H3C LS-5560S-28P-S1修改配置
2024-01-04提问
  • 0收藏,305浏览
新增交换机1台,H3C LS-5560S-28P-S1,现已配置如下:划分4个vlan:vlan40 ,系统应用,地址段192.18.40.254/24,接口1-9号;vlan41,监控段,地址段192.18.40.254/24,接口10-16号,vlan10,地址段192.18.1.xxx/24,接口17-20号,上联汇聚交换机192.18.1.254/24;vlan50,地址段192.18.5.254/24,接口21-24号,上联汇聚交换机192.18.5.254/24。现在想修改配置,实现交换下面40段和41段电脑可以互通,怎么配置?
佚名 九段
粉丝:22人 关注:0人
网关都放到新增交换机上,端口放通相关vlan,默认就是互通的
4 个回答
粉丝:232人 关注:0人
您好,两个办法
1、网关都放到新增设备上,默认就是互通的
2、网关位置不变,配置静态路由
粉丝:17人 关注:5人
40和41网段的网关都在新增交换机上。2个网段之间默认就是互通的。
# interface Vlan-interface1 ip address dhcp-alloc dhcp client identifier ascii 80616c23f2f0-VLAN0001 # interface Vlan-interface10 description bangong1duan # interface Vlan-interface40 description dibang ip address 192.18.40.254 255.255.255.0 # interface Vlan-interface41 description jiankong ip address 192.18.41.254 255.255.255.0 # interface Vlan-interface50 description bangong5duan # interface GigabitEthernet1/0/1 port link-mode bridge port access vlan 40 # interface GigabitEthernet1/0/2 port link-mode bridge port access vlan 40 # interface GigabitEthernet1/0/3 port link-mode bridge port access vlan 40 # interface GigabitEthernet1/0/4 port link-mode bridge port access vlan 40 # interface GigabitEthernet1/0/5 port link-mode bridge port access vlan 40 # interface GigabitEthernet1/0/6 port link-mode bridge port access vlan 40 # interface GigabitEthernet1/0/7 port link-mode bridge port access vlan 40 # interface GigabitEthernet1/0/8 port link-mode bridge port access vlan 40 # interface GigabitEthernet1/0/9 port link-mode bridge port access vlan 41 # interface GigabitEthernet1/0/10 port link-mode bridge port access vlan 41 # interface GigabitEthernet1/0/11 port link-mode bridge port access vlan 41 # interface GigabitEthernet1/0/12 port link-mode bridge port access vlan 41 # interface GigabitEthernet1/0/13 port link-mode bridge port access vlan 41 # interface GigabitEthernet1/0/14 port link-mode bridge port access vlan 41 # interface GigabitEthernet1/0/15 port link-mode bridge port access vlan 41 # interface GigabitEthernet1/0/16 port link-mode bridge port access vlan 41 # interface GigabitEthernet1/0/17 port link-mode bridge port access vlan 10 # interface GigabitEthernet1/0/18 port link-mode bridge port access vlan 10 # interface GigabitEthernet1/0/19 port link-mode bridge port access vlan 10 # interface GigabitEthernet1/0/20 port link-mode bridge port access vlan 10 # interface GigabitEthernet1/0/21 port link-mode bridge port access vlan 50 # interface GigabitEthernet1/0/22 port link-mode bridge port access vlan 50 # interface GigabitEthernet1/0/23 port link-mode bridge port access vlan 50 # interface GigabitEthernet1/0/24 port link-mode bridge port access vlan 50 # interface GigabitEthernet1/0/25 port link-mode bridge port access vlan 40 # interface GigabitEthernet1/0/26 port link-mode bridge port access vlan 41 # interface GigabitEthernet1/0/27 port link-mode bridge port access vlan 10 # interface GigabitEthernet1/0/28 port link-mode bridge port access vlan 50
zhiliao_vRnfub 发表时间:2024-01-04
粉丝:119人 关注:1人
网关在一起,默认都是通的
zhiliao_vRnfub 知了小白
配置如下:
[sjytiejingfen]dis cu
version 7.1.070, Release 6328P03
sysname sjytiejingfen
clock protocol none
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
lldp global enable
loopback-detection global enable vlan 1 to 4094
password-recovery enable
vlan 1
vlan 10
vlan 40 to 41
vlan 50
stp global enable
interface NULL0
description dibang
port access vlan 40
port access vlan 40
port access vlan 40
port access vlan 40
port access vlan 40
port access vlan 40
port access vlan 40
port access vlan 40
port access vlan 41
port access vlan 41
port access vlan 41
port access vlan 41
port access vlan 41
port access vlan 41
port access vlan 41
port access vlan 41
port access vlan 10
port access vlan 10
port access vlan 10
port access vlan 10
port access vlan 50
port access vlan 50
port access vlan 50
port access vlan 50
port access vlan 40
port access vlan 41
port access vlan 10
port access vlan 50
这样还需要修改或者增加什么配置吗?
不需要了,只要终端上地址 掩码 网关都没有问题,默认就是互通的。
执笔画卿颜 发表时间:2024-01-04
Telnet开启了,把vlan1配置地址192.168.0.254/24了,需要配置默认路由吗?
