华三交换机
2023-11-30提问
  • 0收藏,319浏览
配置vpn的时候提示vpn-table is full
按照步骤重启了吗
查看一下是否工作在 Multi-Instance CE模式下 dis switch-mode The current system mode is Multi-Instance CE mode. Number of VLANs: 1024 Number of VPN-Instances: 15 Max number of IPv4 unicast route entries: 15360 Max number of IPv4 multicast route entries: 512 Max number of IPv6 unicast route entries: 0 The system mode which will take effect after reboot is Multi-Instance CE mode.
zhiliao_1uFsi 发表时间:2023-11-30
zhiliao_NGOKLl 知了小白
已经试过switch-mode mce 还是不行
