带vpn实例的nat server
2024-01-11提问
  • 0收藏,380浏览
防火墙1口绑定vrf连接外网,2口绑定同样vrf连接内网
怎样做nat server使静态地址一对一映射公网地址?
粉丝:17人 关注:9人
可以参考如下案例:
FW上做了静态NAT,并且内外网口都有VPN实例,要实现MSR4通过访问1.1.1.1来实现MSR4访问MSR1的10.0.0.1
配置步骤
MSR1关键配置:
 interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 10.0.0.1 255.255.255.0
 ip route-static 0.0.0.0 0 10.0.0.2
MSR2关键配置:
 combo enable copper
 ip address 10.0.0.2 255.255.255.0
interface GigabitEthernet0/1
 combo enable copper
 ip address 10.1.0.1 255.255.255.0
ip route-static 0.0.0.0 0 10.1.0.2
FW主要配置:
VPN配置:
 ip binding vpn-instance vpn1
 ip binding vpn-instance vpn2
接口配置以及静态NAT配置:
 combo enable copper
 ip address 10.1.0.2 255.255.255.0
 combo enable copper
 ip address 1.1.1.1 255.255.255.0
 nat static enable
nat static outbound 10.0.0.1 vpn-instance vpn1 1.1.1.1 vpn-instance vpn2
安全域及安全策略配置:
security-zone name Trust
 import interface GigabitEthernet1/0/1
security-zone name Untrust
 import interface GigabitEthernet1/0/2
security-policy ip
 rule 0 name 0
 action pass
 vrf vpn1
 source-zone untrust
 destination-zone trust
 rule 1 name 1
 action pass
 vrf vpn2
 source-zone untrust
路由配置:
ip route-static vpn-instance vpn1 2.2.2.0 24 vpn-instance vpn2 1.1.1.2
ip route-static vpn-instance vpn1 10.0.0.0 24 10.1.0.1
 ip route-static vpn-instance vpn2 2.2.2.0 24 1.1.1.2
 ip route-static vpn-instance vpn2 10.0.0.0 24 vpn-instance vpn1 10.1.0.1
MSR3关键配置:
 combo enable copper
 ip address 1.1.1.2 255.255.255.0
 combo enable copper
 ip address 2.2.2.1 255.255.255.0
MSR4关键配置:
 combo enable copper
 ip address 2.2.2.2 255.255.255.0
ip route-static 1.1.1.0 24 2.2.2.1
配置关键点
配置关键点,主要是防火墙:
1.安全策略中UNtrust-----trust方向策略 在VRF1与VRF2中都要配置,并且VRF1中,源地址是公网地址,目的地址nat global地址;
在VRF2中,源地址是公网地址,目的地址是nat server 的inside地址
2、跨VPN实例的路由要配置
(1)VPN1中要有到10.0.0.1的路由,并且要有到VPN2目的地址为2.2.2.2的路由
(2)VPN2中要有2.2.2.0的路由,并且要有到1VPN1目的地址为10.0.0.1的路由
3、当现场业务不通,进行debug排查的时候,要想看到完整的4条流,下面ACL必须都配置,并且VRF实例不能错误
acl advanced 3000
 rule 0 permit ip vpn-instance vpn1 source 10.0.0.1 0
 rule 5 permit ip vpn-instance vpn1 source 1.1.1.1 0
 rule 10 permit ip vpn-instance vpn2 destination 1.1.1.1 0
 rule 20 permit ip vpn-instance vpn1 destination 10.0.0.1 0
Xcheng 九段
粉丝:121人 关注:3人
同个vpn实例当成一个fw就行了
配置时候带上vpn实例即可
粉丝:1人 关注:6人
https://zhiliao.h3c.com/Theme/details/165093
可以参考这个看下
粉丝:1人 关注:1人
按提供的拓扑举例:
在F1090 的GE0/1接口下配置nat server global 117.261.20.4 vpn-instance 1 inside 192.168.1.3 vpn-instance 1
相关路由正常,安全策略放通,需注意针对以上流量安全策略destination-ip 应配置为192.168.1.3。
