核心交换机端口广播流量突然超过阈值,然后又低于阈值的报警,请问是什么原因呢?怎么处理呢?
  • 1收藏,850浏览
粉丝:0人 关注:4人
<188>Dec 28 13:26:42 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -Chassis=2-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet2/2/0/13 suddenly drops below the lower threshold. Threshold=20000, current value=6.
<188>Dec 28 13:26:31 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -Chassis=2-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet2/2/0/13 suddenly exceeds the threshold. Threshold=20000, current value=20012.
<188>Dec 28 13:20:27 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -Chassis=2-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet2/2/0/10 suddenly drops below the lower threshold. Threshold=20000, current value=22.
<188>Dec 28 13:20:16 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -Chassis=2-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet2/2/0/10 suddenly exceeds the threshold. Threshold=20000, current value=20007.
<188>Dec 28 13:06:36 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/3 suddenly drops below the lower threshold. Threshold=20000, current value=3.
<188>Dec 28 13:06:25 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/3 suddenly exceeds the threshold. Threshold=20000, current value=20002.
<188>Dec 28 12:58:46 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/47 suddenly drops below the lower threshold. Threshold=20000, current value=26.
<188>Dec 28 12:58:36 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/47 suddenly exceeds the threshold. Threshold=20000, current value=20079.
<188>Dec 28 12:26:38 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -Chassis=2-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet2/2/0/47 suddenly drops below the lower threshold. Threshold=20000, current value=30.
<188>Dec 28 12:26:28 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -Chassis=2-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet2/2/0/47 suddenly exceeds the threshold. Threshold=20000, current value=20045.
<188>Dec 28 12:10:49 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/10 suddenly drops below the lower threshold. Threshold=20000, current value=3.
<188>Dec 28 12:10:38 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/10 suddenly exceeds the threshold. Threshold=20000, current value=20016.
<188>Dec 28 12:09:36 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/48 suddenly drops below the lower threshold. Threshold=20000, current value=13.
<188>Dec 28 12:09:25 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/48 suddenly exceeds the threshold. Threshold=20000, current value=20023.
<188>Dec 28 11:20:15 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/47 suddenly drops below the lower threshold. Threshold=20000, current value=38.
<188>Dec 28 11:20:04 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -Chassis=1-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet1/2/0/47 suddenly exceeds the threshold. Threshold=20000, current value=20070.
<188>Dec 28 10:51:38 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: -Chassis=2-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet2/2/0/47 suddenly drops below the lower threshold. Threshold=20000, current value=37.
<188>Dec 28 10:51:27 2023 CDSL_OA_Core %%10IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: -Chassis=2-Slot=2; The incoming broadcast traffic of Ten-GigabitEthernet2/2/0/47 suddenly exceeds the threshold. Threshold=20000, current value=20086.
大佬们,请问一下核心交换机端口广播流量突然超过阈值,然后又低于阈值的报警,请问是什么原因呢?怎么处理呢?感谢了
ZZQ 八段
粉丝:4人 关注:0人
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Home/Switches/00-Public/Command/Message/H3C_S12500G_AF_S12500CR_Mess_R8054Pxx-14508/?CHID=945165
0.9  IFMON_INPUT_BC_RAPID_CHANGE
日志内容
The incoming broadcast traffic of [STRING] suddenly exceeds the threshold. Threshold=[UINT64], current value=[UINT64].
日志含义
接口入方向广播流量突变超过阈值
参数解释
$1:接口名称
$2:突变阈值
$3:当前突变值
日志等级
4 (Warning)
举例
IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: The incoming broadcast traffic of GigabitEthernet1/0/1 suddenly exceeds the threshold. Threshold=99, current value=44.
对系统的影响
可能导致业务流量被丢弃
日志产生原因
统计周期内,接口入方向广播流量突变超过阈值
处理建议
1.     CurrentInputBroadcastRateBaseInputBroadcastRate +InputBroadcastChangeThreshold时,请确认是否正常的广播流量增加,如果不是请检查链路中是否存在环路
2.     请收集设备的配置文件、日志信息、告警信息,并联系技术支持人员
请问这个统计周期内是多久的时间? 统计完一次是不是就清零了,然后重新开始一个周期的统计??
zhiliao_18364 发表时间:2024-01-29
zhiliao_18364 知了小白
粉丝:1人 关注:7人
请问这个统计周期内是多久的时间?
我也遇到了这个问题,请问有解决吗
升级版本
zhiliao_18364 发表时间:2024-04-22
