H3C5560X-54C-EI从装ios后如何保存
2023-11-16提问
  • 0收藏,278浏览
7 个回答
粉丝:94人 关注:0人
不用保存 直接重启
zhiliao_XR2l7 知了小白
断电从起后就又起不来了
粉丝:171人 关注:8人
怎么升级的,过程看一下,不要删除启动文件啊
zhiliao_XR2l7 知了小白
1. Download image to flash 2. Select image to boot 3. Display all files in flash 4. Delete file from flash 5. Restore to factory default configuration 6. Enter BootRom upgrade menu 7. Skip current system configuration 8. Set switch startup mode 9. Set The Operating Device 0. Reboot Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format file system Ctrl+P: Change authentication for console login Ctrl+R: Download image to SDRAM and run Ctrl+C: Display Copyright Enter your choice(0-9):1
zhiliao_XR2l7 知了小白
1. Set TFTP protocol parameters 2. Set FTP protocol parameters 3. Set XMODEM protocol parameters 0. Return to boot menu Enter your choice(0-3): 1 1. Set TFTP protocol parameters 2. Set FTP protocol parameters 3. Set XMODEM protocol parameters 0. Return to boot menu Enter your choice(0-3): 1
zhiliao_XR2l7 知了小白
这个装完不起动,
zhiliao_XR2l7 知了小白
Ctrl+R: Download image to SDRAM and run 选这个装完可以启动,但机器一断电就不行了,flash里能看到装的系统文件
