S5310 同一个vlan1网段的 两台PC可以互ping,但是无法ping通vlan
2023-12-14提问
  • 0收藏,275浏览
vlan1 配置了 192.168.208.254 255.255.255.0
PC1配置了     192.168.208.10  255.255.255.0   192.168.208.1
PC2配置了     192.168.208.20 255.255.255.0
现在PC1和PC2之间可以互ping
PC1和PC2均无法ping通  vlan1 192.168.208.254 这个地址
端口都是开启的 UP状态
4 个回答
粉丝:1人 关注:2人
你把PC1的网关192.168.208.1改成192.168.208.254试试
不行,PC1改成192.168.208.254也ping不通,
忘记说了环境是在HCL模拟器上的
我在交换机B上ping自己 192.168.208.254 是能ping通的
[H3C]DIS CU
version 7.1.075, Alpha 7571
 sysname H3C
 irf mac-address persistent timer
 irf auto-update enable
 irf auto-merge enable
 undo irf link-delay
 irf member 1 priority 1
 system-working-mode standard
 xbar load-single
 password-recovery enable
 lpu-type f-series
vlan 1
interface NULL0
interface Vlan-interface1
ip address 192.168.208.254 255.255.255.0
 port link-mode bridge
 combo enable fiber
 combo enable fiber
 combo enable copper
 interface GigabitEthernet1/0/4
 combo enable copper
interface GigabitEthernet1/0/5
 combo enable fiber
interface GigabitEthernet1/0/6
 combo enable fiber
interface M-GigabitEthernet0/0/0
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class tty
line class vty
line aux 0 user-role
# line con 0
line vty 0 63 user-role network-operator
domain name system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
 role name level-4
 description Predefined level-4 role
role name level-5 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
 role name level-10
 description Predefined level-10 role
 role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
 return
交换机配置发出来
配置已发在2楼,第一次用知了不是很熟悉。
zhiliao_lllTH9 发表时间:2023-12-14
粉丝:25人 关注:7人
不要用DIY设备做实验啊,直接用预设的交换机。
