四台S10510X堆叠,跨框远程镜像
2023-10-28提问
  • 0收藏,863浏览
配置远程镜像,加入Remote probe VLAN的接口G3/0/0/45、TE3/2/0/7,反射口TE3/2/0/6
日志一直提示TE3/2/0/6传入广播流量突然超过阈值。阈值=20000,当前值=21090。
Ten-GigabitEthernet3/2/0/6的传入广播流量突然降至下限以下。阈值=20000,当前值=623。
然后G3/0/0/45的队列数据包丢失,在TE3/2/0/7的队列恢复;
TE3/2/0/7的队列数据包丢失,在G3/0/0/45的队列恢复,这是为什么?有什么影响?
远程镜像配置如下:
[MZYJL_Core_S10510X]dis mirroring-group all
Mirroring group 1:
 Type: Remote source Status: Active
 Mirroring port:
 Ten-GigabitEthernet1/2/0/17 Both Ten-GigabitEthernet1/2/0/18 Both Ten-GigabitEthernet1/2/0/19 Both Ten-GigabitEthernet1/2/0/20 Both Ten-GigabitEthernet1/2/0/21 Both Ten-GigabitEthernet1/2/0/22 Both Ten-GigabitEthernet1/2/0/23 Both Ten-GigabitEthernet1/2/0/24 Both Ten-GigabitEthernet2/2/0/17 Both Ten-GigabitEthernet2/2/0/18 Both Ten-GigabitEthernet2/2/0/19 Both Ten-GigabitEthernet2/2/0/20 Both Ten-GigabitEthernet2/2/0/21 Both Ten-GigabitEthernet2/2/0/22 Both Ten-GigabitEthernet2/2/0/23 Both Ten-GigabitEthernet2/2/0/24 Both Ten-GigabitEthernet3/2/0/17 Both Ten-GigabitEthernet3/2/0/18 Both Ten-GigabitEthernet3/2/0/19 Both Ten-GigabitEthernet3/2/0/20 Both Ten-GigabitEthernet3/2/0/21 Both Ten-GigabitEthernet3/2/0/22 Both Ten-GigabitEthernet3/2/0/23 Both Ten-GigabitEthernet3/2/0/24 Both Ten-GigabitEthernet4/2/0/17 Both Ten-GigabitEthernet4/2/0/18 Both Ten-GigabitEthernet4/2/0/19 Both Ten-GigabitEthernet4/2/0/20 Both Ten-GigabitEthernet4/2/0/21 Both Ten-GigabitEthernet4/2/0/22 Both Ten-GigabitEthernet4/2/0/23 Both Ten-GigabitEthernet4/2/0/24 Both Reflector port: Ten-GigabitEthernet3/2/0/6
 Remote probe VLAN: 4000
interface GigabitEthernet3/0/0/45
 port link-mode bridge
 port access vlan 4000
 undo stp enable
interface Ten-GigabitEthernet3/2/0/7
 speed 1000 undo
stp enable
日志信息如下:
%Oct 29 05:58:49:422 2023 MZYJL_Core_S10510X IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -MDC=1-Chassis=3-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet3/2/0/6 suddenly exceeds the threshold. Threshold=20000, current value=21090.
%Oct 29 05:58:53:595 2023 MZYJL_Core_S10510X IFNET/4/IF_EGRESS_DROP_RECOVER: -MDC=1-Chassis=3-Slot=0; Packet loss recovers in queue 2 of GigabitEthernet3/0/0/45.
%Oct 29 05:58:53:596 2023 MZYJL_Core_S10510X IFNET/4/IF_BOARD_EGRESS_DROP_RECOVER: -MDC=1-Chassis=3-Slot=0; Packet loss recovers on chassis 3 slot 0.
%Oct 29 05:58:59:741 2023 MZYJL_Core_S10510X IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -MDC=1-Chassis=3-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet3/2/0/6 suddenly drops below the lower threshold. Threshold=20000, current value=623.
%Oct 29 06:02:25:316 2023 MZYJL_Core_S10510X IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -MDC=1-Chassis=2-Slot=4; The incoming broadcast traffic of FortyGigE2/4/0/23 suddenly exceeds the threshold. Threshold=20000, current value=20949.
%Oct 29 06:02:35:602 2023 MZYJL_Core_S10510X IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -MDC=1-Chassis=2-Slot=4; The incoming broadcast traffic of FortyGigE2/4/0/23 suddenly drops below the lower threshold. Threshold=20000, current value=472.
%Oct 29 06:04:54:088 2023 MZYJL_Core_S10510X IFNET/4/IF_EGRESS_DROP: -MDC=1-Chassis=3-Slot=0; Packet loss occurs in queue 2 of GigabitEthernet3/0/0/45.
 %Oct 29 06:04:54:088 2023 MZYJL_Core_S10510X IFNET/4/IF_BOARD_EGRESS_DROP: -MDC=1-Chassis=3-Slot=0; Packet loss occurs on chassis 3 slot 0.
%Oct 29 06:05:11:784 2023 MZYJL_Core_S10510X IFNET/4/IF_EGRESS_DROP: -MDC=1-Chassis=3-Slot=2; Packet loss occurs in queue 2 of Ten-GigabitEthernet3/2/0/7.
%Oct 29 06:05:11:786 2023 MZYJL_Core_S10510X IFNET/4/IF_BOARD_EGRESS_DROP: -MDC=1-Chassis=3-Slot=2; Packet loss occurs on chassis 3 slot 2.
%Oct 29 06:06:14:049 2023 MZYJL_Core_S10510X IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -MDC=1-Chassis=3-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet3/2/0/6 suddenly exceeds the threshold. Threshold=20000, current value=20691.
%Oct 29 06:06:24:417 2023 MZYJL_Core_S10510X IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -MDC=1-Chassis=3-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet3/2/0/6 suddenly drops below the lower threshold. Threshold=20000, current value=512.
%Oct 29 06:08:18:326 2023 MZYJL_Core_S10510X IFNET/4/IF_EGRESS_DROP_RECOVER: -MDC=1-Chassis=3-Slot=2; Packet loss recovers in queue 2 of Ten-GigabitEthernet3/2/0/7.
%Oct 29 06:08:18:328 2023 MZYJL_Core_S10510X IFNET/4/IF_BOARD_EGRESS_DROP_RECOVER: -MDC=1-Chassis=3-Slot=2; Packet loss recovers on chassis 3 slot 2.
%Oct 29 06:08:54:447 2023 MZYJL_Core_S10510X IFNET/4/IF_EGRESS_DROP_RECOVER: -MDC=1-Chassis=3-Slot=0; Packet loss recovers in queue 2 of GigabitEthernet3/0/0/45.
TE3/2/0/6端口的传入广播流量超过了设定的阈值,导致出现了警告。这可能意味着网络中存在较多的广播流量。广播流量会在网络中传播并增加网络负载,如果超过了设定的阈值,可能会对网络性能产生一定的影响。
对于队列数据包丢失的情况,这可能是由于网络流量过大,导致交换机缓冲区无法及时处理所有的数据包,从而造成了队列中的数据包丢失。当一个队列的数据包丢失时,交换机会尝试将数据包发送到备用队列,以便恢复数据传输。因此,在G3/0/0/45和TE3/2/0/7之间的数据传输中,可能会出现数据包丢失和恢复的情况。
这些情况可能会影响网络的性能和数据传输的可靠性。建议您进一步分析网络流量情况,了解广播流量的来源,并尝试优化网络配置来减少广播流量和避免队列数据包丢失的情况。您可以考虑配置流量控制、调整队列大小、调整端口速率等措施来改善网络性能和减少数据丢失。
