HCL模拟器AC三层旁挂+本地转发
2023-11-19提问
  • 0收藏,530浏览
终端连接上AP,但是获取不到IP地址
zhiliao_A1UXkT 知了小白
sysname AC
wlan global-configuration
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
xbar load-single
password-recovery enable
lpu-type f-series
vlan 1
vlan 10
vlan 100
wlan service-template ser-test
ssid test
vlan 40
client forwarding-location ap vlan 40
service-template enable
interface NULL0
interface Vlan-interface10
ip address 10.10.10.2 255.255.255.0
interface Vlan-interface100
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet1/0/0
port link-mode bridge
combo enable fiber
port access vlan 10
combo enable fiber
port link-type trunk
port trunk permit vlan 1 40 100 200
combo enable fiber
scheduler logfile size 16
line class aux
user-role network-operator
line class console
user-role network-admin
line class tty
line class vty
line aux 0
line con 0
line vty 0 31
ip route-static 0.0.0.0 0 192.168.100.254
domain system
domain default enable system
user-group system
local-user admin class manage
password hash $h$6$FrYN3iPdausoOA4E$JC56qGXcvoXUyd6Pt8+BFZaGKMC6mgCfPdKXjHAl4k+lYTSQM8KiRj5tGR1e1C2/GILVySCLlBHHneVcaQP+AA==
service-type telnet http https
authorization-attribute user-role level-15
ip http enable
ip https enable
wlan auto-ap enable
wlan auto-persistent enable
wlan ap-group default-group
vlan 1
wlan ap-group test
vlan 1
ap 2a76-adb5-0700
ap ap1
ap-model WA6320-HCL
map-configuration flash:/apcfg.txt
radio 1
radio enable
service-template ser-test vlan 40
radio 2
gigabitethernet 1
wlan virtual-ap-group default-virtualapgroup
wlan ap 2a76-adb5-0700 model WA6320-HCL
serial-id H3C_2A-76-AD-B5-07-00
vlan 1
radio 1
client-proximity-sensor enable
radio 2
gigabitethernet 1
client-proximity-sensor report-ac enable
client-proximity-sensor rssi-change-threshold 10
return
可以获取
可以看下这个,https://blog.csdn.net/weixin_44410393/article/details/133949759,我原本也以为是模拟器bug,后面发现是自己AP型号选错了,改了后就可以
zhiliao_gYtmbe 发表时间:2023-12-15
[AC]dis current-configuration # version 7.1.064, Alpha 7165 # sysname AC # wlan global-configuration # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1 # xbar load-single password-recovery enable lpu-type f-series # vlan 1 # vlan 10 # vlan 100 # vlan 200 # wlan service-template huawei ssid Huawei vlan 100 client forwarding-location ap vlan 100 service-template enable # wlan service-template ser-test ssid caiyaobin vlan 100 client forwarding-location ap vlan 100 service-template enable # interface NULL0 # interface Vlan-interface1 ip address 192.168.1.200 255.255.255.0 # interface Vlan-interface10 ip address 10.1.1.1 255.255.255.0 # interface GigabitEthernet1/0/0 port link-mode bridge port link-type trunk port trunk permit vlan all combo enable fiber # interface GigabitEthernet1/0/1 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/2 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/3 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/4 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/5 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/6 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/7 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/8 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/9 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/10 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/11 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/12 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/13 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/14 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/15 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/16 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/17 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/18 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/19 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/20 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/21 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/22 port link-mode bridge combo enable fiber # interface GigabitEthernet1/0/23 port link-mode bridge combo enable fiber # interface Ten-GigabitEthernet1/0/24 port link-mode bridge combo enable fiber # interface Ten-GigabitEthernet1/0/25 port link-mode bridge combo enable fiber # interface Ten-GigabitEthernet1/0/26 port link-mode bridge combo enable fiber # interface Ten-GigabitEthernet1/0/27 port link-mode bridge combo enable fiber # scheduler logfile size 16 # line class aux user-role network-operator # line class console user-role network-admin # line class tty user-role network-operator # line class vty user-role network-operator # line aux 0 user-role network-operator # line con 0 user-role network-admin # line vty 0 31 user-role network-operator # ip route-static 0.0.0.0 0 10.1.1.2 # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$s+S3luQ3MHJtCYPp$pbHUk/fSiFYcjDrNxtFcW+QXOGZmokhRm1Twmdpr8zJEiqzPIN66a1i4+kSEmUWFC31FO1YbhgQ9Oja1Q6i8jA== service-type ssh terminal http https authorization-attribute user-role level-15 authorization-attribute user-role network-operator # ip http enable # wlan auto-ap enable wlan auto-persistent enable # wlan ap-group default-group vlan 1 # wlan ap-group one_floor firmware-upgrade enable vlan 1 ap 541a-72cb-0200 ap-model WA6320-HCL radio 1 radio enable service-template huawei vlan 100 radio 2 radio enable gigabitethernet 1 # wlan ap-group test vlan 1 ap 541a-74b4-0300 ap ap1 ap-model WA6320-HCL map-configuration flash:/apcfg.txt radio 1 radio enable service-template huawei vlan 100 radio 2 gigabitethernet 1 # wlan virtual-ap-group default-virtualapgroup # wlan ap 541a-72cb-0200 model WA6320-HCL serial-id H3C_54-1A-72-CB-02-00 vlan 1 radio 1 radio enable service-template huawei vlan 100 radio 2 radio enable service-template huawei vlan 100 gigabitethernet 1 # wlan ap 541a-74b4-0300 model WA6320-HCL serial-id H3C_54-1A-74-B4-03-00 vlan 1 radio 1 radio enable service-template huawei radio 2 radio enable service-template huawei gigabitethernet 1 # return
WXT 一段
配置发一下看看
发了你看看
zhiliao_A1UXkT 发表时间:2023-11-19
