MSR3610E SSH acl问题
2023-11-18提问
  • 0收藏,395浏览
配置命令ssh server acl 2100后,在该ACL范围内的终端使用SSH访问设备时被拒绝,显示连接超时,这是什么问题呢
配置信息:
<R_ZH_WL_H3610-02_CBRC>dis cu
version 9.1.041, Release 9119P16
sysname R_ZH_WL_H3610-02_CBRC
clock timezone GMT add 08:00:00
ip load-sharing mode per-flow src-ip global
ip netstream timeout active 60
ip netstream export host 10.192.31.37 9996
ip netstream export source interface GigabitEthernet0/0/1
lldp global enable
loopback-detection global enable vlan 1 to 4094
system-working-mode standard
password-recovery enable
vlan 1
stp region-configuration
region-name RegionWL
revision-level 1
active region-configuration
stp bpdu-protection
stp pathcost-standard dot1t
stp global enable
policy-based-route CBRC permit node 10
if-match acl 3000
apply default-output-interface GigabitEthernet0/0/0
interface NULL0
port link-mode route
description To_CBRC
combo enable copper
ip address 19.100.249.198 255.255.255.252
undo lldp enable
ip netstream inbound
nat outbound 3000
nat outbound 2050
description To_S_ZH_WL_H5130-02_G1/0/18
combo enable copper
ip address 19.100.193.97 255.255.255.248
interface GigabitEthernet0/0/2
port link-mode bridge
description #unused#
shutdown
interface GigabitEthernet0/0/3
shutdown
interface GigabitEthernet0/0/4
shutdown
interface GigabitEthernet0/0/5
shutdown
interface GigabitEthernet0/0/6
shutdown
interface GigabitEthernet0/0/7
shutdown
interface GigabitEthernet0/0/8
shutdown
interface GigabitEthernet0/0/9
shutdown
interface Ten-GigabitEthernet0/0/10
shutdown
interface Ten-GigabitEthernet0/0/11
shutdown
interface Ten-GigabitEthernet0/0/12
shutdown
security-zone name Local
security-zone name Trust
security-zone name DMZ
security-zone name Untrust
security-zone name Management
scheduler logfile size 16
line class console
user-role network-admin
line class vty
user-role network-operator
line con 0
authentication-mode scheme
idle-timeout 5 0
line vty 0 63
protocol inbound ssh
idle-timeout 5 0
command authorization
 ip route-static 10.0.0.0 8 19.100.193.98
ip route-static 19.10.250.0 24 19.100.249.197
ip route-static 19.10.251.0 24 19.100.249.197
ip route-static 19.100.246.0 24 19.100.249.197
ip route-static 100.100.60.1 32 19.100.193.98
info-center synchronous
info-center logging suppress duplicates
info-center format cmcc
info-center logbuffer size 1024
info-center loghost source GigabitEthernet0/0/1
info-center loghost 10.192.2.11
info-center source SHELL logbuffer deny
snmp-agent
snmp-agent local-engineid 800063A28080616C05066F00000001
snmp-agent community read beachina acl 2000
snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 10.192.31.36 params securityname beachina v2c
snmp-agent target-host trap address udp-domain 10.192.31.37 params securityname beachina v2c
snmp-agent target-host trap address udp-domain 10.192.31.43 params securityname beachina v2c
snmp-agent target-host trap address udp-domain 10.192.31.45 params securityname beachina v2c
snmp-agent target-host trap address udp-domain 10.192.31.47 params securityname beachina v2c
snmp-agent target-host trap address udp-domain 10.192.31.48 params securityname beachina v2c
snmp-agent trap source GigabitEthernet0/0/1
ssh server enable
ssh server acl 2100
ntp-service enable
ntp-service source GigabitEthernet0/0/1
ntp-service unicast-server 10.192.6.104
acl number 2000
rule 5 permit source 10.192.31.0 0.0.0.255
acl number 2050
rule 5 permit source 10.192.56.225 0
acl number 2100
rule 10 permit source 10.192.31.0 0.0.0.255
rule 20 permit source 10.191.0.0 0.0.255.255
acl advanced 3000
rule 5 permit ip source 10.192.56.225 0 destination 19.100.249.197 0
rule 10 permit ip source 19.100.193.97 0 destination 19.100.249.197 0
header login %
WARNING:Unauthorized access and use of this equipment will be vigorously prosecuted.
undo password-control aging enable
 undo password-control history enable
 password-control length 6
password-control login-attempt 3 exceed lock-time 10
password-control update-interval 0
password-control login idle-time 0
hwtacacs scheme acs
primary authentication 10.192.31.181
primary authorization 10.192.31.181
primary accounting 10.192.31.181
secondary authentication 10.192.31.182
secondary authorization 10.192.31.182
secondary accounting 10.192.31.182
key authentication cipher $c$3$tDjm0gxa8wRVgsxmfbk9PG2mU+G2NsX+T+GOj+M=
key authorization cipher $c$3$He1L2wVh+/2lyMUuRegIBV+FAjq7ZMyds35A3OQ=
key accounting cipher $c$3$J9OPAzf1wZJGVx8a7BOUryoz/s3t/jzcFAoakTQ=
user-name-format without-domain
nas-ip 19.100.193.97
radius scheme system
domain name nac
authentication login hwtacacs-scheme acs local
authorization login hwtacacs-scheme acs local
accounting login hwtacacs-scheme acs
authorization command hwtacacs-scheme acs
domain name system
domain default enable nac
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user cnadmin1 class manage
password hash $h$6$7ng/a+kKeymvesMw$tQdrTWJSCbcTDifON818HmRVDbJ2t8ZR+xFp25TVJMMW2c0NhVSOQ6VfJxb+kLjXLDqv5Svz/S1zdAAfPR1LqQ==
service-type ssh terminal
authorization-attribute user-role level-15
local-user cnuser1 class manage
password hash $h$6$4QVTGVh97QIyxB58$87MgiBHel++tqYcwO9xGk+MxQoB/O44Adxrwl56YmQa+fvMwcCvUbTASHSure/a89tBjxmLJIHwjjIj55JkdPA==
local-user cnuser2 class manage
password hash $h$6$weRfqTBH/n7kmYon$AQdhSpOJuIWsFM1q0hU1FJpmrPnkDIOpD0U3x8NwVhCDAtvAxe2IN8Dl6dJdIcgfXvyCyUYAhel7B5otul5m9Q==
local-user cnuser3 class manage
password hash $h$6$s2sfJxaaVPHZbcNU$k1VMt+Qz8L27lL0D0/v83YMyLiuUuvVxCbMvdnNld4Y+WdU39d2V7cBysj97NQuHh7uYTXdwexEcx8/1A+YKiQ==
security-zone intra-zone default permit
return
粉丝:6人 关注:43人
piing能通吗
可以Ping通
zhiliao_9o0zUC 发表时间:2023-11-18
好像确实也没什么问题,去掉ACL就能ssh上吗
会了我也不说 发表时间:2023-11-18
是的,另外一台设备配置相同的ACL就能行,很奇怪
