wa6520异常掉线
2023-10-30提问
  • 0收藏,430浏览
ap异常掉线重启上线ping不通其他网段、以及没有默认静态路由如图1-5
ap异常掉线如下
<XA_DC_N1_WX5540X_HA>dis wlan ap name CF2-3F-AP8 verbose
AP name                       : CF2-3F-AP8
AP ID                         : 73
AP group name                 : cf2_3f
State                         : Run
Backup type                   : Master
Ready-for-Switchover          : Ready
Online time                   : 0 days 11 hours 6 minutes 42 seconds
System uptime                 : 6 days 10 hours 19 minutes 34 seconds
Model                         : WA6520
Region code                   : CN
Region code lock              : Disabled
Serial ID                     :
MAC address                   :
IP address                    : 10.29.255.51
UDP control port number       : 43651
UDP data port number          : 43651
H/W version                   : Ver.A
S/W version                   : R2593P03
Boot version                  : 7.16
USB state                     : N/A
Power level                   : N/A
Power info                    : N/A
map file                      : N/A
Description                   : Not configured
Priority                      : 4
Echo interval                 : 10 seconds
Echo count                    : 3 counts
Keepalive interval            : 10 seconds
Discovery-response wait-time  : 2 seconds
Statistics report interval    : 50 seconds
Fragment size (data)          : 1500
Fragment size (control)       : 1450
MAC type                      : Local MAC & Split MAC
Tunnel mode                   : Local Bridging & 802.3 Frame & Native Frame
CAPWAP data-tunnel status     : Up
Discovery type                : Unknown
Retransmission count          : 3
Retransmission interval       : 5 seconds
Firmware upgrade              : Enabled
Sent control packets          : 22504
Received control packets      : 22504
Echo requests                 : 3996
Lost echo responses           : 0
Average echo delay            : 0
Last reboot reason            : User soft reboot
Latest IP address             : 10.29.255.51
Current AC IP                 : 10.29.255.254
Tunnel down reason            : Processed join request in Run state
Connection count              : 2
Backup IPv4                   : Not configured
Backup IPv6                   : Not configured
Ctrl-tunnel encryption        : Disabled
Ctrl-tunnel encryption state  : Not encrypted
Data-tunnel encryption        : Disabled
Data-tunnel encryption state  : Not encrypted
LED mode                      : Normal
Remote configuration          : Disabled
EnergySaving Level            : 0
AP type                       : Normal AP
Radio 1:
    BSSID                     : 28e4-2438-d1e0
    State                     : Up
    Type                      : 802.11ax(5GHz)
    Antenna type              : internal
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel bandwidth         : 20/40MHz
    Operating bandwidth       : 20/40MHz
    Secondary channel mode    : SCA
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    MIMO                      : 2*2
    Green-Energy-Management   : Disabled
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Supported
    STBC                      : Supported
    Operational VHT-MCS Set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS Set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel                   : 149(auto)
    Channel usage(%)          : 14
    Max power                 : 15 dBm
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Multicast             : Auto
        Supported             : 9, 18, 36, 48, 54 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Frame aging time in cache : 2000 ms
    Noise floor               : -95 dBm
    Protection mode           : cts-to-self
    MU-TxBF                   : Disabled
    SU-TxBF                   : Disabled
    Continuous mode           : N/A
    Client dot11ax-only       : Disabled
    Operational HE-MCS Set:
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9,10,11
                                NSS2 0,1,2,3,4,5,6,7,8,9,10,11
    OFDMA random access RUs   : Not Supported
    DL-OFDMA                  : Disabled
    UL-OFDMA                  : Disabled
    UL-MU-MIMO                : Disabled
    BSS-COLOR                 : Disabled
    TWT negotiation           : Enabled
    ATF                       : Disabled
    radar-detect switch       : Enabled
    HT protection mode        : No protection
Radio 2:
    BSSID                     : 28e4-2438-d1e8
    State                     : Up
    Type                      : 802.11n(2.4GHz)
    Channel bandwidth         : 20MHz
    Operating bandwidth       : 20MHz
    Secondary channel mode    : SCN
    MIMO                      : 2*2
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Supported
    STBC                      : Supported
    Channel                   : 11(auto)
    Channel usage(%)          : 36
    Max power                 : 10 dBm
    Preamble type             : Short
    Operational rate:
        Mandatory             : 11 Mbps
        Multicast             : Auto
        Supported             : 12, 18, 24, 36, 48, 54 Mbps
        Disabled              : 1, 2, 5.5, 6, 9 Mbps
    Distance                  : 1 km
    ANI                       : Enabled
    Noise floor               : -89 dBm
    ATF                       : Disabled
<XA>dis wlan ap statistics tunnel-down-record
AP name                        AP ID  Tunnel down at  Tunnel Down Reason                               Tunnel Down Count
CF2-3F-AP8                     73     10-29/22:22:19  Processed join request in Run state              1
一样的配置,一样的版本
大佬们,这是什么原因导致的
粉丝:158人 关注:8人
检查下链路问题
链路正常
zhiliao_4MMuPO 发表时间:2023-10-30
ap版本都是一样的吧,其他AP都正常? 找个正常的AP 互相换一下试试
zhiliao_sEUyB 发表时间:2023-10-30
z6Kl9 九段
粉丝:67人 关注:2人
排查一下链路
粉丝:23人 关注:0人
你把POE交换机接口下的port-isolate 去掉再看看
跟这个有关系吗
Qwj 二段
dis wlan ap all int 看一下接口协商速率
速率正常是1G
