H3C S5500 连接傻瓜路由器上网~~菜鸟问题
2017-09-08提问
  • 1收藏,2571浏览
拓扑图
打算让VLAN 下的电脑上网,例如接在VLAN101下的172.10.1.2的电脑上网。23接口在VLAN1000上,接口配置192.168.100.2上联路由器LAN口 192.168.100.1,路由器已经写好反向路由,电脑172.10.1.2可以ping通路由器192.168.100.1,但是无法上网 ,求大神指点,是不是没有写NAT?如果是的话需要怎么写?谢谢
<H3C>system-view
[H3C]dis  cur
[H3C]dis  current-configuration
 version 5.20, Release 2220P02
 sysname H3C
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 telnet server enable
 password-recovery enable
vlan 1
vlan 5
 description senlingongan
vlan 6
 description guoshuiju
vlan 8
vlan 15
vlan 24
vlan 32
vlan 40
vlan 48
vlan 64
vlan 72
vlan 80
vlan 88
 description changzhuang
vlan 96
vlan 101
vlan 104
vlan 107 to 108
vlan 112
vlan 116
vlan 120
vlan 136
 description huaishu
vlan 144
vlan 1000
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$1fGhpqoqHGGHc/06wDufhF9+g/QFRififoxAKSqw
 authorization-attribute level 3
 service-type telnet terminal
 service-type web
interface NULL0
interface Vlan-interface1
interface Vlan-interface5
 ip address 172.10.5.1 255.255.255.0
interface Vlan-interface6
 ip address 172.10.6.1 255.255.248.0
interface Vlan-interface8
 ip address 172.10.8.1 255.255.248.0
interface Vlan-interface15
 ip address 172.10.56.1 255.255.248.0
interface Vlan-interface24
 ip address 172.10.24.1 255.255.248.0
interface Vlan-interface32
 ip address 172.10.32.1 255.255.248.0
interface Vlan-interface40
 ip address 172.10.40.1 255.255.248.0
interface Vlan-interface48
 ip address 172.10.48.1 255.255.248.0
interface Vlan-interface64
 ip address 172.10.64.1 255.255.248.0
interface Vlan-interface72
 ip address 172.10.72.1 255.255.248.0
interface Vlan-interface80
 ip address 172.10.80.1 255.255.248.0
interface Vlan-interface88
 ip address 172.10.88.1 255.255.248.0
interface Vlan-interface96
 ip address 172.10.96.1 255.255.248.0
interface Vlan-interface101
 ip address 172.10.1.1 255.255.255.0
interface Vlan-interface104
 ip address 172.10.104.1 255.255.248.0
interface Vlan-interface107
 ip address 172.10.7.1 255.255.255.0
interface Vlan-interface112
 ip address 172.10.112.1 255.255.248.0
interface Vlan-interface116
 ip address 172.10.16.1 255.255.248.0
interface Vlan-interface120
 ip address 172.10.120.1 255.255.248.0
interface Vlan-interface136
 ip address 172.10.136.1 255.255.248.0
interface Vlan-interface144
 ip address 172.10.144.1 255.255.248.0
interface Vlan-interface1000
 ip address 192.168.100.2 255.255.255.0
 port access vlan 101
 port access vlan 5
 arp rate-limit disable
 port access vlan 107
interface GigabitEthernet1/0/4
 port access vlan 120
interface GigabitEthernet1/0/5
 port access vlan 112
interface GigabitEthernet1/0/6
 port access vlan 136
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
 port access vlan 72
interface GigabitEthernet1/0/9
 port access vlan 96
interface GigabitEthernet1/0/10
 port access vlan 48
interface GigabitEthernet1/0/11
 port access vlan 104
interface GigabitEthernet1/0/12
 port access vlan 116
interface GigabitEthernet1/0/13
 port access vlan 88
interface GigabitEthernet1/0/14
 port access vlan 8
interface GigabitEthernet1/0/15
 port access vlan 144
interface GigabitEthernet1/0/16
 port access vlan 80
interface GigabitEthernet1/0/17
 port access vlan 32
interface GigabitEthernet1/0/18
 port access vlan 6
interface GigabitEthernet1/0/19
 port access vlan 64
interface GigabitEthernet1/0/20
 port access vlan 40
 port auto-power-down
interface GigabitEthernet1/0/21
 port access vlan 24
interface GigabitEthernet1/0/22
 port access vlan 15
interface GigabitEthernet1/0/23
 port access vlan 1000
interface GigabitEthernet1/0/24
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
interface GigabitEthernet1/0/25
 shutdown
interface GigabitEthernet1/0/26
 shutdown
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
 ip route-static 0.0.0.0 255.255.255.0 192.168.100.1
 ip route-static 172.10.1.0 255.255.255.0 192.168.100.1
 load xml-configuration
user-interface aux 0
user-interface vty 0 15
 authentication-mode scheme
return
路由器是tp-link的路由器,5500上的这边的配置没有啥问题阿,是不是需要看看tp-link怎么配置的。
粉丝:94人 关注:0人
tp问题
