下
看不出来,只有拓扑改变的日志,并且不多
