交换机日志
2023-12-20提问
  • 0收藏,742浏览
这些日志是什么意思?
%Jan  7 13:23:56:408 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP_RECOVER: Packet loss recovers in queue 2 of GigabitEthernet2/0/4.
%Jan  7 13:23:56:408 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP_RECOVER: Packet loss recovers in queue 5 of GigabitEthernet2/0/3.
%Jan  7 13:23:56:408 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP_RECOVER: Packet loss recovers in queue 2 of GigabitEthernet2/0/3.
%Jan  7 13:23:56:408 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP_RECOVER: Packet loss recovers in queue 2 of GigabitEthernet2/0/2.
%Jan  7 13:23:56:407 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP_RECOVER: Packet loss recovers in queue 5 of GigabitEthernet2/0/1.
%Jan  7 13:23:56:407 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP_RECOVER: Packet loss recovers in queue 2 of GigabitEthernet2/0/1.
%Jan  7 13:23:49:587 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: -Slot=1; Packet loss occurs in queue 2 of GigabitEthernet1/0/21.
%Jan  7 13:23:49:587 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: -Slot=1; Packet loss occurs in queue 2 of GigabitEthernet1/0/17.
%Jan  7 13:23:49:586 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: -Slot=1; Packet loss occurs in queue 2 of GigabitEthernet1/0/16.
%Jan  7 13:23:49:586 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: -Slot=1; Packet loss occurs in queue 2 of GigabitEthernet1/0/15.
%Jan  7 13:23:49:689 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD_RESUME: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/11 drops below the lower threshold. Threshold=100, value=0, interval=10s.
%Jan  7 13:23:48:686 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD_RESUME: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/8 drops below the lower threshold. Threshold=100, value=0, interval=10s.
%Jan  7 13:23:48:668 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD_RESUME: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/7 drops below the lower threshold. Threshold=100, value=0, interval=10s.
%Jan  7 13:23:47:696 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD_RESUME: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/6 drops below the lower threshold. Threshold=100, value=0, interval=10s.
%Jan  7 13:23:47:681 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD_RESUME: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/5 drops below the lower threshold. Threshold=100, value=0, interval=10s.
%Jan  7 13:23:46:718 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD_RESUME: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/3 drops below the lower threshold. Threshold=100, value=0, interval=10s.
%Jan  7 13:23:46:668 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD_RESUME: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/1 drops below the lower threshold. Threshold=100, value=0, interval=10s.
%Jan  7 13:23:39:700 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/11 exceeds the upper threshold. Threshold=1000, value=1132, interval=10s.
%Jan  7 13:23:38:720 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/8 exceeds the upper threshold. Threshold=1000, value=1131, interval=10s.
%Jan  7 13:23:38:674 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/7 exceeds the upper threshold. Threshold=1000, value=1105, interval=10s.
%Jan  7 13:23:37:688 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/6 exceeds the upper threshold. Threshold=1000, value=1134, interval=10s.
%Jan  7 13:23:37:677 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/5 exceeds the upper threshold. Threshold=1000, value=1134, interval=10s.
%Jan  7 13:23:36:701 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/3 exceeds the upper threshold. Threshold=1000, value=1138, interval=10s.
%Jan  7 13:23:36:670 2021 judalou-ip250 IFMON/4/IFMON_OUTPUT_JAM_DISCARD: The number of outgoing packets lost due to network congestion on GigabitEthernet2/0/1 exceeds the upper threshold. Threshold=1000, value=1125, interval=10s.
%Jan  7 13:23:35:394 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of Ten-GigabitEthernet2/0/26.
%Jan  7 13:23:35:392 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of GigabitEthernet2/0/11.
%Jan  7 13:23:35:391 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of GigabitEthernet2/0/10.
%Jan  7 13:23:35:391 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of GigabitEthernet2/0/9.
%Jan  7 13:23:35:391 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 5 of GigabitEthernet2/0/8.
%Jan  7 13:23:35:391 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of GigabitEthernet2/0/8.
%Jan  7 13:23:35:390 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of GigabitEthernet2/0/7.
%Jan  7 13:23:35:390 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of GigabitEthernet2/0/6.
%Jan  7 13:23:35:390 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 5 of GigabitEthernet2/0/5.
%Jan  7 13:23:35:390 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of GigabitEthernet2/0/5.
%Jan  7 13:23:35:389 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of GigabitEthernet2/0/4.
%Jan  7 13:23:35:389 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 5 of GigabitEthernet2/0/3.
%Jan  7 13:23:35:389 2021 judalou-ip250 IFNET/4/IF_EGRESS_DROP: Packet loss occurs in queue 2 of GigabitEthernet2/0/3.
粉丝:145人 关注:1人
这是利率超过接口限速的、和恢复的日志
会导致丢包造成网络中断吗
zhiliao_XRtQYG 发表时间:2023-12-20
粉丝:0人 关注:6人
这个告警解决了吗 什么问题呢
