WA4320-ACN-C-FIT改FAT模式后如何配置上网
2023-10-31提问
  • 0收藏,348浏览
手上有WA4320-ACN-C-FIT现已升级为FAT模式。现在需要接入网络中为手机提供无线上网功能,现有网络结构是:光猫>安全网关>三层交换机>二层交换机>PC 。 我想把WA4320接在二层交换机端口上 本段的IP是192.168.100.0, 网关在三层交换机上 没有开DHCP。请问我怎么配置WA4320 WEB或者命令行的配置谁能提供一下啊 万分感谢
粉丝:23人 关注:0人
巧了,我有一台,直接刷入或者你自己修改下里面的ssid和密码再刷入
version 5.20, Release 1509P01
sysname XUPE
clock timezone Beijing add 08:00:00
domain default enable system
telnet server enable
port-security enable
web idle-timeout 100
password-recovery enable
undo attack-defense tcp fragment enable
vlan 1
vlan 2
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
dhcp server ip-pool vlan2
network 172.10.10.0 mask 255.255.255.0
gateway-list 172.10.10.1
dns-list 223.5.5.5 114.114.114.114
expired day 0 hour 8
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$5h3z8h+g
authorization-attribute level 3
service-type telnet
service-type web
local-user xupe
password cipher $c$3$lyCelIV0w
service-type web
wlan rrm
dot11a mandatory-rate 6 12 24
dot11a supported-rate 9 18 36 48 54
dot11b mandatory-rate 1 2
dot11b supported-rate 5.5 11
dot11g mandatory-rate 1 2 5.5 11
dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 clear
ssid H3C
service-template enable
wlan service-template 2 crypto
ssid XUPE
cipher-suite ccmp
security-ie rsn
cwmp
undo cwmp enable
interface NULL0
interface Vlan-interface1
ip address dhcp-alloc
nat outbound
interface Vlan-interface2
ip address 172.10.10.1 255.255.255.0
interface WLAN-BSS2
port access vlan 2
port-security port-mode psk
port-security tx-key-type 11key
port-security preshared-key pass-phrase cipher $c$3$Q2A0euu+PrJBhiqIaAbsx8p1QLAZCtZ4Agb2M2k=
interface WLAN-BSS3
port access vlan 2
port-security preshared-key pass-phrase cipher $c$3$Ew60Z/hAuDdmUPUo5hQsdH5fpNyO5EgZcDKkRxw=
interface WLAN-BSS32
port link-type hybrid
port hybrid vlan 1 untagged
interface WLAN-BSS33
interface WLAN-Radio1/0/1
service-template 2 interface wlan-bss 2
interface WLAN-Radio1/0/2
service-template 2 interface wlan-bss 3
undo info-center enable
dhcp enable
arp-snooping enable
load xml-configuration
load tr069-configuration
user-interface con 0
user-interface vty 0 4
authentication-mode scheme
return
谢谢!
zhiliao_LEyKY 发表时间:2023-10-31
试了,可以连接手机,但是手机无法连接到三层交换机,加了一条172到上行网关的路由也不行 Please press ENTER. <XUPE>dis cur # version 5.20, Release 1509P01 # sysname XUPE # clock timezone Beijing add 08:00:00 # domain default enable system # telnet server enable # port-security enable # web idle-timeout 100 # password-recovery enable # undo attack-defense tcp fragment enable # vlan 1 # vlan 2 # domain system access-limit disable state active idle-cut disable self-service-url disable # dhcp server ip-pool vlan2 network 172.10.10.0 mask 255.255.255.0 gateway-list 172.10.10.1 dns-list 114.114.114.114 expired day 0 hour 8 # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$U383dX1KaEqrIDaGjj14Zz6vjJVFJfalqrZAFAg= authorization-attribute level 3 service-type telnet service-type web local-user xupe password cipher $c$3$d+ArFHlJci4bwoIzJ192wDN/yLE21WfGT1ID authorization-attribute level 3 service-type ssh telnet terminal service-type web # wlan rrm dot11a mandatory-rate 6 12 24 dot11a supported-rate 9 18 36 48 54 dot11b mandatory-rate 1 2 dot11b supported-rate 5.5 11 dot11g mandatory-rate 1 2 5.5 11 dot11g supported-rate 6 9 12 18 24 36 48 54 # wlan service-template 1 clear ssid H3C # wlan service-template 2 crypto ssid XUPE cipher-suite ccmp security-ie rsn service-template enable # cwmp undo cwmp enable # interface NULL0 # interface Vlan-interface1 ip address 192.168.100.1 255.255.255.0 undo dhcp select server global-pool # interface Vlan-interface2 ip address 172.10.10.1 255.255.255.0 # interface GigabitEthernet1/0/1 # interface WLAN-BSS2 port access vlan 2 port-security port-mode psk port-security tx-key-type 11key port-security preshared-key pass-phrase cipher $c$3$Q2A0euu+PrJBhiqIaAbsx8p1QLAZCtZ4Agb2M2k= # interface WLAN-BSS3 port access vlan 2 port-security port-mode psk port-security tx-key-type 11key port-security preshared-key pass-phrase cipher $c$3$Ew60Z/hAuDdmUPUo5hQsdH5fpNyO5EgZcDKkRxw= # interface WLAN-BSS32 port link-type hybrid port hybrid vlan 1 untagged # interface WLAN-BSS33 port link-type hybrid port hybrid vlan 1 untagged # interface WLAN-BSS34 port access vlan 2 port-security port-mode psk port-security tx-key-type 11key port-security preshared-key pass-phrase cipher $c$3$P2xmn999liuOuuyxeQ8d0YoR9rTA8aVNg4uf # interface WLAN-BSS35 port link-type hybrid port hybrid vlan 1 untagged port-security port-mode psk port-security tx-key-type 11key port-security preshared-key pass-phrase cipher $c$3$P2xmn999liuOuuyxeQ8d0YoR9rTA8aVNg4uf # interface WLAN-Radio1/0/1 service-template 2 interface wlan-bss 34 # interface WLAN-Radio1/0/2 service-template 2 interface wlan-bss 35 # ip route-static 172.10.10.0 255.255.255.0 192.168.100.254 # undo info-center enable # dhcp enable # arp-snooping enable # load xml-configuration # load tr069-configuration # user-interface con 0 user-interface vty 0 4 authentication-mode scheme # return
回复zhiliao_LEyKY:
我这个是nat模式啊,需要连接上层设备的话,你得写nat server了,自己后面做成二层模式,把网关放在上层设备上就行了
悲剧塔 发表时间:2023-10-31
粉丝:133人 关注:8人
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Wlan/WA/WA4300/?category=187037&subcategory=618797
zhiliao_LEyKY 知了小白
Please press ENTER.
<XUPE>dis cur
sysname XUPE
vlan 1
vlan 2
domain system
state active
idle-cut disable
user-group system
local-user admin
service-type telnet
service-type web
local-user xupe
service-type web
wlan rrm
ssid H3C
ssid XUPE
cipher-suite ccmp
security-ie rsn
cwmp
undo cwmp enable
interface NULL0
interface WLAN-BSS2
port access vlan 2
interface WLAN-BSS3
port access vlan 2
port access vlan 2
dhcp enable
arp-snooping enable
return
