大范围无线终端用户频繁异常下线,是什么问题
2023-10-29提问
  • 0收藏,581浏览
大范围无线终端用户频繁异常下线,是什么问题。Received deauthentication frame in Run state.(Reason Code:5025)
粉丝:4人 关注:0人
Received deauthentication frame in Run state(Reason Code:5025) 在运行状态下收到解除身份验证帧
这种情况是客户端主动要求断线,更新下客户端网卡驱动
看下空口利用率
无线协议规定的802.11 Deauth报文的Reason Code
CodeReason
0Reserved
1Unspecific Reason
2Previous authentication no longer valid
3Deauthenticated because sending STA is leaving (or has left) IBSS or ESS
4Disassociated due to inactivity
5Disassociated because AP is unable to handle all currently associated STAs
6Class 2 frame received from nonauthenticated STA
7Class 3 frame received from nonassociated STA
8Disassociated because sending STA is leaving (or has left) BSS
9STA requesting (re)association is not authenticated with responding STA
10Disassociated because the information in the Power Capability element is unacceptable
11Disassociated because the information in the Supported Channels element is unacceptable
12Reserved
13Invalid information element.
14Message integrity code (MIC) failure
154-Way Handshake timeout
16Group Key Handshake timeout
17Information element in 4-Way Handshake different from (Re)Association Request/Probe Response/Beacon frame
18Invalid group cipher or Association denied due to requesting STA not supporting all of the data rates in the BSSBasicRateSet parameter
19Invalid pairwise cipher
20Invalid AKMP
21Unsupported RSN information element version
22Invalid RSN information element capabilities
23IEEE 802.1X authentication failed
24Cipher suite rejected because of the security policy
25-31Reserved
32Disassociated for unspecified, QoS-related reason
33Disassociated because QoS AP lacks sufficient bandwidth for this QoS STA
34Disassociated because excessive number of frames need to be acknowledged, but are not acknowledged due to AP transmissions and/or poor channel conditions
35Disassociated because STA is transmitting outside the limits of its TXOPs
36Requested from peer STA as the STA is leaving the BSS (or resetting)
37Requested from peer STA as it does not want to use the mechanism
38Requested from peer STA as the STA received frames using the mechanism for which a setup is required
39Requested from peer STA due to timeout
45Peer STA does not support the requested cipher suite
45-65Reserved
535Reserved
大范围,手机电脑平板都有这种情况出现
来过就好 发表时间:2023-10-29
那看看ap的空口利用率,如果信号干扰大或者接入用户数多方面排查下
zhiliao_oQRyre 发表时间:2023-10-29
粉丝:3人 关注:0人
是什么终端,
