如何对交换机默认的管理口,单独写默认路由
2023-11-15提问
  • 0收藏,347浏览
blili 八段
粉丝:3人 关注:0人
管理口绑定vpn,静态路由加vpn实例实现
1.1.4  ip route-static
ip route-static命令用来配置静态路由。
undo ip route-static命令用来删除指定的静态路由。
ip route-static dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ nexthop-index index-string ] ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static dest-address { mask-length | mask } next-hop-address [ nexthop-index index-string ] [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address [ nexthop-index index-string ] [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static group group-name interface-type interface-number [ next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet } | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static  group group-name next-hop-address [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static group group-name vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
undo ip route-static { dest-address { mask-length | mask } | group group-name } [ interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
ip route-static { dest-address { mask-length | mask } | group group-name } vpn-instance d-vpn-instance-name [ preference preference ] [ tag tag-value ] [ description text ]
undo ip route-static { dest-address { mask-length | mask } | group group-name } [ vpn-instance d-vpn-instance-name ] [ preference preference ]
未配置静态路由。
dest-address:静态路由的目的IP地址,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
group group-name:指定静态路由配置组。group-name 表示配置组名称,为1~31个字符的字符串,区分大小写。
vpn-instance d-vpn-instance-name:指定目的VPN实例。d-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果指定目的VPN实例,但未指定next-hop-address参数,则静态路由将在目的VPN实例中查找出接口。如果指定目的VPN实例,且指定了next-hop-address参数,静态路由将根据配置的next-hop-address在目的VPN中查找出接口。
interface-type interface-number:指定静态路由的出接口类型和接口号。在指定静态路由的出接口类型和接口号时需要注意的事项,详见使用指导。
next-hop-address:指定路由的下一跳的IP地址,点分十进制格式。在指定路由的下一跳的IP地址时需要注意的事项,详见使用指导。
nexthop-index index-string:指定路由的下一跳的索引标识。index-string表示索引标识,为1~93个字符的字符串,不区分大小写。如果未指定本参数,静态路由采用出接口和下一跳的IP地址作为索引标识。去往同一目的地的多条路由,其下一跳的索引标识不能相同。
recursive-lookup host-route:指定静态路由只能迭代到主机路由。
backup-interface interface-type interface-number:备份出接口。对于备份出接口为非P2P类型的接口时(包括NBMA类型接口或广播类型接口),必须同时指定其对应的备份下一跳地址。interface-type interface-number为指定的接口类型和编号。
backup-nexthop backup-nexthop-address:备份下一跳地址。
bfd:使能BFD(Bidirectional Forwarding Detection,双向转发检测)功能,对静态路由下一跳的可达性进行快速检测,当下一跳不可达时可以快速切换到备份路由。
control-packet:通过BFD控制报文方式实现BFD功能。
bfd-source ip-address:BFD源IP地址。建议配置为Loopback接口IP地址。
echo-packet:通过BFD echo报文方式实现BFD功能。
permanent:指定为永久静态路由。指定本参数后,静态路由会一直生效,不受出接口状态的影响,即使在出接口down时,配置的永久静态路由仍然保持active状态。
track track-entry-number:将静态路由与Track项相关联,track-entry-number为Track项的序号,取值范围为1~1024。关于Track的详细介绍,请参见“可靠性配置指导”中的“Track”。
preference preference:指定静态路由的优先级,取值范围为1~255,缺省值为60。
tag tag-value:静态路由Tag值,用于标识该条静态路由,以便在路由策略中根据Tag对路由进行灵活的控制。tag-value的取值范围为1~4294967295,缺省值为0。关于路由策略的详细信息,请参见“三层技术-IP路由配置指导”中的“路由策略”。
recursive-lookup:开启静态路由下一跳循环迭代功能(即允许迭代到更大网段的路由)。如果不指定本参数,则表示关闭静态路由的下一跳循环迭代功能。
description text:配置的静态路由描述信息,取值范围为1~60个字符。除“?”外,可以包含空格等特殊字符。
如果目的IP地址和掩码都为0.0.0.0(或掩码为0),则配置的路由为缺省路由。当没有匹配的路由表项时,将使用缺省路由进行报文转发。
对不同的优先级配置,可采用不同的路由管理策略。例如,为同一目的地配置多条路由,如果指定相同的优先级,则实现路由负载分担;如果指定不同的优先级,则实现路由备份。
配置静态路由时,可根据实际需要指定出接口或下一跳地址。需要注意的是:
·     对于Null0接口,配置了出接口就不需要配置下一跳地址。
·     对于点到点接口,配置时可以只指定出接口,不指定下一跳地址。这样,即使对端地址发生了变化也无须改变配置。
·     对于NBMA、P2MP等接口,需要进行IP地址到链路层地址的映射,建议同时配置出接口和下一跳IP地址。
·     对于广播类型接口,需要通过下一跳IP地址来获取下一跳的物理地址,配置时需要指定出接口和下一跳IP地址。特殊情况下也可以不配置下一跳IP地址,比如VXLAN的跨VPN引流组网。
配置静态路由时需要注意的是:
·     路由震荡时,使能BFD检测功能可能会加剧震荡,需谨慎使用。关于BFD的详细介绍,请参考“可靠性配置指导”中的“BFD”。
·     如果Track模块通过NQA探测私网静态路由中下一跳的可达性,静态路由下一跳的VPN实例号与NQA测试组配置的实例号必须相同,才能进行正常的探测。
·     在静态路由进行迭代时,Track项监测的应该是静态路由真正的下一跳,而不是配置的下一跳。否则,可能导致错误地将有效路由判断为无效路由。
·     参数permanent不能和bfd、track一起进行配置。
粉丝:5人 关注:4人
绑定VPN实例,默认路由加实例
粉丝:154人 关注:1人
  • 方法一:您可以在交换机上创建一个VPN实例,将管理口绑定到该VPN实例上,然后在VPN实例中配置默认路由,指向管理网关。这样,管理口就可以通过VPN实例的路由表,与外部网络进行通信,而不影响交换机的全局路由表。您可以参考这里查看如何在交换机上配置VPN实例和管理口的详细步骤1
  • 方法二:您可以在交换机上创建一个VRF实例,将管理口绑定到该VRF实例上,然后在VRF实例中配置默认路由,指向管理网关。这样,管理口就可以通过VRF实例的路由表,与外部网络进行通信,而不影响交换机的全局路由表。您可以参考这里查看如何在交换机上配置VRF实例和管理口的详细步骤2
  • 方法三:您可以在交换机上创建一个VLAN,将管理口加入到该VLAN中,然后在VLAN接口上配置IP地址和默认路由,指向管理网关。这样,管理口就可以通过VLAN接口的路由表,与外部网络进行通信,而不影响交换机的全局路由表。您可以参考这里查看如何在交换机上配置VLAN和管理口的详细步骤3
您可以根据您的实际需求,选择适合您的方法,或者尝试其他的方法,以实现最佳的管理口配置效果。如果您想要了解更多关于H3C交换机的信息,您可以参考[这里]的产品介绍,或者[这里]的配置指导,或者[这里]的典型配置举例。
1、先创建vpn实例
2、管理口添加vpn实例
3、写带vpn实例的缺省路由
