核心交换机摄像头丢包
2024-01-09提问
  • 2关注
  • 0收藏,272浏览
zhang 零段
核心7602 交换机下的监控摄像头丢包率高,以前正常的,现在摄像头都很卡,因为摄像头大约在400个,用的3个网段,192.168.1.0/24、192.168.2.0/24、192.168.3.0.24基于IP划分VLAN,6网段是上墙的服务器及NVR。不知道从何查询故障点,和丢包检测请教大神。
正常业务需要把摄像头轮询上大屏
 version 7.1.045, Release 7187
mdc Admin id 1
 sysname Dahua
 clock protocol none
 telnet server enable
 forward-path-detection enable
 irf mode normal
 lldp global enable
 loopback-detection global enable vlan 1 to 4094
 system-working-mode standard
 xbar load-balance
 password-recovery enable
vlan 1
 ip-subnet-vlan 0 ip 192.168.1.0 255.255.255.0
vlan 2
 ip-subnet-vlan 0 ip 192.168.2.0 255.255.255.0
vlan 3
 ip-subnet-vlan 0 ip 192.168.3.0 255.255.255.0
vlan 4
 ip-subnet-vlan 0 ip 192.168.4.0 255.255.255.0
vlan 5
 ip-subnet-vlan 0 ip 192.168.5.0 255.255.255.0
vlan 6
 ip-subnet-vlan 0 ip 192.168.6.0 255.255.255.0
vlan 7 to 9
vlan 11 to 4094
 stp mode stp
 stp global enable
ftth
interface Bridge-Aggregation1
interface Bridge-Aggregation2
interface Bridge-Aggregation3
 port access vlan 6
 link-aggregation mode dynamic
 link-aggregation load-sharing mode source-ip
interface Bridge-Aggregation4
 port access vlan 6
interface NULL0
interface Vlan-interface1
interface Vlan-interface2
 ip address 192.168.2.1 255.255.255.0
interface Vlan-interface3
 ip address 192.168.3.1 255.255.255.0
interface Vlan-interface4
 ip address 192.168.4.1 255.255.255.0
interface Vlan-interface5
 description LINK_TO_ROUTER
 ip address 192.168.5.2 255.255.255.0
interface Vlan-interface6
 ip address 192.168.6.1 255.255.255.0
interface Vlan-interface7
interface Vlan-interface40
 ip address 10.198.40.1 255.255.248.0
interface Vlan-interface200
 ip address 192.168.185.1 255.255.255.0
interface GigabitEthernet2/0/1
 port link-mode bridge
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
 port access vlan 2
interface GigabitEthernet2/0/4
 port access vlan 2
interface GigabitEthernet2/0/5
 port access vlan 3
interface GigabitEthernet2/0/6
 port access vlan 3
interface GigabitEthernet2/0/7
 port access vlan 4
interface GigabitEthernet2/0/8
 port access vlan 4
interface GigabitEthernet2/0/9
 port access vlan 6
interface GigabitEthernet2/0/10
 port access vlan 6
interface GigabitEthernet2/0/11
 port access vlan 6
interface GigabitEthernet2/0/12
 port access vlan 6
interface GigabitEthernet2/0/13
 port access vlan 6
interface GigabitEthernet2/0/14
 port access vlan 40
interface GigabitEthernet2/0/15
 port access vlan 6
interface GigabitEthernet2/0/16
 port access vlan 40
interface GigabitEthernet2/0/17
 port access vlan 6
interface GigabitEthernet2/0/18
 port access vlan 6
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
 port access vlan 40
interface GigabitEthernet2/0/21
 port access vlan 6
 port link-aggregation group 3
interface GigabitEthernet2/0/22
 port access vlan 6
interface GigabitEthernet2/0/23
 port access vlan 6
 port link-aggregation group 4
interface GigabitEthernet2/0/24
 port access vlan 6
interface GigabitEthernet2/0/25
 port link-aggregation group 2
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
 port link-type hybrid
 port hybrid vlan 1 3 to 5 untagged
 port hybrid ip-subnet-vlan vlan 3
 port hybrid ip-subnet-vlan vlan 4
 port hybrid ip-subnet-vlan vlan 5
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
 port access vlan 4
interface GigabitEthernet2/0/34
 port access vlan 4
interface GigabitEthernet2/0/35
 port access vlan 2
interface GigabitEthernet2/0/36
 port access vlan 4
interface GigabitEthernet2/0/37
 port access vlan 5
interface GigabitEthernet2/0/38
 port access vlan 5
interface GigabitEthernet2/0/39
 port access vlan 2
interface GigabitEthernet2/0/40
 port access vlan 2
interface GigabitEthernet2/0/41
 port access vlan 2
interface GigabitEthernet2/0/42
 port access vlan 2
interface GigabitEthernet2/0/43
 port access vlan 2
interface GigabitEthernet2/0/44
 port access vlan 2
interface M-GigabitEthernet0/0/0
 ip address 192.168.100.100 255.255.255.0
interface Ten-GigabitEthernet2/0/45
 port link-aggregation group 1
interface Ten-GigabitEthernet2/0/46
interface Ten-GigabitEthernet2/0/47
 port hybrid vlan 1 to 6 untagged
 port hybrid ip-subnet-vlan vlan 1
 port hybrid ip-subnet-vlan vlan 2
 port hybrid ip-subnet-vlan vlan 6
interface Ten-GigabitEthernet2/0/48
 port hybrid vlan 1 to 2 untagged
 loopback-detection enable vlan 1 to 4094
 scheduler logfile size 16
line class aux
 user-role network-admin
line class vty
 user-role network-operator
line aux 0
line vty 0 63
 ip route-static 0.0.0.0 0 192.168.5.1
 undo info-center enable
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$vV0ydFla7zPGeiIe$PSTnrFky/Ale318wrR/nefG2bR5mjP7XbQ3gaI1/UiYGOd0jd0I1ZOKIDeOdl+yTiw9MOaPDHaJBMArnoTSjCg==
 service-type ftp
 service-type telnet http https
 authorization-attribute user-role level-15
 ftp server enable
粉丝:5人 关注:1人
(1)可以看看接口流量是不是比较大,如果300S的记录最大值已经达到带宽的80%,有可能存在拥塞丢包;
(2)可通过逐步减少摄像头看下是否正常
(3)丢包的话可以在交换机做流统,确认丢包位置;流统可参考该链接配置方法https://zhiliao.h3c.com/Theme/details/142620
