交换机一直有bgdu报文,该如何排查,告警如下
2024-01-12提问
  • 1收藏,697浏览
粉丝:0人 关注:3人
%Jan  1 09:33:19:315 2013 H3C STP/4/STP_DISPUTE_RESTORATION: The block action by dispute guard was undone on Instance 0's port GigabitEthernet1/0/23. The port transited to learning state.
%Jan  1 09:33:13:315 2013 H3C STP/5/STP_BPDU_RECEIVE_EXPIRY: Instance 0's port GigabitEthernet1/0/23 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Jan  1 09:33:12:842 2013 H3C STP/4/STP_DISPUTE: Instance 0's port GigabitEthernet1/0/23 received an inferior BPDU from a designated port which is in forwarding or learning state.
%Jan  1 09:33:10:842 2013 H3C STP/4/STP_DISPUTE: Instance 0's port GigabitEthernet1/0/23 received an inferior BPDU from a designated port which is in forwarding or learning state.
%Jan  1 09:33:08:842 2013 H3C STP/4/STP_DISPUTE: Instance 0's port GigabitEthernet1/0/23 received an inferior BPDU from a designated port which is in forwarding or learning state.
%Jan  1 09:33:06:842 2013 H3C STP/4/STP_DISPUTE: Instance 0's port GigabitEthernet1/0/23 received an inferior BPDU from a designated port which is in forwarding or learning state.
%Jan  1 09:33:04:842 2013 H3C STP/4/STP_DISPUTE: Instance 0's port GigabitEthernet1/0/23 received an inferior BPDU from a designated port which is in forwarding or learning state.
%Jan  1 09:33:02:842 2013 H3C STP/4/STP_DISPUTE: Instance 0's port GigabitEthernet1/0/23 received an inferior BPDU from a designated port which is in forwarding or learning state.
%Jan  1 09:33:00:842 2013 H3C STP/4/STP_DISPUTE: Instance 0's port GigabitEthernet1/0/23 received an inferior BPDU from a designated port which is in forwarding or learning state.
粉丝:31人 关注:4人
g1/0/23 端口收到的 bpdu 报文、从一个指定端口,且此端口处于forwarding 、learning 状态、触发了dispute 保护、
什么是Dispute
交换机端口的STP状态依靠不断接收上游交换机发送的BPDU报文来维持,当由于链路拥塞或者单向链路故障等问题,导致根端口收不到上游交换机的BPDU时,下游交换机会重新选择根端口,原来的根端口经过计算后会变为指定端口,而原来的阻塞端口经过计算后会变为根端口且迁移到转发状态,从而导致网络中产生环路,Dispute机制会抑制这种环路的产生。
Dispute机制默认在所有端口生效,当端口收到这样的BPDU报文:报文中携带指定端口角色和Learning/Forwarding状态并且报文中的优先级向量低于接收端口的优先级向量,此时 Dispute机制生效,接收该报文的端口被设置为Discarding状态,阻止网络形成环路。
bpdu 的单通;
上游设备的端口收到了低优先级的bpdu、而下游设备收不到上游设备发送的高优先级的bpdu、触发stp dispute 、认为下游可能发生了环路、将该端口致于discardding 状态;
1、解决bpdu单通;
2. 导致单通的原因除了常见的配置问题以外,还有可能是链路拥塞或者单向链路故障等。
3. 设备上线之前需检查网络中相关设备的STP配置,避免触发Dispute机制。
4. H3C V5平台设备的STP功能不具有Dispute保护机制。
5. H3C V7平台设备的STP功能具有Dispute保护机制,特定情况下可以配置undo stp dispute-protection命令关闭Dispute保护功能,一般情况下不建议关闭。
而下游设备收不到上游设备发送的高优先级的bpdu、触发stp dispute 、认为下游可能发生了环路、将该端口致于discardding 状态,这个是下游设备触发了stp dispute吗,下游设备discardding?
zhiliao_7UAySV 发表时间:2024-03-18
4 个回答
粉丝:4人 关注:4人
生成树问题,看你生成树是不是没配完,或者没关完
粉丝:7人 关注:15人
查看这个端口 port GigabitEthernet1/0/23,排查SFP故障再排查链路,可以先断开链接看看。
粉丝:8人 关注:0人
  交换机一直有bgdu报文的原因可能有以下几种:
1. 交换机的端口配置了BPDU过滤功能,导致收到的BPDU报文被丢弃或者转发到其他端口。
2. 交换机的端口配置了BPDU保护功能,导致收到的BPDU报文被保护或者转发到其他端口。
3. 交换机的端口配置了BPDU转发功能,导致收到的BPDU报文被转发到其他端口。
4. 交换机的端口配置了BPDU过滤、保护或者转发功能,并且与其他设备或者模块存在冲突或者不兼容。
如果您想要排查交换机一直有bgdu报文的问题,您可以尝试以下方法:
1. 检查交换机的端口是否开启了BPDU过滤、保护或者转发功能,并且是否与其他设备或者模块匹配。
2. 检查交换机的端口是否正确配置了BPDU过滤、保护或者转发参数,并且是否符合业界标准。
3. 检查交换机的端口是否正常工作,并且没有故障或者异常。
4. 检查网络环境是否正常,并且没有干扰或者故障。
