防火墙F1000-日志解析
  • 0收藏,428浏览
%Dec  8 16:07:31:278 2023 FW SSHS/6/SSHS_DISCONNECT: SSH user ubnt (IP: 118.45.72.178) disconnected from the server.
%Dec  8 16:07:31:277 2023 FW SSHS/6/SSHS_LOG: Disconnecting: Too many authentication failures for ubnt.
%Dec  8 16:07:31:277 2023 FW SSHS/6/SSHS_AUTH_EXCEED_RETRY_TIMES: SSH user ubnt (IP: 118.45.72.178) failed to log in, because the number of authentication attempts exceeded the upper limit.
%Dec  8 16:07:31:277 2023 FW SSHS/6/SSHS_LOG: Authentication failed for ubnt from 118.45.72.178 port 61803 because of invalid username or wrong password .
%Dec  8 16:04:00:660 2023 FW FILTER/6/FILTER_ZONE_IPV4_EXECUTION: SrcZoneName(1025)=Trust;DstZoneName(1035)=Untrust;Type(1067)=ACL;SecurityPolicy(1072)=Trust_Untrust;RuleID(1078)=1;Protocol(1001)=TCP;Application(1002)=https;SrcIPAddr(1003)=10.0.18.17;SrcPort(1004)=53438;SrcMacAddr(1021)=b044-2c43-0020;DstIPAddr(1007)=101.36.166.9;DstPort(1008)=443;MatchCount(1069)=30;Event(1048)=Permit;
%Dec  8 16:04:00:656 2023 FW FILTER/6/FILTER_ZONE_IPV4_EXECUTION: SrcZoneName(1025)=Trust;DstZoneName(1035)=Untrust;Type(1067)=ACL;SecurityPolicy(1072)=Trust_Untrust;RuleID(1078)=1;Protocol(1001)=UDP;Application(1002)=general_udp;SrcIPAddr(1003)=10.0.51.22;SrcPort(1004)=7973;SrcMacAddr(1021)=b044-2c43-0020;DstIPAddr(1007)=58.59.49.234;DstPort(1008)=7573;MatchCount(1069)=39;Event(1048)=Permit;
%Dec  8 16:04:00:655 2023 FW FILTER/6/FILTER_ZONE_IPV4_EXECUTION: SrcZoneName(1025)=Trust;DstZoneName(1035)=Untrust;Type(1067)=ACL;SecurityPolicy(1072)=Trust_Untrust;RuleID(1078)=1;Protocol(1001)=TCP;Application(1002)=other;SrcIPAddr(1003)=10.0.51.68;SrcPort(1004)=60667;SrcMacAddr(1021)=b044-2c43-0020;DstIPAddr(1007)=220.243.190.102;DstPort(1008)=443;MatchCount(1069)=22;Event(1048)=Permit;
%Dec  8 16:04:00:654 2023 FW FILTER/6/FILTER_ZONE_IPV4_EXECUTION: SrcZoneName(1025)=Untrust;DstZoneName(1035)=Local;Type(1067)=ACL;SecurityPolicy(1072)=ĬuleID(1078)=0;Protocol(1001)=TCP;Application(1002)=invalid;SrcIPAddr(1003)=182.40.32.112;SrcPort(1004)=443;SrcMacAddr(1021)=a01c-8dd4-d943;DstIPAddr(1007)=123.125.144.2;DstPort(1008)=62044;MatchCount(1069)=1;Event(1048)=Permit;
防火墙系统版本 7.1,麻烦解释下上下这些日志的作用,如何关闭下面日志在syslog的输出
粉丝:35人 关注:3人
安全策略下rule里面的logging enable取消
能不能设置log记录级别呢,怎么设置
zhiliao_NRaCeN 发表时间:2023-12-08
RBM_P[F1090_S]info-center source default logbuffer level ? alert Action must be taken immediately (severity=1) critical Critical conditions (severity=2) debugging Debug-level messages (severity=7) emergency System is unusable (severity=0) error Error conditions (severity=3) informational Informational messages (severity=6) notification Normal but significant conditions (severity=5) warning Warning conditions (severity=4)
城管六分队 发表时间:2023-12-08
粉丝:8人 关注:0人
1.第一条日志是SSH用户ubnt(IP: 118.45.72.178)从服务器断开连接的记录。原因是该用户的认证尝试次数超过了上限,导致无法登录。日志级别是6,表示通知信息。
2.第二至第五条日志是防火墙对不同安全域之间的流量进行过滤的记录。日志中包含了源域名、目的域名、安全策略、规则ID、协议、应用、源IP地址、源端口、源MAC地址、目的IP地址、目的端口、匹配次数和事件等信息。日志级别也是6,表示通知信息。
