G1/0/15为WAN口,自动获取IP
G1/0/8-G1/0/11为LAN口,PC接在1/0/8,自动获取到了IP地址192.168.2.100,PC ping不通192.168.1.1,路由器上可以ping通192.168.1.1,路由器也可以ping通192.168.2.100
下面是G1/0/15端口信息
[H3C]dis interface GigabitEthernet 1/0/15
GigabitEthernet1/0/15
Current state: UP
Line protocol state: UP
Description: GigabitEthernet1/0/15 Interface
Bandwidth: 1000000 kbps
Internet address: 192.168.1.214/24 (DHCP-allocated)
IP packet frame type: Ethernet II, hardware address: 600b-0319-e2a7
IPv6 packet frame type: Ethernet II, hardware address: 600b-0319-e2a7
Media type: twisted pair, loopback: not set, promiscuous mode: not set
Port priority: 0
1000Mbps-speed mode, full-duplex mode
Flow-control is not enabled
The Maximum Frame Length is 9216
Last link flapping: 0 hours 17 minutes 52 seconds
Peak input rate: 430 bytes/sec, at 2023-12-26 01:49:39
Peak output rate: 52 bytes/sec, at 2023-12-26 01:59:14
Last 300 second input: 2 packets/sec 325 bytes/sec 0%
Last 300 second output: 0 packets/sec 33 bytes/sec 0%
Input (total): 2603 packets, 489302 bytes
225 unicasts, 972 broadcasts, 1406 multicasts, 0 pauses
Input (normal): 2603 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
Output (total): 227 packets, 18663 bytes
212 unicasts, 15 broadcasts, 0 multicasts, 0 pauses
Output (normal): 227 packets, - bytes
0 lost carrier, - no carrier
[H3C]
这是路由表
[H3C]dis ip routing-table
Destinations : 13 Routes : 13
0.0.0.0/0 Static 70 0 192.168.1.1 GE1/0/15
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.0/24 Direct 0 0 192.168.1.214 GE1/0/15
192.168.1.0/32 Direct 0 0 192.168.1.214 GE1/0/15
192.168.1.214/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.214 GE1/0/15
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
[H3C]
下面是配置文件
[H3C]DIS CU
version 7.1.064, Release 0605P18
sysname H3C
dhcp enable
password-recovery enable
vlan 1
vlan 10
dhcp server ip-pool vlan10
gateway-list 192.168.2.1
network 192.168.2.0 mask 255.255.255.0
address range 192.168.2.100 192.168.2.200
dns-list 192.168.2.1
interface NULL0
interface Vlan-interface10
ip address 192.168.2.1 255.255.255.0
dhcp server apply ip-pool vlan10
interface GigabitEthernet1/0/0
port link-mode route
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
ip address dhcp-alloc
interface GigabitEthernet1/0/8
port link-mode bridge
port access vlan 10
interface GigabitEthernet1/0/9
port access vlan 10
interface GigabitEthernet1/0/10
port access vlan 10
interface GigabitEthernet1/0/11
port access vlan 10
interface M-GigabitEthernet0
scheduler logfile size 16
line class console
user-role network-admin
line class vty
user-role network-operator
line con 0
line vty 0 63
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
return
(0)
楼上说的对,没有nat的原因,没有nat,你数据包源ip是192.169.2.0地址段,外网没有192.168.2.0的路由的,所以用pcping不同,其实你pc连外网都ping不同
(0)
有没有什么思路没
1.1在哪?
电脑就一个网卡吧?
(0)
WAN口自动获取IP后,网关是192.168.1.1
电脑是普通的单网卡
15口配置一下nat outbound
没有这个功能。。。。 [H3C-GigabitEthernet1/0/15]? Gigabitethernet_l3 interface view commands: arp ARP module bandwidth Specify the expected bandwidth bfd BFD module cfd Connectivity Fault Detection (CFD) module dampening Set port dampening attributes ddns Dynamic Domain Name System (DDNS) module default Restore the default settings description Describe the interface dhcp DHCP module diagnostic-logfile Diagnostic log file configuration display Display current system information dldp DLDP module dns Domain Name System (DNS) module duplex Status of duplex enable Enable functions end Alias for 'return' esmc Ethernet Synchronous Message Channel exit Alias for 'quit' flow-control Enable flow control function igmp Internet Group Management Protocol (IGMP) module ip Specify IP configuration ipsec IP Security module ipv6 Specify IPv6 configuration isis Configure interface parameters for IS-IS jumboframe Specify jumbo frame forwarding lacp Configure LACP protocol link-aggregation Specify link aggregation group configuration information link-delay Set the physical state change suppression lldp Link Layer Discovery Protocol (802.1ab) local-proxy-arp Specify local proxy ARP function for same interface local-proxy-nd Local ND proxy function lock Lock the current line logfile Log file configuration loopback Specify loopback of current port mirroring-group Specify mirroring group mld Multicast Listener Discovery (MLD) module monitor System monitor mpls Multiprotocol Label Switching (MPLS) module mtu Specify Maximum Transmission Unit(MTU) of the interface multicast Multicast module no Alias for 'undo' ntp-service Network Time Protocol (NTP) module oam OAM module ospf OSPF module ospfv3 OSPFv3 interface commands packet-filter Packet filter settings pim Protocol Independent Multicast (PIM) module ping Ping function port Specify a port portal Portal authentication module proxy-arp Specify proxy ARP function proxy-nd ND proxy function ptp Precision Time Protocol module qos Quality of Service (QoS) module quit Exit from current command view repeat Repeat executing history commands reset Reset operation return Exit to User View rip Configure interface parameters for RIP ripng Configure interface parameters for RIPng rmon RMON module rsvp Resource Reservation Protocol (RSVP) module save Save current configuration security-logfile Security log file configuration show Alias for 'display' shutdown Shut down the interface speed Specify speed of current port sub-interface Specify subinterface configuration information synce Synchronous Ethernet settings synchronous Specify the synchronous mode tcp Specify TCP parameters of the interface tracert Tracert function undo Cancel current setting vrrp Virtual Router Redundancy Protocol(VRRP) module web-redirect Web redirection function write Alias for 'save' xconnect Bind a VSI [H3C-GigabitEthernet1/0/15]
接口需要配置nat才行,或者终端也获取192.168.1段的IP
不支持nat。不知道咋整
终端也从光猫获取地址吧
G1/0/15从光猫获取地址,获取的地址是192.168.1.214/24 ,网关192.168.1.1
配置了策略路由也不行 [H3C]acl advanced 3101 [H3C-acl-ipv4-adv-3101]rule permit ip [H3C-acl-ipv4-adv-3101]quit [H3C]policy-based-route aaa permit node 5 [H3C-pbr-aaa-5]if-match acl 3101 [H3C-pbr-aaa-5]apply next-hop 192.168.1.1 [H3C]ip local policy-based-route aaa
配置了ACL和包过滤也不行
[H3C]dis acl all
Advanced IPv4 ACL 3000, 1 rule,
ACL"s step is 5
rule 0 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.1 0
[H3C-GigabitEthernet1/0/15]dis this
packet-filter 3000 outbound
return
G1/0/15不支持NAT
arp ARP module
bfd BFD module
dhcp DHCP module
dldp DLDP module
end Alias for "return"
exit Alias for "quit"
no Alias for "undo"
oam OAM module
ospf OSPF module
ping Ping function
port Specify a port
rmon RMON module
show Alias for "display"
write Alias for "save"
xconnect Bind a VSI
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
谢谢
