H3C S5024PV5-EI-PWR 无法启动
2023-11-10提问
  • 0收藏,410浏览
风扇狂转,系统灯显示红色
<H3C>display log Log buffer: Enabled Max buffer size: 1024 Actual buffer size: 512 Dropped messages: 0 Overwritten messages: 0 Current messages: 7 %Dec 31 23:59:33:437 2012 H3C SYSLOG/6/SYSLOG_RESTART: System restarted -- H3C Comware Software. %Jan 1 00:01:40:215 2013 H3C IFNET/3/PHY_UPDOWN: Physical state on the interfac e GigabitEthernet1/0/11 changed to up. %Jan 1 00:01:40:218 2013 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the in terface GigabitEthernet1/0/11 changed to up. %Jan 1 00:01:45:785 2013 H3C LOGIN/5/LOGIN_FAILED: TTY failed to log in from au x0. %Jan 1 00:01:50:872 2013 H3C LOGIN/5/LOGIN_FAILED: TTY failed to log in from au x0. %Jan 1 00:01:57:043 2013 H3C DEV/2/TEMPERATURE_SHUTDOWN: Temperature is greater than the high-temperature shutdown threshold on slot 1 sensor hotspot 5. The sl ot will be powered off automatically. %Jan 1 00:02:06:670 2013 H3C SHELL/5/SHELL_LOGIN: admin logged in from aux0.
粉丝:17人 关注:9人
收集诊断信息文件反馈400协助处理定位是否为硬件问题,如果是硬件问题再走备件更换流程。
你好,请问这个诊断信息用什么命令?
中国人 发表时间:2023-11-10
dis diag
得闲饮酒725 发表时间:2023-11-10
粉丝:3人 关注:0人
硬件故障走备件更换吧
中国人 知了小白
