WX2540E AC控制器和WA4320-ACN-E瘦AP
  • 0收藏,334浏览
WX2540E AC控制器和WA4320-ACN-E瘦AP,旁路在核心上。配置完成后 ap获取不到ip地址 dhcp是在ac控制器上做的 不知道配置哪里出现问题了。
ac配置#
[AC-3]dis cu
 version 5.20, ESS 3703P61
 sysname AC-3
 dhcp relay server-group 1 ip 172.20.1.2
 dhcp relay server-group 2 ip 172.30.1.2
 domain default enable system
 telnet server enable
 port-security enable
 wlan auto-ap enable
 wlan auto-persistent enable
 password-recovery enable
vlan 1
vlan 20
vlan 30
vlan 50
vlan 60
vlan 70
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool pipe
 network 172.20.0.0 mask 255.255.0.0
 gateway-list 172.20.1.1
 dns-list 202.99.96.68
 expired unlimited
dhcp server ip-pool pipe-guest
 network 172.30.0.0 mask 255.255.0.0
 gateway-list 172.30.1.1
 expired unlimited
user-group system
 group-attribute allow-guest
local-user admin
 password cipher
 authorization-attribute level 3
 service-type ssh telnet
 service-type web
 service-type ftp
 service-type web
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 crypto
 ssid TJISV
 bind WLAN-ESS 0
 cipher-suite ccmp
 security-ie rsn
 security-ie wpa
 service-template enable
wlan service-template 2 crypto
 ssid TJISV-Guest
 bind WLAN-ESS 1
 cipher-suite ccmp
 security-ie rsn
 security-ie wpa
 key-derivation sha1-and-sha256
wlan service-template 3 crypto
 ssid PIPE
 bind WLAN-ESS 2
 cipher-suite wep40
 cipher-suite ccmp
 security-ie rsn
 wep default-key 1 wep40 raw-key cipher $c$3$n1B+VM7HMi/RFqVWPEi6nCgoCLIhzXE0PVi7UeQ=
 wep default-key 2 wep40 raw-key cipher $c$3$7OFryabbmENjjR0fWFZYA3v5ukBJjS0Dsn9kKgo=
 wep key-id 2
wlan ap-group default_group
 ap 222
 ap 74ea-cb88-92e0
 ap 74ea-cb88-93a0
 ap 74ea-cb88-9440
 ap 74ea-cb88-95e0
 ap 74ea-cb88-9740
 ap 74ea-cb88-9e20
 ap 74ea-cb88-9ec0
 ap 9428-2ef0-bda0
 ap 9428-2ef0-cfc0
 ap 9428-2ef1-1780
 ap 9428-2ef1-2ba0
 ap 9428-2ef1-42a0
 ap 9c06-1bd8-d3a0
 ap 9c06-1bd9-0200
 ap 9c06-1bd9-0440
 dot11a service-template 1
 dot11a service-template 3
 dot11bg service-template 1
 dot11bg service-template 3
 dot11a radio enable
 dot11bg radio enable
interface Cellular1/0/1
 async mode protocol
 link-protocol ppp
interface NULL0
interface Vlan-interface1
interface Vlan-interface20
 ip address 172.20.1.2 255.255.0.0
interface Vlan-interface30
 ip address 172.30.1.2 255.255.0.0
 port link-mode route
 ip address 172.16.100.19 255.255.0.0
 undo dhcp select server global-pool
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
 port link-mode bridge
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
 port trunk permit vlan all
 dhcp-snooping trust
 dhcp-snooping information enable
interface GigabitEthernet1/0/4
interface WLAN-ESS0
 port link-type hybrid
 port hybrid vlan 1 50 70 untagged
 port hybrid pvid vlan 50
 port-security port-mode psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase cipher $c$3$d599mjyWKo1W+cMeTYlZRkeHplsiRdf5b/QE
interface WLAN-ESS1
 port hybrid vlan 1 60 untagged
 port hybrid pvid vlan 60
 port-security preshared-key pass-phrase cipher $c$3$TRBeAAWZLqCArshjNiFmjvP7Ug+2ica1ZlMp
interface WLAN-ESS2
 port hybrid vlan 1 20 30 untagged
 port hybrid pvid vlan 20
 dhcp-snooping trust
 port-security preshared-key pass-phrase cipher $c$3$1qhp9jdG3JnQEHM4f7ekJELjsMIirkyVy+6VbQ==
wlan ap 222 model WA4320-ACN-E id 2
 serial-id auto
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 74ea-cb88-92e0 model WA4320-ACN-E id 8
 serial-id 219801A0X78177E00201
 backup-ac ip 172.20.1.1
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 74ea-cb88-93a0 model WA4320-ACN-E id 5
 serial-id 219801A0X78177E00207
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 74ea-cb88-9440 model WA4320-ACN-E id 12
 serial-id 219801A0X78177E00212
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 74ea-cb88-95e0 model WA4320-ACN-E id 10
 serial-id 219801A0X78177E00225
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 74ea-cb88-9740 model WA4320-ACN-E id 6
 serial-id 219801A0X78177E00236
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 74ea-cb88-9e20 model WA4320-ACN-E id 11
 serial-id 219801A0X78177E00291
