MSR2600-10配置不了WEB访问
2023-12-12提问
  • 0收藏,314浏览
黄生 一段
粉丝:1人 关注:1人
[H3C]dis cu
 version 5.20, Release 2516P15
 sysname H3C
 domain default enable system
 dar p2p signature-file flash:/p2p_default.mtd
 port-security enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$Q6QRHuL/bjSYKv7xazuQhsqw7NuoaL9p
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
interface Virtual-Ethernet1
 ip address 192.168.2.1 255.255.255.0
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
 port link-mode bridge
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
 snmp-agent
 snmp-agent local-engineid 800063A20394282E9C4CCE
 snmp-agent sys-info version v3
 ip https enable
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
[H3C]
黄生 一段
粉丝:1人 关注:1人
误打误撞搞定了。这个是配置文件,希望对大家有帮助!
[H3C]dis cu
version 5.20, Release 2516P29
sysname H3C
dns proxy enable
acl number 2000
rule 1000 permit source 192.168.100.0 0.0.0.255
vlan 1
vlan 10
domain system
state active
idle-cut disable
dhcp server ip-pool vlan10 extended
network ip range 192.168.100.2 192.168.100.254
network mask 255.255.255.0
gateway-list 192.168.100.1
dns-list 114.114.114.114
user-group system
local-user admin
password cipher $c$3$4pJVTpl2OUltjvbyMLqcIQAla7kdpd3c
service-type web
interface Aux0
async mode flow
link-protocol ppp
async mode protocol
link-protocol ppp
interface NULL0
interface Vlan-interface10
ip address 192.168.100.1 255.255.255.0
dhcp server apply ip-pool vlan10
nat outbound 2000
ip address 192.168.1.56 255.255.255.0
undo dhcp select server global-pool
dns server 192.168.0.1
ip address dhcp-alloc
port access vlan 10
port access vlan 10
port access vlan 10
port access vlan 10
port access vlan 10
port access vlan 10
ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/0 192.168.1.1
dhcp enable
ip https enable
nms primary monitor-interface GigabitEthernet0/0
return
[H3C]
四段
粉丝:0人 关注:9人
浏览器登录的时候手动在地址前面加个https://试一下
ping 不通就登录不了
黄生 发表时间:2023-12-12
ping不通肯定登录不了
发表时间:2023-12-12
误打误撞搞定了
黄生 发表时间:2023-12-12
