WAP712刷胖
2024-01-06提问
  • 0收藏,308浏览
61990 二段
粉丝:0人 关注:3人
WAP712在刷胖的时候需要修改名称吗?
官网下载下来的是这个名称,我升级完重起一直进不去如下图:
Protocol (FTP or TFTP) :tftp tftp
Load File Name         :WA4300S-WPT330-R1113P19-OASIS.bin
Target File Name       :WA4300S-WPT330-R1113P19-OASIS.bin
Server IP Address      :10.1.1.1 10.1.1.1
Local IP Address       :10.1.1.2 10.1.1.2
Subnet Mask            :255.255.255.0 255.255.255.0
Gateway IP Address     :0.0.0.0 10.1.1.254
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 2
Enter your choice(0-5): 1
Loading.....................................................................
.............................................Done.
13501440 bytes downloaded!
Something wrong with the file.
Enter your choice(0-5): 3
Enter your choice(0-5): 0
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Enter your choice(0-9): 0
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.................................
Done!
*                 H3C WAP712C-LI BootWare, Version 7.14                    *
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd.
Compiled Date       : Oct 15 2018
CPU Type            : ATHEROS AR9563
CPU L1 Cache        : 32KB
CPU Clock Speed     : 775MHz
Memory Type         : SDRAM
Memory Size         : 128MB
Memory Speed        : 560MHz
BootWare Size       : 512KB
Flash Size          : 16MB
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading the main boot and system image files...
The system image does not exist!
Loading the backup boot and system image files...
The image does not exist!
Booting image fails!
Trying to get the IP address from the DHCP server......
粉丝:44人 关注:1人
你AP的具体型号是什么?712后面没有尾缀了么?如果没有的话你现在的版本不对了
712的版本是这些的,没有你的版本呀
H3C WA4300系列无线接入点-新华三集团-H3C
看你回复的型号你是不是操作错了,你按照这个步骤去操作
WAP712C-LI-S-FIT
61990 发表时间:2024-01-06
无论是将文件名称改为wa4300s-oasis.bin还是使用默认下载的文件传上去都提示文件有问题,换过电脑跟网线以及重新下载软件版本还是一样,不知道是那里的问题。
粉丝:2人 关注:0人
可以尝试先升级bootrom
升级了也是依旧
回复61990:
您好,文件没问题,请看一下手册,对照手册操作。如果搞不定,我可以远程给你弄一下。
爱上秋刀鱼 发表时间:2024-01-07
