IS-IS网络中,L1级的路由器在连l1-2级路由器的时候没有产生缺省路由
2023-12-03提问
  • 0收藏,289浏览
r6和r7是L1级路由,可以获取到L1级其他路由器的明细路由,但是获取不到L2级路由信息,连L1级的缺省路由都没有,各位大神请问这是系统bug吗?
<r3>dis cu
 version 7.1.064, Release 0427P22
 sysname r3
isis 1
 is-level level-2
 network-entity 10.0000.0000.0001.00
 address-family ipv4 unicast
  import-route direct
  import-route ospf 1
ospf 1 router-id 3.3.3.3
 import-route direct
 import-route isis 1
 area 0.0.0.0
  network 3.3.3.3 0.0.0.0
  network 10.0.2.0 0.0.0.255
  network 10.0.3.0 0.0.0.255
 ip ttl-expires enable
 system-working-mode standard
 xbar load-single
 password-recovery enable
 lpu-type f-series
vlan 1
interface Serial1/0
interface Serial2/0
interface Serial3/0
interface Serial4/0
interface NULL0
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 10.0.2.3 255.255.255.0
interface GigabitEthernet0/1
 combo enable copper
 ip address 10.0.3.3 255.255.255.0
interface GigabitEthernet0/2
 combo enable copper
 ip address 10.0.5.3 255.255.255.0
 isis enable 1
R5:
[r5]dis cu
 sysname r5
isis 1
 network-entity 10.0000.0000.0002.00
 sysid r5
 xbar load-single
 lpu-type f-series
vlan 1
interface Serial1/0
interface Serial2/0
interface Serial3/0
interface Serial4/0
interface NULL0
interface LoopBack0
 ip address 5.5.5.5 255.255.255.255
 isis enable 1
interface LoopBack1
 ip address 192.168.10.1 255.255.255.0
 isis enable 1
interface LoopBack2
 ip address 192.168.12.1 255.255.255.0
 isis enable 1
interface LoopBack3
 isis enable 1
interface LoopBack4
 ip address 192.168.13.1 255.255.255.0
 isis enable 1
 combo enable copper
 ip address 10.0.5.5 255.255.255.0
 isis enable 1
 combo enable copper
 ip address 10.0.6.5 255.255.255.0
 isis enable 1
 combo enable copper
 ip address 10.0.7.5 255.255.255.0
 isis enable 1
R6:
<r6>  DIS CU
 sysname r6
isis 1
 is-level level-1
 network-entity 10.0000.0000.0003.00
 xbar load-single
 lpu-type f-series
vlan 1
interface Serial1/0
interface Serial2/0
interface Serial3/0
interface Serial4/0
interface NULL0
interface LoopBack0
 ip address 6.6.6.6 255.255.255.255
 isis enable 1
interface LoopBack1
 ip address 192.168.100.1 255.255.255.0
 isis enable 1
interface LoopBack2
 ip address 192.168.101.1 255.255.255.0
 isis enable 1
interface LoopBack3
 ip address 192.168.102.1 255.255.255.0
 isis enable 1
interface LoopBack4
 ip address 192.168.103.1 255.255.255.0
 isis enable 1
 combo enable copper
 ip address 10.0.6.6 255.255.255.0
 isis enable 1
R6的路由表:
<r6>DIS IP routing-table
Destinations : 29       Routes : 29
Destination/Mask   Proto   Pre Cost        NextHop         Interface
0.0.0.0/32         Direct  0   0           127.0.0.1       InLoop0
5.5.5.5/32         IS_L1   15  10          10.0.6.5        GE0/0
6.6.6.6/32         Direct  0   0           127.0.0.1       InLoop0
10.0.5.0/24        IS_L1   15  20          10.0.6.5        GE0/0
10.0.6.0/24        Direct  0   0           10.0.6.6        GE0/0
10.0.6.6/32        Direct  0   0           127.0.0.1       InLoop0
10.0.6.255/32      Direct  0   0           10.0.6.6        GE0/0
10.0.7.0/24        IS_L1   15  20          10.0.6.5        GE0/0
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.1/32       Direct  0   0           127.0.0.1       InLoop0
127.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
192.168.10.0/24    IS_L1   15  10          10.0.6.5        GE0/0
192.168.12.0/24    IS_L1   15  10          10.0.6.5        GE0/0
192.168.13.0/24    IS_L1   15  10          10.0.6.5        GE0/0
192.168.100.0/24   Direct  0   0           192.168.100.1   Loop1
192.168.100.1/32   Direct  0   0           127.0.0.1       InLoop0
192.168.100.255/32 Direct  0   0           192.168.100.1   Loop1
192.168.101.0/24   Direct  0   0           192.168.101.1   Loop2
192.168.101.1/32   Direct  0   0           127.0.0.1       InLoop0
192.168.101.255/32 Direct  0   0           192.168.101.1   Loop2
192.168.102.0/24   Direct  0   0           192.168.102.1   Loop3
192.168.102.1/32   Direct  0   0           127.0.0.1       InLoop0
192.168.102.255/32 Direct  0   0           192.168.102.1   Loop3
192.168.103.0/24   Direct  0   0           192.168.103.1   Loop4
192.168.103.1/32   Direct  0   0           127.0.0.1       InLoop0
192.168.103.255/32 Direct  0   0           192.168.103.1   Loop4
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
<r6>
在IS-IS网络中,L1和L2级的路由器之间连接时,L1级路由器不会产生缺省路由。这是因为在IS-IS协议中,L1级路由器只负责在同一级内部进行路由信息交换,不会向L2级路由器传递任何L1级的路由信息。因此,L1级路由器不会形成默认路由条目到L2级路由器。
正常来说,有外部路由引入时,因为L2路由信息不会传给L1,所以L1-2路由器会传一个L1的缺省路由给L1路由器吗?
东溪 发表时间:2023-12-03
