s5560组播不能转发
2023-11-28提问
  • 1收藏,386浏览
aseter 零段
两个s5560的交换机背靠背连接,发送组播业务,不能转发,求助
交换机配置如下: 1.配置 vlan VLAN ID :3 IPv4 address :10.145.1.254 IPv4 subnet mask :255.255.255.0 VLAN ID :4 IPv4 address :10.10.2.49 IPv4 subnet mask :255.255.255.0 2.默认网关 ip route - static 0.0.0.0010.10.2.50 3.开启组播路由 multicast routing 4.开启 pim 协议 interface Vlan -interface4 pim sm 5.开启 igmp 协议 interface Vlan -interface3 igmp enable igmp version 3 interface Vlan -interface4 igmp enable igmp version 3 6.开启 igmp - snooping vlan 3 igmp - snooping enable igmp - snooping drop - unknown vlan 4 igmp - snooping enable igmp - snooping drop - unknown 7.设置静态 rp pim static - rp 10.10.2.49 auto - rp enable 组播路由如下 H3C] dis pim routing - table Totl 2(*, G ) entries ;1( S , G ) entry (*,230.0.0.11) RP :10.10.2.49( local ) Protocol : pim - sm , Flag : WC UpTime :00:45:23 Upstream interface : Register -Tunnel0 Upstream neighbor : NULL RPF prime neighbor : NULL ownstream interface ( s ) information : Total number of downstreams :1 1: Vlan -interface4 Protocol : pim - sm , UpTime :00:45:23, Expires :00:03:07 (*,239.255.255.250) RP :10.10.2.49( local ) Protocol : pim - sm , Flag : WC pTime :16:04:37 Upstream interface : Register -Tunnel0 Upstream neighbor : NULL RPF prime neighbor : NULL Downstream interface ( s ) information : Total number of downstreams :1 1: Vlan -interface4 Protocol : pim - sm , UpTime :00:46:50, Expires :00:02:39 (10.148.3.19,239.255.255:250) RP :10.10.2.49( local ) Protocol : pim - sm , Flag : RPT SPT 2MSDP ACT UpTime :15:04:25 Upstream interface : Vlan -interface4 Upstream neighbor :10.10.2.50 RPF prime neighbor :10.10.2.50 Downstream interface ( s ) information : None
粉丝:144人 关注:0人
您好,参考配置
1.14  IGMP Snooping典型配置举例
1.14.1  基于VLAN的组策略及模拟主机加入配置举例
·            图1-4所示,Router A通过GigabitEthernet1/0/2接口连接组播源(Source),通过GigabitEthernet1/0/1接口连接Switch A;Router A上运行IGMPv2,Switch A上运行版本2的IGMP Snooping,并由Router A充当IGMP查询器。
·            通过配置,使Host A和Host B能且只能接收发往组播组224.1.1.1的组播数据,并且当Host A和Host B发生意外而临时中断接收组播数据时,发往组播组224.1.1.1组播数据也能不间断地通过Switch A的接口GigabitEthernet1/0/3和GigabitEthernet1/0/4转发出去;同时,使Switch A将收到的未知组播数据直接丢弃,避免在其所属的VLAN 100内广播。
图1-4 基于VLAN的组策略及模拟主机加入配置组网图
(1)       配置IP地址
请按照图1-4配置各接口的IP地址和子网掩码,具体配置过程略。
(2)       配置Router A
# 使能IP组播路由,在接口GigabitEthernet1/0/2上使能PIM-DM,并在接口GigabitEthernet1/0/1上使能IGMP。
[RouterA] multicast routing
[RouterA-mrib] quit
[RouterA-GigabitEthernet1/0/1] igmp enable
[RouterA-GigabitEthernet1/0/2] pim dm
(3)       配置Switch A
# 全局使能IGMP Snooping。
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
# 创建VLAN 100,把端口GigabitEthernet1/0/1到GigabitEthernet1/0/4添加到该VLAN中;在该VLAN内使能IGMP Snooping,并开启丢弃未知组播数据报文功能。
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[SwitchA-vlan100] igmp-snooping enable
[SwitchA-vlan100] igmp-snooping drop-unknown
[SwitchA-vlan100] quit
# 配置组播组过滤器,以限定VLAN 100内的主机只能加入组播组224.1.1.1。
[SwitchA] acl basic 2001
[SwitchA-acl-ipv4-basic-2001] rule permit source 224.1.1.1 0
[SwitchA-acl-ipv4-basic-2001] quit
[SwitchA-igmp-snooping] group-policy 2001 vlan 100
# 在GigabitEthernet1/0/3和GigabitEthernet1/0/4上分别配置模拟主机加入组播组224.1.1.1。
[SwitchA] interface gigabitethernet 1/0/3
[SwitchA-GigabitEthernet1/0/3] igmp-snooping host-join 224.1.1.1 vlan 100
[SwitchA-GigabitEthernet1/0/3] quit
[SwitchA] interface gigabitethernet 1/0/4
[SwitchA-GigabitEthernet1/0/4] igmp-snooping host-join 224.1.1.1 vlan 100
[SwitchA-GigabitEthernet1/0/4] quit
假设组播源分别向组播组224.1.1.1和224.2.2.2发送的组播数据,Host A和Host B也都申请加入这两个组播组。
# 显示Switch A上VLAN 100内动态IGMP Snooping转发表的信息。
[SwitchA] display igmp-snooping group vlan 100
Total 1 entries.
VLAN 100: Total 1 entries.
  (0.0.0.0, 224.1.1.1)
    Host slots (0 in total):
    Host ports (2 in total):
      GE1/0/3                             (00:03:23)
      GE1/0/4                             (00:04:10)
由此可见,Host A和Host B所在的端口GigabitEthernet1/0/4和GigabitEthernet1/0/3均已加入组播组224.1.1.1,但都未加入组播组224.2.2.2,这表明组播组过滤器已生效。
图看不见,可以再给发一下吗?
aseter 发表时间:2023-11-28
粉丝:119人 关注:1人
https://www.h3c.com/cn/d_201412/847515_30005_0.htm
参考配置举例