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 74ea-cb88-9ec0 model WA4320-ACN-E id 7
 serial-id 219801A0X78177E00296
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 9428-2ef0-bda0 model WA4320-ACN-E id 15
 serial-id 219801A0X78178E00399
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 9428-2ef0-cfc0 model WA4320-ACN-E id 14
 serial-id 219801A0X78178E00544
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 9428-2ef1-1780 model WA4320-ACN-E id 16
 serial-id 219801A0X78178E01118
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 9428-2ef1-2ba0 model WA4320-ACN-E id 1
 serial-id 219801A0X78178E01279
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 9428-2ef1-42a0 model WA4320-ACN-E id 13
 serial-id 219801A0X78178E01463
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 9c06-1bd8-d3a0 model WA4320-ACN-E id 9
 serial-id 219801A0X78174E02381
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 9c06-1bd9-0200 model WA4320-ACN-E id 3
 serial-id 219801A0X78174E02752
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap 9c06-1bd9-0440 model WA4320-ACN-E id 4
 serial-id 219801A0X78174E02770
 radio 1
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ips
 malformed-detect-policy default
 signature deauth_flood signature-id 1
 signature broadcast_deauth_flood signature-id 2
 signature disassoc_flood signature-id 3
 signature broadcast_disassoc_flood signature-id 4
 signature eapol_logoff_flood signature-id 5
 signature eap_success_flood signature-id 6
 signature eap_failure_flood signature-id 7
 signature pspoll_flood signature-id 8
 signature cts_flood signature-id 9
 signature rts_flood signature-id 10
 signature addba_req_flood signature-id 11
 signature-policy default
 countermeasure-policy default
 attack-detect-policy default
 virtual-security-domain default
 ip route-static 0.0.0.0 0.0.0.0 172.20.1.1
 undo info-center enable
 ntp-service refclock-master 2
 ssh server enable
 load xml-configuration
user-interface con 0
user-interface tty 4
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
return
[AC-3]
poe交换机配置
 version 5.20.99, Release 1111
 sysname H3C
 ipv6
 port-group-vlan 1
vlan 1
vlan 10
vlan 20
vlan 30
domain system
 state active
 idle-cut disable
user-group system
local-user admin
 password cipher
 service-type telnet
 service-type web
interface NULL0
 dhcp select relay
interface Vlan-interface10
 ip address 172.16.100.18 255.255.0.0
 ip address 172.20.1.3 255.255.0.0
 dhcp select relay
 port trunk permit vlan 1 20 30
 poe enable
 poe enable
 dhcp-snooping trust
 poe enable
 poe enable
 poe enable
 poe enable
interface GigabitEthernet1/0/7
 poe enable
interface GigabitEthernet1/0/8
 poe enable
interface GigabitEthernet1/0/9
 poe enable
interface GigabitEthernet1/0/10
 poe enable
interface GigabitEthernet1/0/11
 port trunk permit vlan 1 10
 poe enable
interface GigabitEthernet1/0/12
 poe enable
 dhcp-snooping trust
interface GigabitEthernet1/0/13
 poe enable
interface GigabitEthernet1/0/14
 poe enable
interface GigabitEthernet1/0/15
 poe enable
interface GigabitEthernet1/0/16
 poe enable
interface GigabitEthernet1/0/17
 poe enable
interface GigabitEthernet1/0/18
 poe enable
interface GigabitEthernet1/0/19
 poe enable
interface GigabitEthernet1/0/20
 poe enable
interface GigabitEthernet1/0/21
 poe enable
interface GigabitEthernet1/0/22
 poe enable
interface GigabitEthernet1/0/23
 poe enable
interface GigabitEthernet1/0/24
 poe enable
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
 undo info-center logfile enable
 dhcp enable
 ssh server enable
user-interface aux 0
 protocol inbound ssh
user-interface vty 5 15
粉丝:137人 关注:8人
二层获取地址,检查下放通相应vlan了吗
三层检查下dhcp中继的配置
4 个回答
AC没有配置 dhcp enable
Xcheng 九段
粉丝:122人 关注:3人
版本太低了。非受限局点请升级到最新版本
H3C WX2500E-CMW520-E3703P73版本软件及说明书-新华三集团-H3C
如果还异常,说明配置有问题或局点网络有问题
不过当前设备已停止技术支持,不太推荐升级。风险有点大。慎重考虑。
zhiliao_1ykAkj 知了小白
ac控制器上刚开启了dhcp功能,ac上的g1/0/1口连接poe交换机的g1/0/12口,vlan放通的全部。 现在ap还是获取不到ip地址
POE接口要port trunk pvid vlan
zhiliao_OqusJP 发表时间:2023-12-28
粉丝:4人 关注:0人
交换机上建个AP的管理VLAN
地址配成自动获取
就可以排查DHCP是卡在哪了
