3PAR8440存储电池一直是充电状态
2023-10-25提问
  • 0收藏,625浏览
粉丝:1人 关注:13人
客户一台3PAR8440存储存储admithw报以下错误,node存储柜的两个电源,总是有一个电池(两个电池会切换)一直是充电状态(电池充电都已经100%),根据以下的报错输出,可以优先考虑更换两个电源的电池吗?
node:0 - Only 0% of node cache memory is available
node:1 - Only 0% of node cache memory is available
Resolution for the above issues: This indicates that the one of the batteries associated with the node may be failing or severely degraded. Refer to the Service and Upgrade guide appropriate to your array for further troubleshooting information. It may be necessary to replace the failing battery.
3PAR8440存储两个控制器checkhealth报Only 0% of node cache memory is available,且电池一直是充电状态
