v5路由器msr2600-10
2024-01-04提问
  • 0收藏,266浏览
粉丝:2人 关注:1人
请问各位大佬,现在遇到了一个SSL VPN的问题,配置后,iNode拨号提示证书验证失败,可是路由器并没有证书相关的配置,认证方式也是本地认证;查看官网上的配置文档发现是结合认证服务器的场景,由于现场原因无法与官网上的配置1:1,请问有没有纯本地认证配置的场景案例,并且路由器的系统为V5版本,请问有没有大佬实施过我这种相关案例
粉丝:144人 关注:0人
您好,参考
SSL VPN配置示例:
IP接入配置举例(缺省证书)
interface SSLVPN-AC1
 ip address 10.1.1.100 255.255.255.0
acl advanced 3000
 rule 0 permit ip source 10.1.1.0 0.0.0.255 destination 20.2.2.0 0.0.0.255
sslvpn ip address-pool sslvpnpool 10.1.1.1 10.1.1.10
sslvpn gateway gw
 ip address 1.1.1.2 port 4430
 service enable
sslvpn context ctxip
 gateway gw domain domainip
 ip-tunnel interface SSLVPN-AC1
 ip-tunnel address-pool sslvpnpool mask 255.255.255.0
 ip-route-list rtlist
  include 20.2.2.0 255.255.255.0
 policy-group resourcegrp
  filter ip-tunnel acl 3000
  ip-tunnel access-route ip-route-list rtlist
 service enable
local-user sslvpnuser class network
 password simple 123456
 service-type sslvpn
 authorization-attribute sslvpn-policy-group resourcegrp
[H3C]display sslvpn gateway
Gateway name: gw
  Operation state: Up
  IP: 1.1.1.2  Port: 4430
  Front VPN instance: Not configured
[H3C]display sslvpn context
Context name: ctxip
  Operation state: Up
  AAA domain: Not specified
  Certificate authentication: Disabled
  Password authentication: Enabled
  Authentication use: All
  Dynamic password: Disabled
  Code verification: Disabled
  Default policy group: Not configured
  Associated SSL VPN gateway: gw
    Domain name: domainip
  Maximum users allowed: 1048575
  Idle timeout: 30 min
IPsec野蛮模式配置示例:
RTA------------------------------------------------------------------RTB
RTA分部:
192.168.1.0/24 1.1.1.1/24 1.1.1.2/24 192.168.2.0/24
interface LoopBack0
ip address 192.168.1.1 255.255.255.255
interface GigabitEthernet0/0
ip address 1.1.1.1 255.255.255.0
ipsec apply policy policy1
ip route-static 0.0.0.0 0 1.1.1.2
acl advanced 3000
rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
ipsec transform-set tran1
esp encryption-algorithm aes-cbc-128
esp authentication-algorithm sha1
ipsec policy policy1 1 isakmp
transform-set tran1
security acl 3000
remote-address 1.1.1.2
ike-profile 1
ike identity fqdn RTA
ike profile 1
keychain 1
exchange-mode aggressive
match remote identity fqdn RTB
proposal 1
ike proposal 1
encryption-algorithm 3des-cbc
authentication-algorithm md5
ike keychain 1
pre-shared-key address 1.1.1.2 255.255.255.0 key simple 123
RTB:总部
interface LoopBack0
ip address 192.168.2.1 255.255.255.255
ip address 1.1.1.2 255.255.255.0
ipsec apply policy 1
ip route-static 0.0.0.0 0 1.1.1.1
acl advanced 3000
rule 0 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
ipsec policy-template template1 1
transform-set tran1
#可以不写ACL
#security acl 3000
ike-profile 1
ipsec policy 1 1 isakmp template template1
ike identity fqdn RTB
ike profile 1
keychain 1
match remote identity fqdn RTA
proposal 1
ike proposal 1
ike keychain 1
pre-shared-key hostname RTA key simple 123
