H3C模拟器DIY设备疑问
2023-12-14提问
  • 0收藏,365浏览
在使用H3C模拟器的DIY了一台名为DIY_S1224R_1的交换机,
将这台交换机的vlan1 的IP 地址设置为192.168.208.254 255.255.255.0 并执行了undo shutdown 命令。
交换机上端口3口和口都使用电口,且都执行了undo shutdown 命令
交换机下连两台CNMS_10和CNMS_20,
CNMS_10 IP 地址设置为192.168.208.10 255.255.255.0
CNMS_20 IP 地址设置为192.168.208.10 255.255.255.0
两台CNMS_10和CNMS_20可以互ping
但是都ping不到交换机的vlan 1 ip192.168.208.254
同时还发现DIY了一台名为DIY_S1224R_1的交换机, 无法开启http 和https
[H3C]DIS CU
version 7.1.075, Alpha 7571
 sysname H3C
 irf mac-address persistent timer
 irf auto-update enable
 irf auto-merge enable
 undo irf link-delay
 irf member 1 priority 1
 system-working-mode standard
 xbar load-single
 password-recovery enable
 lpu-type f-series
vlan 1
interface NULL0
interface Vlan-interface1
ip address 192.168.208.254 255.255.255.0
 port link-mode bridge
 combo enable fiber
 combo enable fiber
 combo enable copper
 interface GigabitEthernet1/0/4
 combo enable copper
interface GigabitEthernet1/0/5
 combo enable fiber
interface GigabitEthernet1/0/6
 combo enable fiber
interface M-GigabitEthernet0/0/0
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class tty
line class vty
line aux 0 user-role
# line con 0
line vty 0 63 user-role network-operator
domain name system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
 role name level-4
 description Predefined level-4 role
role name level-5 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
 role name level-10
 description Predefined level-10 role
 role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
 return
不要用diy的交换机模拟,直接用自带的交换机模拟即可。
好吧,实在找不到原因,也就放弃diy了,谢谢。
zhiliao_lllTH9 发表时间:2023-12-15
heam 四段
粉丝:1人 关注:9人
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Switches/Catalog/S1200/S1216[S1216R][S1224][S1224R]/
1224的应该都是傻瓜的呀,可以小程序"新华三终端服务"问下客服,这应该是智能终端系列的产品;
H3C模拟器里没有傻瓜式交换机,DIY出来的交换机可以划分VLAN,应该不是傻瓜式交换机,我只是命名为1224,ping不通的问题也是在模拟器上的问题。
