MSR56-60 用户流量排行问题
2023-12-23提问
  • 0收藏,352浏览
MSR56-60路由器系统版本是最新Version 7.1.064, Release 6728P26只要一打开用户流量排行,ipoed进程就占用一半CPU资源,关掉,ipoed进程还是一样占用CPU一半资源,另外一台设备系统版本是Version 7.1.064, Release 6728P25,就没有出现这里的问题,我把整体配置文件发出来,请各位帮忙优化一下,是什么原因导致ipoed进程一直占用CPU一半资源不释放,本人不是专业网工,大部分配置都是依赖于Web页面配置,设备已过保没法找400,请各位大佬担待,谢谢各位大佬,谢谢
 version 7.1.064, Release 6728P26
 sysname H3C
 clock timezone Beijing add 08:00:00
 clock protocol ntp
 undo resource-monitor output syslog snmp-notification netconf-event
 security-zone intra-zone default permit
 security-policy disable
 dialer-group 1 rule ip permit
 ip load-sharing mode per-flow src-ip global
 nat alg h323
 nat alg ils
 nat alg mgcp
 nat alg sccp
 nat alg tftp
 dhcp enable
 dhcp server always-broadcast
 dns proxy enable
 system-working-mode standard
 password-recovery enable
vlan 1
dhcp server ip-pool lan1
 gateway-list 192.168.1.1
 network 192.168.1.0 mask 255.255.255.0
 address range 192.168.1.51 192.168.1.254
 dns-list 192.168.1.1
 expired day 8
controller Cellular2/0/0
controller Cellular2/0/1
interface Aux0/0/1
interface Dialer0
 mtu 1480
 ppp chap password cipher XXX
 ppp chap user XXX
 ppp ipcp dns admit-any
 ppp ipcp dns request
 ppp pap local-user XXX password cipher XXX
 dialer bundle enable
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 5
 ip address ppp-negotiate
 tcp mss 1440
 packet-filter name GigabitEthernet2/0/0 inbound
 nat outbound
interface NULL0
interface Vlan-interface1
 description LAN-interface
 mtu 1480
 tcp mss 1440
 ip subscriber l2-connected enable
 ip subscriber initiator dhcp enable
 ip subscriber initiator unclassified-ip enable
 ip subscriber dhcp domain ipoeenabledomain
 ip subscriber unclassified-ip domain ipoeenabledomain
interface GigabitEthernet2/0/0
 port link-mode route
 description Multiple_Line1
 combo enable copper
 pppoe-client dial-bundle-number 0
interface GigabitEthernet2/0/1
 description Multiple_Line2
 combo enable copper
 ip last-hop hold
interface GigabitEthernet2/0/2
 description Multiple_Line3
 combo enable copper
 ip last-hop hold
interface GigabitEthernet2/0/3
 description Multiple_Line4
 combo enable copper
 ip last-hop hold
interface GigabitEthernet2/5/0
 port link-mode bridge
interface GigabitEthernet2/5/1
interface GigabitEthernet2/5/2
interface GigabitEthernet2/5/3
interface GigabitEthernet2/5/4
interface GigabitEthernet2/5/5
interface GigabitEthernet2/5/6
interface GigabitEthernet2/5/7
interface GigabitEthernet2/5/8
interface GigabitEthernet2/5/9
interface GigabitEthernet2/5/10
interface GigabitEthernet2/5/11
interface GigabitEthernet2/5/12
interface GigabitEthernet2/5/13
interface GigabitEthernet2/5/14
interface GigabitEthernet2/5/15
interface GigabitEthernet2/5/16
interface GigabitEthernet2/5/17
interface GigabitEthernet2/5/18
interface GigabitEthernet2/5/19
interface GigabitEthernet2/5/20
interface GigabitEthernet2/5/21
interface GigabitEthernet2/5/22
interface GigabitEthernet2/5/23
interface M-GigabitEthernet0
 ip address 192.168.0.1 255.255.255.0
object-policy ip Any-Any
 rule 65533 inspect 8048_url_profile_global disable
 rule 65534 pass
security-zone name Local
security-zone name Trust
 import interface Vlan-interface1
security-zone name DMZ
security-zone name Untrust
 import interface Dialer0
 import interface GigabitEthernet2/0/1
 import interface GigabitEthernet2/0/2
 import interface GigabitEthernet2/0/3
security-zone name Management
zone-pair security source Any destination Any
 object-policy apply ip Any-Any
zone-pair security source Local destination Trust
 packet-filter name SWXWSGL
zone-pair security source Local destination Untrust
zone-pair security source Trust destination Local
zone-pair security source Untrust destination Local
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class tty
line class vty
line aux 0
line con 0
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 Dialer0
 info-center loghost 127.0.0.1 port 3301
 info-center source CFGLOG loghost level informational
performance-management
 ssh user admin service-type all authentication-type password
 ntp-service enable
 ntp-service unicast-server ***.***
acl advanced name SWXWSGL
 rule 1 permit ip
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control update-interval 0
 password-control login idle-time 0
authorization-attribute idle-cut 5 1
authentication ipoe none
authorization ipoe none
accounting ipoe none
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 service-type ftp
 service-type ssh telnet terminal http https
 security-enhanced level 1
 session statistics enable
 ip http enable
url-filter category custom severity 65535
traffic-policy
 rule 1 name web_AppTraffRank
  application app http
dac log-collect service dpi traffic enable
dac traffic-statistic application enable
dac storage service dpi traffic limit hold-time 1
dac storage service traffic limit hold-time 1
return
粉丝:6人 关注:5人
一般不是版本的问题,后续版本都是在之前的版本上优化的,找个时间取消流量排行的配置,一般不建议用,保存配置重启恢复看看
您好,首先感谢您的回复,我试过恢复配置文件,但只要一打开用户流量排行,ipoed进程就启动直接吃掉cpu一半资源,打开上网行为管理,网址日志,应用流量排行都没事。
TingLoft 发表时间:2023-12-23
回复TingLoft:
这种一般就要后台收诊断去看了呀,目前您过保的话建议您不使用这个功能
Super_King 发表时间:2023-12-23
粉丝:8人 关注:0人
我看到您的配置文件,发现您的路由器使用了IPoE业务,这可能是导致CPU占用率高的原因之一。IPoE业务是一种基于IP地址的用户接入方式,它需要路由器对用户的IP地址进行认证、授权、计费等操作,这些操作会消耗CPU的资源。您可以尝试以下方法来优化您的配置:
1. 限制IPoE用户的数量,避免过多的用户同时接入造成CPU压力。
2. 优化IPoE用户的地址分配,使用固定的地址池或者预分配的地址,减少动态地址分配的开销。
3. 优化IPoE用户的认证方式,使用基于MAC地址的认证或者Portal认证,避免使用基于DHCP的认证,因为DHCP报文会增加CPU的处理负载。
4. 优化IPoE用户的计费方式,使用基于流量的计费或者基于时长的计费,避免使用基于会话的计费,因为会话的建立和维护会占用CPU的资源。
5. 优化IPoE用户的策略控制,使用基于用户组的策略或者基于业务的策略,避免使用基于用户的策略,因为用户的策略会增加CPU的匹配次数。
您好,首先感谢您的回复,请问配置文件里面那一部分是属于IPoE业务,麻烦您指点一下,我好研究官方文档,谢谢
